Expulsé par punbuster.PnkBstrB.exe driverfail
Salutations
Alors voila depuis quelques jours, lorsque je me connecte en ligne aux servers de jeux avec Punkbuster, je recois le message suivant avant de me faire expulsé.
"Server disconnected :punkbuster kicked player (playername)
RESTRICTION; service communication failure PnkBstrB.exe driver failure (PnkBstrK.sys) ffab"
J'ai éxécuté le pbsvc.exe et voici le rapport .
Checking user is Administrator OK
Checking Administrator privileges OK
Opening Service Control Manager OK
Searching for PnkBstrA Found - OK
Extracting PnkBstrA service OK
Verifying service authenticity OK
Installing PunkBuster service OK
Installed at "C:\Windows\system32\PnkBstrA.exe"
Checking PunkBuster service status STOPPED
Starting PunkBuster service OK
Adding firewall rule for PnkBstrA OK
Adding firewall rule for PnkBstrB OK
Installation Finished.
Please click "Next" to test the PunkBuster services.
Starting PunkBuster Service Tests (v0.987) (10/28/10 07:11:14)
Checking OS
Windows NT 6.0 (build 6002, Service Pack 2) 32-bit
Checking PnkBstrA service status RUNNING
Checking PnkBstrA Version OK (1032)
Extracting "PnkBstrB.exe" to:
"C:\Users\Maximilien\AppData\Roaming\PnkBstrB.exe"
OK
Checking firewall settings OFF
Is PnkBstrA explicitly allowed?
C:\Windows\system32\PnkBstrA.exe YES
Is PnkBstrB explicitly allowed?
C:\Windows\system32\PnkBstrB.exe YES
Checking if PnkBstrB is running RUNNING
Manually stopping PnkBstrB STOPPED
Getting port for PnkBstrA OK (44301)
Opening socket for packet send OK
Sending version packet to PnkBstrA SENT
Receiving version from PnkBstrA OK
Received 6 bytes from 127.0.0.1:44301
Response = 8268 (ms) Version = v1032
Getting PnkBstrB install instance OK
Sending start packet to PnkBstrA SENT
Waiting for packet from PnkBstrA OK
Received 3 bytes from 127.0.0.1:44301
Response = 15351 (ms) PnkBstrB started.
Load SUCCESSFUL.
Watching for PnkBstrB instance change (22) CHANGED (23)
Getting port for PnkBstrB OK (45301)
Sending version packet to PnkBstrB SENT
Receiving version from PnkBstrB OK
Received 5 bytes from 127.0.0.1:45301
Response = 3011 (ms) Version = 2110
Checking PnkBstrK driver status NOT FOUND
Extracting new PnkBstrK to:
"C:\Users\Maximilien\AppData\Roaming\PnkBstrK.sys"
OK
Sending load packet to PnkBstrB SENT
Checking PnkBstrK driver status RUNNING
Stopping PnkBstrK STOPPED
Deleting PnkBstrK OK
Checking PnkBstrK driver status DELETED
Removing test PnkBstrB file OK
Tests finished.
Avant tout commentaires inutiles , je tiens a préciser que:
_mon punkbuster est a jour ( manuellement)
_mon jeu ( Call of Duty 1) est patché, a jour et fonctionnel sur les serveurs sans punkbuster.
_Mes pare feux ( windows vista et le bouclier réseau d'Avast 5) autorisent tout les 2 punkbuster A et B
J'ai essayé:
_de re-installé Call of duty
_de réinstallé Punkbuster
_de désactiver TOUTES mes défenses(par feu, windows defender, avast)
_de démarrer Call of duty en tant qu'administrateur
Rien n'y fait. J'ai posté un ticket sur evenbalance.com, le site de punkbuster, mais pas de réponses....
J'ajoute que une fois sur 10 le probleme n'apparait pas, mais reviens a la connection suivante .... grand mystère pour moi.
Merci de votre aide
Cordialement.
  1. Slt,
    t as essayer le patch punkbuster.
    c'est un peu de mémoire, mais ce que je faisait avant.
    le liens a était vite cherché sur google
    https://forums-fr.ubisoft.com/eve/forums/a/tpc/f/771102505/m/238103505
    Regarde un peut si t en trouve un bien....
    bn route
    1. Non apparemment ton patch est seulement utilisable sur Ravenshield 3.
      Par contre si un tel patch existe sur Call of Duty, il m'intéresse.
      Mais désolé sa ne marche pas ^^'
    2. slt ca c'est celui du site officiel c'est celui la que tu as pris?
      verif la version et reinstalle si t as pas deja fait:
      http://www.evenbalance.com/
    3. Ah sinon regarde sur le forum meme bleme:
      https://forums.commentcamarche.net/forum/affich-3306501-call-of-duty-probleme-punkbuster
      bn chance tiens au jus (ps j ai pas ce jeux mais j avais galérer avec d autre jeux, donc regarde bien j ai pas tester....)
      et si pas mis a jour mais c'a a plutot l air d'etre le lien du dessus qui pourait correspondre a ton probleme tu peut essayer ca (si pas deja fait bien sur):
      http://fr-techsupport.ea.com/index.php?showtopic=71BAABO91
      bn chance!
    4. C'est sympa de vouloir aider mais, comme je l'ai dis dans mon post intial, TOUT EST A JOUR, pas la peine de me dire met a jour si, mais a jour pb, etc etc etc
      et je n'utilise pas steam. Seulement xfire.
