Aide pour un pc contaminé
Bonjour,je vien de faire un scan en ligne avec Panda active scan et il me trouve des malware que j'aimerais bien me débarasser voici le scan:
ANALYSIS: 2011-02-26 13:03:01
PROTECTIONS
Description Version Active Updated
Windows Defender No No
MALWARE
Id Description Type Active Severity Disinfectable Disinfected Location
00076351 Exploit/ByteVerify HackTools No 0 Yes No c:\users\asus\appdata\locallow\sun\java\deployment\cache\6.0\62\29d6457e-2f35b5cd[dev/s/adgredy.class]
00076352 Exploit/ByteVerify HackTools No 0 Yes No c:\users\asus\appdata\locallow\sun\java\deployment\cache\6.0\62\29d6457e-2f35b5cd[dev/s/dyesyasz.class]
00076353 Exploit/ByteVerify HackTools No 0 Yes No c:\users\asus\appdata\locallow\sun\java\deployment\cache\6.0\62\29d6457e-2f35b5cd[dev/s/loaderx.class]
00079880 Exploit/CVE-2009-3867 Virus/Trojan No 0 Yes No c:\users\asus\appdata\locallow\sun\java\deployment\cache\6.0\26\56bf0f5a-20b1fff6[vmain.class]
00139061 Cookie/Doubleclick TrackingCookie No 0 Yes No c:\users\asus\appdata\roaming\microsoft\windows\cookies\low\asus@doubleclick[2].txt
00139061 Cookie/Doubleclick TrackingCookie No 0 Yes No c:\users\asus\appdata\roaming\microsoft\windows\cookies\low\asus@doubleclick[1].txt
00139064 Cookie/Atlas DMT TrackingCookie No 0 Yes No c:\users\asus\appdata\roaming\microsoft\windows\cookies\low\asus@atdmt[2].txt
00139064 Cookie/Atlas DMT TrackingCookie No 0 Yes No c:\users\asus\appdata\roaming\microsoft\windows\cookies\asus@atdmt[2].txt
00145393 Cookie/Tradedoubler TrackingCookie No 0 Yes No c:\users\asus\appdata\roaming\microsoft\windows\cookies\low\asus@tradedoubler[1].txt
00145738 Cookie/Mediaplex TrackingCookie No 0 Yes No c:\users\asus\appdata\roaming\microsoft\windows\cookies\low\asus@mediaplex[2].txt
00167704 Cookie/Xiti TrackingCookie No 0 Yes No c:\users\asus\appdata\roaming\microsoft\windows\cookies\low\asus@xiti[2].txt
00167704 Cookie/Xiti TrackingCookie No 0 Yes No c:\users\asus\appdata\roaming\microsoft\windows\cookies\low\asus@xiti[1].txt
00168056 Cookie/YieldManager TrackingCookie No 0 Yes No c:\users\asus\appdata\roaming\microsoft\windows\cookies\low\asus@ad.yieldmanager[2].txt
00168061 Cookie/Apmebf TrackingCookie No 0 Yes No c:\users\asus\appdata\roaming\microsoft\windows\cookies\low\asus@apmebf[1].txt
00168106 Cookie/Weborama TrackingCookie No 0 Yes No c:\users\asus\appdata\roaming\microsoft\windows\cookies\low\asus@weborama[1].txt
00168109 Cookie/Adtech TrackingCookie No 0 Yes No c:\users\asus\appdata\roaming\microsoft\windows\cookies\low\asus@adtech[1].txt
00207936 Cookie/Adviva TrackingCookie No 0 Yes No c:\users\asus\appdata\roaming\microsoft\windows\cookies\low\asus@adviva[1].txt
00273339 Cookie/Smartadserver TrackingCookie No 0 Yes No c:\users\asus\appdata\roaming\microsoft\windows\cookies\low\asus@smartadserver[1].txt
03074964 Trj/CI.A Virus/Trojan No 0 Yes No c:\windows\system32\weber\key.exe
06832939 W32/P2Pworm.MW.worm Virus/Worm No 0 Yes No c:\users\asus\desktop\cle usb\autorun.inf
VULNERABILITIES
Id Severity Description
je posterais un scan hijackthis une fois fini merci d'avance :)
31 réponses
Le sujet décrit une détection de malwares par un scan Panda Active Scan, avec des éléments détectés comme Exploit/ByteVerify, Cookies de suivi et des menaces Trojan puis un fichier autorun.inf, signalant une infection potentielle. Plusieurs réponses proposent des méthodes de nettoyage spécifiques, notamment Malwarebytes Anti-Malware et Ad-Remover, avec des étapes de mise à jour, analyse complète et suppression des éléments en démarrage et des clés de registre associées. En parallèle, échanges évoquent des risques liés à des commandes réseau comme netsh winsock reset et les difficultés pour réactiver le pare-feu après manipulation, soulignant l’importance d’un suivi sûr et d’un diagnostic complémentaire si nécessaire.
    Hello,
    Pas besoin de scan HJT, il est devenu obsolète. De nos jour on utilises d'autres tool de diagnostique.
    Commence par ceci :
    * Télécharge UsbFix (créé par El Desaparecido & C_XX) sur ton Bureau. Si ton antivirus affiche une alerte, ignore le et désactive le temporairement.
    * Branche tes sources de données externes à ton PC (clé USB, disque dur externe, etc...) sans les ouvrir
    * Double clique sur le raccourci UsbFix sur ton Bureau, l'installation se fera automatiquement
    * Clique sur "Recherche"
    * Laisse travailler l'outil
    * A la fin, le rapport va s'afficher : poste le dans ta prochaine réponse (il est aussi sauvegardé a la racine du disque dur)
    Aide en images : Tutoriel "Recherche"
    1. rapport usb fix :
      ############################## | UsbFix 7.041 | [Recherche]
      Utilisateur: ASUS (Administrateur) # PC-DE-ASUS [ASUSTeK Computer Inc. F8Vr]
      Mis à jour le 24/02/2011 par TeamXscript
      Lancé à 13:28:03 | 26/02/2011
      Site Web: http://www.teamxscript.org
      Un fichier non reconnu ? : http://www.teamxscript.org/Upload.php
      Contact: TeamXscript.ElDesaparecido@gmail.com
      CPU: Intel(R) Core(TM)2 Duo CPU T5800 @ 2.00GHz
      CPU 2: Intel(R) Core(TM)2 Duo CPU T5800 @ 2.00GHz
      Microsoft® Windows Vista(TM) Édition Familiale Premium (6.0.6002 32-Bit) # Service Pack 2
      Internet Explorer 8.0.6001.19019
      RAM -> 3070 Mo
      C:\ (%systemdrive%) -> Disque fixe # 116 Go (26 Go libre(s) - 22%) [VistaOS] # NTFS
      D:\ -> Disque fixe # 107 Go (41 Go libre(s) - 39%) [DATA] # NTFS
      E:\ -> CD-ROM
      F:\ -> CD-ROM
      ################## | Éléments infectieux |
      ################## | Registre |
      ################## | Mountpoints2 |
      HKCU\.\.\.\.\Explorer\MountPoints2\{3997038f-75fd-11df-9ba0-99ed50b3abc3}
      Shell\AutoRun\Command = U3ROM/flyhigh.exe
      Shell\explore\Command = U3ROM/flyhigh.exe
      Shell\open\Command = U3ROM/flyhigh.exe
      HKCU\.\.\.\.\Explorer\MountPoints2\{72605f62-3b66-11e0-ae8f-d2e8b3816f95}
      Shell\AutoRun\Command = G:\start.exe
      HKCU\.\.\.\.\Explorer\MountPoints2\{bb264038-bb17-11df-995e-bc9a9db9f8c0}
      Shell\AutoRun\Command = G:\urDrive.exe
      ################## | Vaccin |
      (!) Cet ordinateur n'est pas vacciné!
      ################## | E.O.F |
        Hello,
        * Clique sur "Suppression"
        * Ton Bureau va disparaitre puis l'ordinateur va redémarrer : c'est normal
        :!: UsbFix te proposera d'envoyer un dossier compressé à cette adresse. Ce dossier a été créé par UsbFix sur ton Bureau. Merci de l'envoyer à l'adresse indiquée afin d'aider l'auteur de UsbFix dans ses recherches. Une fois sur le site, il faut sélectionner "UsbFix" dans le menu déroulant. Merci d'avance pour ta contribution !
        Aide en images : Tutoriel "Nettoyage"
        Puis
        Utilise ce logiciel de diagnostic :
        * Télécharge ZHPDiag (de Nicolas Coolman)
        * Laisse toi guider lors de l'installation, il se lancera automatiquement à la fin.
        * Clique sur l'icône représentant une loupe (« Lancer le diagnostic »)
        * Héberge le rapport ZHPDiag.txt sur ce site, puis copie/colle le lien fourni dans ta prochaine réponse sur le forum.
        1. ############################## | UsbFix 7.041 | [Suppression]
          Lancé à 14:07:56 | 26/02/2011
          RAM -> 3070 Mo
          E:\ -> CD-ROM
          F:\ -> CD-ROM
          Supprimé! C:\$RECYCLE.BIN\S-1-5-21-3276036760-3260313600-186898634-1000
          Supprimé! D:\$RECYCLE.BIN\S-1-5-21-3276036760-3260313600-186898634-1000
          ################## | Listing |
          [26/02/2011 - 14:08:29 | SHD ] C:\$RECYCLE.BIN
          [18/02/2011 - 14:07:02 | D ] C:\AMD
          [09/10/2008 - 16:47:08 | D ] C:\ASUS.SYS
          [18/02/2011 - 14:18:34 | D ] C:\ATI
          [18/09/2006 - 22:43:36 | N | 24] C:\autoexec.bat
          [26/02/2011 - 13:55:24 | RASHD ] C:\Autorun.inf
          [03/01/2010 - 16:25:59 | D ] C:\Boot
          [11/04/2009 - 07:36:36 | RASH | 333257] C:\bootmgr
          [16/04/2008 - 12:27:17 | N | 8192] C:\BOOTSECT.BAK
          [28/01/2010 - 19:45:19 | D ] C:\Clarity
          [26/02/2011 - 13:24:58 | D ] C:\Config.Msi
          [18/09/2006 - 22:43:37 | N | 10] C:\config.sys
          [02/11/2006 - 14:02:03 | SHD ] C:\Documents and Settings
          [08/02/2011 - 18:48:52 | D ] C:\Download
          [25/06/2008 - 02:36:55 | N | 1048576] C:\F8Va.BIN
          [26/02/2011 - 13:24:59 | ASH | 3220295680] C:\hiberfil.sys
          [09/10/2008 - 16:06:51 | D ] C:\Intel
          [18/07/2010 - 11:34:53 | N | 0] C:\IO.SYS
          [15/08/2010 - 22:50:59 | D ] C:\Kill'em
          [18/07/2010 - 11:34:53 | N | 0] C:\MSDOS.SYS
          [18/02/2011 - 12:54:49 | D ] C:\Nexon
          [26/02/2011 - 13:24:58 | ASH | 3534073856] C:\pagefile.sys
          [21/01/2008 - 03:32:31 | D ] C:\PerfLogs
          [26/02/2011 - 13:36:38 | D ] C:\Program Files
          [24/02/2011 - 19:38:51 | HD ] C:\ProgramData
          [26/02/2011 - 13:55:19 | RSHD ] C:\RECYCLER
          [03/07/2010 - 21:49:39 | SHD ] C:\System Volume Information
          [27/12/2010 - 21:31:03 | D ] C:\Temp
          [26/02/2011 - 14:08:29 | D ] C:\UsbFix
          [26/02/2011 - 14:07:53 | A | 2467] C:\UsbFix.txt
          [26/02/2011 - 13:55:27 | N | 3191440] C:\UsbFix_Upload_Me_PC-DE-ASUS.zip
          [16/08/2010 - 02:54:48 | D ] C:\Users
          [26/02/2011 - 00:48:01 | D ] C:\Windows
          [26/02/2011 - 14:08:29 | SHD ] D:\$RECYCLE.BIN
          [03/07/2010 - 12:43:55 | D ] D:\04375192ce1225df8da690966c
          [19/09/2009 - 14:53:36 | D ] D:\200907
          [19/09/2009 - 14:54:37 | D ] D:\200908
          [19/09/2009 - 14:55:15 | D ] D:\200909
          [19/09/2009 - 14:55:46 | D ] D:\Appareil photo
          [26/02/2011 - 13:55:24 | RASHD ] D:\Autorun.inf
          [24/07/2010 - 14:42:29 | N | 639875979] D:\Flyff_Eu_Fr_Setup.exe
          [25/02/2011 - 20:51:12 | D ] D:\jack
          [20/12/2010 - 22:09:41 | D ] D:\kikiii (COLOW)
          [18/02/2011 - 15:26:58 | D ] D:\Nouveau dossier
          [26/02/2011 - 13:47:34 | D ] D:\Spybot - Search & Destroy
          [03/07/2010 - 21:39:37 | SHD ] D:\System Volume Information
          [02/10/2010 - 16:57:56 | N | 282] D:\VistaOS (C) - Raccourci.lnk
          [24/02/2011 - 15:30:47 | D ] D:\Warcraft III
          [24/02/2011 - 22:40:23 | D ] D:\World of Warcraft
          C:\Autorun.inf -> Vaccin créé par UsbFix (TeamXscript)
          D:\Autorun.inf -> Vaccin créé par UsbFix (TeamXscript)
          il manque quelque chose ?
            Nan c'est bon.
            Alors :
            * Télécharge AD-Remover(de C_XX) sur ton Bureau.
            Déconnecte toi et ferme toutes les applications en cours
            * Double-clique sur l'icône AD-Remover
            * Au menu principal, clique sur Nettoyer
            * Confirme le lancement de l'analyse et laisse l'outil travailler
            * Poste le rapport qui apparait à la fin (il est aussi sauvegardé sous C:\Ad-report-CLEAN.txt )
            1. ==== RAPPORT D'AD-REMOVER 2.0.0.2,E | UNIQUEMENT XP/VISTA/7 =======
              Mis à jour par TeamXscript le 26/02/11
              Contact: AdRemover[DOT]contact[AT]gmail[DOT]com
              Site web: http://www.teamxscript.org
              C:\Program Files\Ad-Remover\main.exe (CLEAN [1]) -> Lancé à 14:43:22 le 26/02/2011, Mode normal
              Microsoft® Windows Vista(TM) Édition Familiale Premium Service Pack 2 (X86)
              ASUS@PC-DE-ASUS (ASUSTeK Computer Inc. F8Vr)
              ============== ACTION(S) ==============
              Dossier supprimé: C:\Users\ASUS\AppData\Roaming\FissaSearch
              Dossier supprimé: C:\Users\ASUS\AppData\Roaming\freeTVRadio
              Dossier supprimé: C:\Users\ASUS\AppData\Roaming\OfferBox
              (!) -- Fichiers temporaires supprimés.
              Clé supprimée: HKCU\Software\OfferBox
              Clé supprimée: HKCU\Software\FissaSearch
              Clé supprimée: HKCU\Software\freeTVRadio
              Clé supprimée: HKCU\Software\Spointer
              Clé supprimée: HKCU\Software\Microsoft\Internet Explorer\SearchScopes\{b41306c6-96d0-442a-bcc4-b0f621e82ce9}
              Clé supprimée: HKCU\Software\Microsoft\Windows\CurrentVersion\App Management\ARPCache\Fissa
              Clé supprimée: HKCU\Software\Microsoft\Windows\CurrentVersion\App Management\ARPCache\{2C8574B5-6935-4FCE-860E-F4E8602378FF}
              Clé supprimée: HKCU\Software\Microsoft\Windows\CurrentVersion\App Management\ARPCache\{38470B46-9BF1-40AE-A588-F6AD6D1C2D42}
              Clé supprimée: HKCU\Software\Microsoft\Windows\CurrentVersion\App Management\ARPCache\Live-Player
              Valeur supprimée: HKCU\Software\Microsoft\Internet Explorer\Toolbar\WebBrowser|{D4027C7F-154A-4066-A1AD-4243D8127440}
              ============== SCAN ADDITIONNEL ==============
              **** Internet Explorer Version [8.0.6001.19019] ****
              HKCU_Main|Default_Page_URL - hxxp://www.microsoft.com/isapi/redir.dll?prd=ie&pver=6&ar=msnhome
              HKCU_Main|Default_Search_URL - hxxp://www.microsoft.com/isapi/redir.dll?prd=ie&ar=iesearch
              HKCU_Main|Search bar - hxxp://go.microsoft.com/fwlink/?linkid=54896
              HKCU_Main|Start Page - hxxp://fr.msn.com/
              HKLM_Main|Default_Page_URL - hxxp://go.microsoft.com/fwlink/?LinkId=54896
              HKLM_Main|Default_Search_URL - hxxp://www.microsoft.com/isapi/redir.dll?prd=ie&ar=iesearch
              HKLM_Main|Search bar - hxxp://search.msn.com/spbasic.htm
              HKLM_Main|Search Page - hxxp://www.microsoft.com/isapi/redir.dll?prd=ie&ar=iesearch
              HKLM_Main|Start Page - hxxp://fr.msn.com/
              HKCU_SearchScopes\{171DEBEB-C3D4-40b7-AC73-056A5EBA4A7E} - "?" (?)
              HKCU_ElevationPolicy\{B00D39C0-C2DE-4A40-80C2-9DC89E457A9B} - C:\Program Files\uTorrent\uTorrent.exe (BitTorrent, Inc.)
              HKLM_ElevationPolicy\{08FF730A-494F-4cba-AA0B-E4F1D44715F9} - C:\Program Files\Norton Internet Security\Engine\17.6.0.32\symerr.exe (x)
              HKLM_ElevationPolicy\{289AC7E0-0AEE-4a7b-913C-709D9803D23E} - C:\ProgramData\NexonEU\NGM\NGM.exe (x)
              HKLM_ElevationPolicy\{70f641fd-9ffc-4d5b-a4dc-962af4ed7999} - C:\Program Files\Internet Explorer\iedw.exe (x)
              HKLM_Extensions\{85d1f590-48f4-11d9-9669-0800200c9a66} - "?" (?)
              BHO\{5C255C8A-E604-49b4-9D64-90988571CECB} (?)
              C:\Program Files\Ad-Remover\Quarantine: 8 Fichier(s)
              C:\Program Files\Ad-Remover\Backup: 15 Fichier(s)
              C:\Ad-Report-CLEAN[1].txt - 26/02/2011 14:43:44 (3105 Octet(s))
              Fin à: 14:44:49, 26/02/2011
              ============== E.O.F ==============
                Hello,
                On va passer un coup de MBAM,
                mais avant on va utiliser un logiciel (rapide) que j'ai l'habitude de faire passer avant MBAM ne serait-ce que pour des remontées à l'auteur.
                * Télécharge RogueKiller sur le bureau
                * Quitte tous les programmes en cours
                * Sous Vista/Seven , clic droit -> lancer en tant qu'administrateur
                * Sinon lance simplement RogueKiller.exe
                * Lorsque demandé, tape 1 et valide
                * Un rapport à dû s'ouvrir (RKreport.txt se trouve également à côté de l'exécutable), donner son contenu à la personne qui vous aide
                * Si le programme a été bloqué, ne pas hésiter a essayer plusieurs fois. Si vraiment cela ne passe pas (ça peut arriver), le renommer en winlogon.exe
                1. RogueKiller V4.0.0 by Tigzy
                  contact at https://www.luanagames.com/index.fr.html
                  mail: tigzyRK<at>gmail<dot>com
                  Feedback: https://www.luanagames.com/index.fr.html
                  Operating System: Windows Vista (6.0.6002 Service Pack 2) 32 bits version
                  Started in : Normal mode
                  User: ASUS [Admin rights]
                  Mode: Scan -- Time : 26/02/2011 14:55:16
                  Bad processes: 0
                  Registry Entries: 0
                  HOSTS File:
                  127.0.0.1 localhost
                  Finished
              2. Contributeur
                Bien.
                MBAM
                * Télécharge Malwarebytes' Anti-Malware
                * Tu auras un tutoriel à ta disposition pour l'installer et l'utiliser correctement.
                * Fais la mise à jour du logiciel (elle se fait normalement à l'installation)
                * Lance une analyse complète en cliquant sur "Exécuter un examen complet"
                * Sélectionne les disques que tu veux analyser et clique sur "Lancer l'examen"
                * L'analyse peut durer un bon moment.....
                * Une fois l'analyse terminée, clique sur "OK" puis sur "Afficher les résultats"
                * Vérifie que tout est bien coché et clique sur "Supprimer la sélection" => et ensuite sur "OK"
                * Il se pourrait que certains fichiers devront être supprimés au redémarrage du PC... Fais le en cliquant sur "oui" à la question posée
                * Un rapport va s'ouvrir dans le bloc note... Fais un copié/collé du rapport dans ta prochaine réponse sur le forum
                1. Malwarebytes' Anti-Malware 1.50.1.1100
                  www.malwarebytes.org
                  Version de la base de données: 5878
                  Windows 6.0.6002 Service Pack 2
                  26/02/2011 16:04:01
                  mbam-log-2011-02-26 (16-04-01).txt
                  Type d'examen: Examen complet (C:\|D:\|E:\|F:\|)
                  Elément(s) analysé(s): 252896
                  Temps écoulé: 37 minute(s), 34 seconde(s)
                  Clé(s) du Registre infectée(s): 0
                  Valeur(s) du Registre infectée(s): 0
                  Elément(s) de données du Registre infecté(s): 0
                  Dossier(s) infecté(s): 0
                  Fichier(s) infecté(s): 0
                  1. oui grand merci mais toujour un probleme le parefeu qui ne veut pas s'activé ;'(
                    je fait faire un nouveau thread
                      /!\ Ne pas utiliser ce logiciel en dehors du cadre de cette désinfection : DANGEREUX /!\
                      tutoriel combofix
                      ▶ Fais un clic droit sur le lien ci dessous, choisi "Enregistrer la cible du lien sous", comme destination : ton Bureau, change son nom (ton_pseudo.exe par exemple) :
                      ▶ /!\ Déconnecte-toi du net et ARRÊTE TES LOGICIELS DE PROTECTION /!\
                      ▶ Double-clique sur ComboFix.exe
                      Un "pop-up" va apparaître qui dit que ComboFix est utilisé à vos risques et avec aucune garantie... Clique sur oui pour accepter
                      ▶ ▶ SURTOUT INSTALLES LA CONSOLE DE RÉCUPÉRATION
                      (si il te propose de l'installer remets internet)
                      ▶ Mets-le en langue française F
                      ▶ Tape sur la touche 1 (Yes) pour démarrer le scan.
                      ▶ Ne touche à rien(souris, clavier) tant que le scan n'est pas terminé, car tu risques de planter ton PC
                      ▶En fin de scan, il est possible que ComboFix ait besoin de redémarrer le PC pour finaliser la désinfection, laisse-le faire.
                      ▶ Une fois le scan achevé, un rapport va s'afficher : Poste son contenu
                      ▶ ▶ /!\ Réactive la protection en temps réel de ton antivirus et de ton antispyware avant de te reconnecter à Internet. /!\
                      ▶ Note : Le rapport se trouve également là : C:\ComboFix.txt
                      1. OUFFF ;'(((( serieu tu ma fait super peur lors du redémarrage je n'ai pas pu ouvrir IE !!!voila le scan :
                        ComboFix 11-02-25.02 - ASUS 26/02/2011 21:26:21.1.2 - x86
                        Microsoft® Windows Vista(TM) Édition Familiale Premium 6.0.6002.2.1252.33.1036.18.3070.1811 [GMT 1:00]
                        Lancé depuis: c:\users\ASUS\Desktop\moncompte.exe
                        SP: Windows Defender *Disabled/Outdated* {D68DDC3A-831F-4fae-9E44-DA132C1ACF46}
                        * Un nouveau point de restauration a été créé
                        (((((((((((((((((((((((((((((((((((( Autres suppressions ))))))))))))))))))))))))))))))))))))))))))))))))
                        c:\users\ASUS\AppData\Local\Temp\A488.tmp
                        c:\users\ASUS\AppData\Roaming\ACD Systems\ACDSee\ImageDB.ddf
                        ((((((((((((((((((((((((((((( Fichiers créés du 2011-01-26 au 2011-02-26 ))))))))))))))))))))))))))))))))))))
                        2011-02-26 18:45 . 2011-02-26 18:45 -------- d-----w- c:\users\ASUS\AppData\Roaming\TeamViewer
                        2011-02-26 13:43 . 2011-02-26 13:43 -------- d-----w- c:\program files\Ad-Remover
                        2011-02-26 12:36 . 2011-02-26 18:35 -------- d-----w- c:\program files\ZHPDiag
                        2011-02-26 12:27 . 2011-02-26 13:08 -------- d-----w- C:\UsbFix
                        2011-02-26 11:56 . 2011-02-26 11:56 -------- d-----w- c:\program files\Trend Micro
                        2011-02-26 10:46 . 2009-06-30 09:37 28552 ----a-w- c:\windows\system32\drivers\pavboot.sys
                        2011-02-26 10:46 . 2011-02-26 10:46 -------- d-----w- c:\program files\Panda Security
                        2011-02-25 23:14 . 2011-02-25 23:14 -------- d-----w- c:\program files\Common Files\Java
                        2011-02-24 18:38 . 2011-02-24 18:38 -------- d-----w- c:\programdata\Blizzard Entertainment
                        2011-02-18 13:44 . 2011-02-25 00:33 -------- d-----w- c:\users\ASUS\fulltilt
                        2011-02-18 13:22 . 2011-02-18 13:22 -------- d-----w- c:\programdata\ATI
                        2011-02-18 13:22 . 2011-02-18 13:22 -------- d-----w- c:\program files\ATI Stream
                        2011-02-18 13:18 . 2011-02-18 13:18 -------- d-----w- C:\ATI
                        2011-02-18 13:07 . 2011-02-18 13:07 -------- d-----w- C:\AMD
                        2011-02-18 11:45 . 2011-02-18 11:54 -------- d-----w- C:\Nexon
                        2011-02-17 12:58 . 2011-02-17 12:58 -------- d-----w- c:\users\ASUS\AppData\Local\cache
                        2011-02-17 12:53 . 2011-02-25 00:07 -------- d-----w- c:\users\ASUS\AppData\Local\FullTiltPoker.fr
                        2011-02-12 15:00 . 2011-02-12 15:00 -------- d-----w- c:\program files\Feedback Tool
                        2011-02-10 21:14 . 2011-02-10 21:14 -------- d-----w- c:\program files\Defraggler
                        2011-02-03 20:29 . 2011-02-18 14:11 -------- d-----w- c:\programdata\NexonUS
                        2011-02-03 18:49 . 2011-02-14 13:48 -------- d-----w- c:\users\ASUS\AppData\Local\PMB Files
                        2011-02-03 18:49 . 2011-02-14 11:44 -------- d-----w- c:\programdata\PMB Files
                        2011-02-03 18:49 . 2011-02-03 18:49 -------- d-----w- c:\program files\Pando Networks
                        2011-02-03 18:37 . 2011-02-18 11:45 235 ----a-w- c:\windows\system32\nxEuUninstall.bat
                        2011-01-30 13:57 . 2011-01-30 13:57 103864 ----a-w- c:\program files\Internet Explorer\PLUGINS\nppdf32.dll
                        2011-01-28 16:07 . 2011-01-28 16:07 84621672 ----a-w- c:\program files\Common Files\Windows Live\.cache\wlc9A2.tmp
                        (((((((((((((((((((((((((((((((((( Compte-rendu de Find3M ))))))))))))))))))))))))))))))))))))))))))))))))
                        2011-02-26 13:08 . 2011-02-26 12:55 3191122 ----a-w- C:\UsbFix_Upload_Me_PC-DE-ASUS.zip
                        2011-02-18 11:45 . 2010-07-25 23:21 446464 ----a-w- c:\windows\NEXON_EU_DownloaderUpdater.exe
                        2011-02-12 15:01 . 2011-02-12 15:01 4096 ----a-w- c:\windows\system32\drivers\fr-FR\dxgkrnl.sys.mui
                        2011-02-02 20:40 . 2010-07-20 13:46 472808 ----a-w- c:\windows\system32\deployJava1.dll
                        2011-01-26 23:36 . 2011-01-26 23:36 7566848 ----a-w- c:\windows\system32\drivers\atikmdag.sys
                        2011-01-26 23:00 . 2011-01-26 23:00 143360 ----a-w- c:\windows\system32\atiapfxx.exe
                        2011-01-26 23:00 . 2011-01-26 23:00 596480 ----a-w- c:\windows\system32\aticfx32.dll
                        2011-01-26 22:59 . 2011-01-26 22:59 17204736 ----a-w- c:\windows\system32\atioglxx.dll
                        2011-01-26 22:56 . 2011-01-26 22:56 462848 ----a-w- c:\windows\system32\ATIDEMGX.dll
                        2011-01-26 22:55 . 2011-01-26 22:55 393216 ----a-w- c:\windows\system32\atieclxx.exe
                        2011-01-26 22:55 . 2011-01-26 22:55 176128 ----a-w- c:\windows\system32\atiesrxx.exe
                        2011-01-26 22:54 . 2008-04-22 14:05 159744 ----a-w- c:\windows\system32\atitmmxx.dll
                        2011-01-26 22:53 . 2008-04-22 14:04 356352 ----a-w- c:\windows\system32\atipdlxx.dll
                        2011-01-26 22:53 . 2011-01-26 22:53 278528 ----a-w- c:\windows\system32\Oemdspif.dll
                        2011-01-26 22:53 . 2011-01-26 22:53 15872 ----a-w- c:\windows\system32\atimuixx.dll
                        2011-01-26 22:53 . 2008-04-22 14:04 43520 ----a-w- c:\windows\system32\ati2edxx.dll
                        2011-01-26 22:49 . 2011-01-26 22:49 4105728 ----a-w- c:\windows\system32\atidxx32.dll
                        2011-01-26 22:32 . 2011-01-26 22:32 1912832 ----a-w- c:\windows\system32\atiumdmv.dll
                        2011-01-26 22:28 . 2008-04-22 13:50 4170752 ----a-w- c:\windows\system32\atiumdag.dll
                        2011-01-26 22:27 . 2011-01-26 22:27 46080 ----a-w- c:\windows\system32\aticalrt.dll
                        2011-01-26 22:27 . 2011-01-26 22:27 44032 ----a-w- c:\windows\system32\aticalcl.dll
                        2011-01-26 22:25 . 2011-01-26 22:25 5580800 ----a-w- c:\windows\system32\aticaldd.dll
                        2011-01-26 22:24 . 2008-04-22 13:35 3463680 ----a-w- c:\windows\system32\atiumdva.dll
                        2011-01-26 22:20 . 2011-01-26 22:20 52736 ----a-w- c:\windows\system32\coinst.dll
                        2011-01-26 22:14 . 2011-01-26 22:14 249856 ----a-w- c:\windows\system32\atiadlxx.dll
                        2011-01-26 22:13 . 2011-01-26 22:13 12800 ----a-w- c:\windows\system32\atiglpxx.dll
                        2011-01-26 22:13 . 2011-01-26 22:13 32768 ----a-w- c:\windows\system32\atigktxx.dll
                        2011-01-26 22:13 . 2011-01-26 22:13 238592 ----a-w- c:\windows\system32\drivers\atikmpag.sys
                        2011-01-26 22:12 . 2011-01-26 22:12 30720 ----a-w- c:\windows\system32\atiuxpag.dll
                        2011-01-26 22:12 . 2011-01-26 22:12 28672 ----a-w- c:\windows\system32\atiu9pag.dll
                        2011-01-26 22:11 . 2011-01-26 22:11 23040 ----a-w- c:\windows\system32\atitmpxx.dll
                        2011-01-26 22:11 . 2011-01-26 22:11 53248 ----a-w- c:\windows\system32\drivers\ati2erec.dll
                        2011-01-26 22:08 . 2011-01-26 22:08 52736 ----a-w- c:\windows\system32\atimpc32.dll
                        2011-01-26 22:08 . 2011-01-26 22:08 52736 ----a-w- c:\windows\system32\amdpcom32.dll
                        2010-12-28 15:55 . 2011-01-12 12:50 413696 ----a-w- c:\windows\system32\odbc32.dll
                        2010-12-20 17:09 . 2010-07-10 22:48 38224 ----a-w- c:\windows\system32\drivers\mbamswissarmy.sys
                        2010-12-20 17:08 . 2010-07-10 22:47 20952 ----a-w- c:\windows\system32\drivers\mbam.sys
                        2010-12-14 14:49 . 2011-01-12 12:50 1169408 ----a-w- c:\windows\system32\sdclt.exe
                        2010-12-07 11:16 . 2010-12-07 11:16 51200 ----a-w- c:\windows\system32\OpenCL.dll
                        2008-07-02 02:28 . 2008-07-02 02:28 61440 ----a-w- c:\program files\Common Files\CPInstallAction.dll
                        ((((((((((((((((((((((((((((((((( Points de chargement Reg ))))))))))))))))))))))))))))))))))))))))))))))))
                        *Note* les éléments vides & les éléments initiaux légitimes ne sont pas listés
                        REGEDIT4
                        [HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Run]
                        "LightScribe Control Panel"="c:\program files\Common Files\LightScribe\LightScribeControlPanel.exe" [2008-06-09 2363392]
                        "uTorrent"="c:\program files\uTorrent\uTorrent.exe" [2010-12-14 395640]
                        "msnmsgr"="c:\program files\Windows Live\Messenger\msnmsgr.exe" [2010-04-16 3872080]
                        "WMPNSCFG"="c:\program files\Windows Media Player\WMPNSCFG.exe" [2008-01-21 202240]
                        [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run]
                        "ATKOSD2"="c:\program files\ATKOSD2\ATKOSD2.exe" [2008-01-23 7766016]
                        "RtHDVCpl"="RtHDVCpl.exe" [2008-02-13 4915200]
                        "CognizanceTS"="c:\progra~1\ASUSSE~1\ASUSSE~1\Bin\ASTSVCC.dll" [2003-12-21 17920]
                        "SynTPEnh"="c:\program files\Synaptics\SynTP\SynTPEnh.exe" [2007-12-06 1029416]
                        "ASUS Camera ScreenSaver"="c:\windows\ASScrProlog.exe" [2008-10-09 39480]
                        "ASUS Screen Saver Protector"="c:\windows\ASScrPro.exe" [2008-10-09 33136]
                        "StartCCC"="c:\program files\ATI Technologies\ATI.ACE\Core-Static\CLIStart.exe" [2011-01-26 336384]
                        "SunJavaUpdateSched"="c:\program files\Common Files\Java\Java Update\jusched.exe" [2010-10-29 249064]
                        [HKEY_USERS\.DEFAULT\Software\Microsoft\Windows\CurrentVersion\Run]
                        "Sidebar"="c:\program files\Windows Sidebar\sidebar.exe" [2009-04-11 1233920]
                        c:\programdata\Microsoft\Windows\Start Menu\Programs\Startup\
                        Bluetooth.lnk - c:\program files\WIDCOMM\Bluetooth Software\BTTray.exe [2008-4-10 752168]
                        [HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\policies\system]
                        "EnableUIADesktopToggle"= 0 (0x0)
                        [HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\drivers32]
                        "aux"=wdmaud.drv
                        [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\Windows Defender]
                        %ProgramFiles%\Windows Defender\MSASCui.exe -hide [X]
                        [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\Adobe ARM]
                        2010-09-20 21:07 932288 ----a-r- c:\program files\Common Files\Adobe\ARM\1.0\AdobeARM.exe
                        [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\Adobe Reader Speed Launcher]
                        2011-01-31 08:44 35760 ----a-w- c:\program files\Adobe\Reader 9.0\Reader\reader_sl.exe
                        [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\msnmsgr]
                        2010-04-16 21:12 3872080 ----a-w- c:\program files\Windows Live\Messenger\msnmsgr.exe
                        [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\Skype]
                        2009-10-09 12:11 25623336 ----a-r- c:\program files\Skype\Phone\Skype.exe
                        [HKEY_LOCAL_MACHINE\software\microsoft\security center\Monitoring]
                        "DisableMonitoring"=dword:00000001
                        [HKEY_LOCAL_MACHINE\software\microsoft\security center\Monitoring\SymantecAntiVirus]
                        [HKEY_LOCAL_MACHINE\software\microsoft\security center\Monitoring\SymantecFirewall]
                        R2 clr_optimization_v4.0.30319_32;Microsoft .NET Framework NGEN v4.0.30319_X86;c:\windows\Microsoft.NET\Framework\v4.0.30319\mscorsvw.exe [2010-03-18 130384]
                        R3 btwl2cap;Bluetooth L2CAP Service;c:\windows\system32\DRIVERS\btwl2cap.sys [2008-01-29 29736]
                        R3 GarenaPEngine;GarenaPEngine;c:\users\ASUS\AppData\Local\Temp\CAL48A8.tmp [x]
                        R3 GGSAFERDriver;GGSAFER Driver;c:\program files\Garena\safedrv.sys [x]
                        R3 npggsvc;nProtect GameGuard Service;c:\windows\system32\GameMon.des [2010-06-17 3890920]
                        R3 WPFFontCache_v0400;Windows Presentation Foundation Font Cache 4.0.0.0;c:\windows\Microsoft.NET\Framework\v4.0.30319\WPF\WPFFontCache_v0400.exe [2010-03-18 753504]
                        S0 lullaby;lullaby;c:\windows\system32\DRIVERS\lullaby.sys [2008-05-29 15416]
                        S0 pavboot;pavboot;c:\windows\system32\drivers\pavboot.sys [2009-06-30 28552]
                        S0 sptd;sptd;c:\windows\System32\Drivers\sptd.sys [2010-08-08 691696]
                        S2 AMD External Events Utility;AMD External Events Utility;c:\windows\system32\atiesrxx.exe [2011-01-26 176128]
                        S2 ASBroker;Logon Session Broker;c:\windows\System32\svchost.exe [2008-01-21 21504]
                        S2 ASChannel;Local Communication Channel;c:\windows\System32\svchost.exe [2008-01-21 21504]
                        S3 amdkmdag;amdkmdag;c:\windows\system32\DRIVERS\atikmdag.sys [2011-01-26 7566848]
                        S3 amdkmdap;amdkmdap;c:\windows\system32\DRIVERS\atikmpag.sys [2011-01-26 238592]
                        S3 itecir;ITECIR Infrared Receiver;c:\windows\system32\DRIVERS\itecir.sys [2007-12-19 54784]
                        [HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\svchost]
                        bthsvcs REG_MULTI_SZ BthServ
                        Cognizance REG_MULTI_SZ ASBroker ASChannel
                        LocalServiceAndNoImpersonation REG_MULTI_SZ FontCache
                        [HKEY_LOCAL_MACHINE\software\microsoft\active setup\installed components\{10880D85-AAD9-4558-ABDC-2AB1552D831F}]
                        2008-06-09 17:14 451872 ----a-w- c:\program files\Common Files\LightScribe\LSRunOnce.exe
                        ------- Examen supplémentaire -------
                        IE: E&xport to Microsoft Excel - c:\progra~1\MICROS~2\Office12\EXCEL.EXE/3000
                        - - - - ORPHELINS SUPPRIMES - - - -
                        HKLM-Run-DivXUpdate - c:\program files\DivX\DivX Update\DivXUpdate.exe
                        HKLM-Run-jsafesurf - c:\windows\Help32\safesurf.exe
                        AddRemove-DivX Setup.divx.com - c:\programdata\DivX\Setup\DivXSetup.exe
                        AddRemove-{34785AD0-6276-11DF-A08A-0800200C9A66} - c:\users\ASUS\uninstall.exe
                        catchme 0.3.1398 W2K/XP/Vista - rootkit/stealth malware detector by Gmer, http://www.gmer.net
                        Rootkit scan 2011-02-26 21:34
                        Windows 6.0.6002 Service Pack 2 NTFS
                        Recherche de processus cachés ...
                        Recherche d'éléments en démarrage automatique cachés ...
                        Recherche de fichiers cachés ...
                        Scan terminé avec succès
                        Fichiers cachés: 0
                        [HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\GarenaPEngine]
                        "ImagePath"="\??\c:\users\ASUS\AppData\Local\Temp\CAL48A8.tmp"
                        [HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\npggsvc]
                        "ImagePath"="c:\windows\system32\GameMon.des -service"
                        --------------------- CLES DE REGISTRE BLOQUEES ---------------------
                        [HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\Class\{4D36E96D-E325-11CE-BFC1-08002BE10318}\0000\AllUserSettings]
                        @Denied: (A) (Users)
                        @Denied: (A) (Everyone)
                        @Allowed: (B 1 2 3 4 5) (S-1-5-20)
                        "BlindDial"=dword:00000000
                        "MSCurrentCountry"=dword:000000b5
                        [HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\Class\{4D36E96D-E325-11CE-BFC1-08002BE10318}\0001\AllUserSettings]
                        --------------------- DLLs chargées dans les processus actifs ---------------------
                        - - - - - - - > 'Explorer.exe'(1308)
                        c:\windows\system32\APSHook.dll
                        c:\program files\ASUS Security Center\ASUS Security Protect Manager\Bin\ItClient.dll
                        c:\windows\system32\btmmhook.dll
                        ------------------------ Autres processus actifs ------------------------
                        c:\program files\ATKGFNEX\GFNEXSrv.exe
                        c:\windows\system32\WLANExt.exe
                        c:\windows\system32\agrsmsvc.exe
                        c:\program files\WIDCOMM\Bluetooth Software\bin\btwdins.exe
                        c:\program files\Common Files\LightScribe\LSSrvc.exe
                        c:\program files\asus\NB Probe\SPM\spmgr.exe
                        c:\windows\servicing\TrustedInstaller.exe
                        c:\program files\ASUS\SmartLogon\sensorsrv.exe
                        c:\windows\system32\conime.exe
                        c:\windows\RtHDVCpl.exe
                        c:\program files\ACD Systems\DevDetect\DevDetect.exe
                        c:\program files\ATI Technologies\ATI.ACE\Core-Static\MOM.exe
                        c:\program files\ASUS Security Center\ASUS Security Protect Manager\Bin\AsGHost.exe
                        c:\program files\Windows Media Player\wmpnetwk.exe
                        c:\windows\system32\wbem\unsecapp.exe
                        c:\\?\c:\windows\system32\wbem\WMIADAP.EXE
                        Heure de fin: 2011-02-26 21:37:04 - La machine a redémarré
                        ComboFix-quarantined-files.txt 2011-02-26 20:37
                        Avant-CF: 26 283 044 864 octets libres
                        Après-CF: 26 078 208 000 octets libres
                        - - End Of File - - D6011521BFFC8338045E57B3AA2D7AF3
                          Toujours des problèmes ?
                          1. le pc est plus rapide mais la parefeu ne marche toujours pas
                        2. oui c'est bien le parefeu windows je vais suivre la méthode la
                          1. le service parefeu n'est pas en cour d'exécution ... le probleme persiste je ne peux meme pas
                            accéder au parametre .
                        3. salut
                          Il faudrait peut être le réactiver via les services Windows.
                          cmd ---->services.msc
                            Si tu fais Démarrer/Executer
                            Tapes services.msc
                            Cherche la ligne Pare-Feu Windows
                            Double clique dessus et passe son type de démarrage en automatique
                            • 1
                            • 2
