Script qui ne passe pas sur Firefox
Je souhaiterais utilisé un script java pour faire une rotation de bannière, le problème c'est que ce script est compatible sur IE9 mais pas sur Firefox ni sur Chrome (rien ne s'affiche)
Quelqu'un aurait-il une solution ?
Voici mon script :
<body>
<script language="JavaScript1.2">
var scrollerwidth=700
var scrollerheight=230
var scrollerbgcolor='white'
//3000 miliseconds=3 seconds
var pausebetweenimages=2000
var slideimages=new Array()
slideimages[0]='<a href="URL 1"><img src="IMG 1" border="0"></a>'
slideimages[1]='<a href="URL 2"><img src="IMG 2" border="0"></a>'
if (slideimages.length>1)
i=2
else
i=0
function move1(whichlayer){
tlayer=eval(whichlayer)
if (tlayer.top>0&&tlayer.top<=5){
tlayer.top=0
setTimeout("move1(tlayer)",pausebetweenimages)
setTimeout("move2(document.main.document.second)",pausebetweenimages)
return
if (tlayer.top>=tlayer.document.height*-1){
tlayer.top-=5
setTimeout("move1(tlayer)",100)
else{
tlayer.top=scrollerheight
tlayer.document.write(slideimages[i])
tlayer.document.close()
if (i==slideimages.length-1)
i=0
else
i++
function move2(whichlayer){
tlayer2=eval(whichlayer)
if (tlayer2.top>0&&tlayer2.top<=5){
tlayer2.top=0
setTimeout("move2(tlayer2)",pausebetweenimages)
setTimeout("move1(document.main.document.first)",pausebetweenimages)
return
if (tlayer2.top>=tlayer2.document.height*-1){
tlayer2.top-=5
setTimeout("move2(tlayer2)",100)
else{
tlayer2.top=scrollerheight
tlayer2.document.write(slideimages[i])
tlayer2.document.close()
i=0
else
i++
function move3(whichdiv){
tdiv=eval(whichdiv)
if (tdiv.style.pixelTop>0&&tdiv.style.pixelTop<=5){
tdiv.style.pixelTop=0
setTimeout("move3(tdiv)",pausebetweenimages)
setTimeout("move4(second2)",pausebetweenimages)
return
if (tdiv.style.pixelTop>=tdiv.offsetHeight*-1){
tdiv.style.pixelTop-=5
setTimeout("move3(tdiv)",100)
else{
tdiv.style.pixelTop=scrollerheight
tdiv.innerHTML=slideimages[i]
i=0
else
i++
function move4(whichdiv){
tdiv2=eval(whichdiv)
if (tdiv2.style.pixelTop>0&&tdiv2.style.pixelTop<=5){
tdiv2.style.pixelTop=0
setTimeout("move4(tdiv2)",pausebetweenimages)
setTimeout("move3(first2)",pausebetweenimages)
return
if (tdiv2.style.pixelTop>=tdiv2.offsetHeight*-1){
tdiv2.style.pixelTop-=5
setTimeout("move4(second2)",100)
else{
tdiv2.style.pixelTop=scrollerheight
tdiv2.innerHTML=slideimages[i]
i=0
else
i++
function startscroll(){
if (document.all){
move3(first2)
second2.style.top=scrollerheight
else if (document.layers){
document.main.visibility='show'
document.main.document.second.top=scrollerheight+5
document.main.document.second.visibility='show'
window.onload=startscroll</script><ilayer id="main" width=&{scrollerwidth}; height=&{scrollerheight}; bgColor=&{scrollerbgcolor}; visibility=hide></ilayer><script language="JavaScript1.2">
if (document.all){
document.writeln('<span id="main2" style="position:relative;width:'+scrollerwidth+';height:'+scrollerheight+';overflow:hiden;background-color:'+scrollerbgcolor+'">')
document.writeln('<div style="position:absolute;width:'+scrollerwidth+';height:'+scrollerheight+';clip:rect(0 '+scrollerwidth+' '+scrollerheight+' 0);left:0;top:0">')
document.writeln('<div id="first2" style="position:absolute;width:'+scrollerwidth+';left:0;top:1;">')
document.write(slideimages[0])
document.writeln('</div>')
document.writeln('<div id="second2" style="position:absolute;width:'+scrollerwidth+';left:0;top:0">')
document.write(slideimages[1])
document.writeln('</span>')
}</script>
</body>
Merci par avance
  1. les points virgules étaient en option sur ton clavier ?
      GG
  2. Contributeur
    Hello,
    C'est toi qui a pondu ça ou pas ?
    Il faudrait essayer de remplacer ta balise script :
    Par celle-ci :
    <script type="text/javascript">
    1. Non, je l'ai récupérer sur un site. (un peu long ?)
      J'ai essayer de remplacer par <script type="text/javascript"> et le problème est le même
      ce qui m'intéresse, c'est plus l'effet de défilement de haut en bas plutôt que l'image qui change d'un coup, si jamais tu avais un autre script, je prends aussi ...
        Non je n'ai pas sous l'aisselle comme ça.
        Par contre, installe le plugin "Firebug" de Firefox, et active sa "Console" ; s'il y a des erreurs JS, elles te seront signalées.
