<java>wight affiche pas
j'ai essayé ce prg,dans le résultat weight affiche pas
j'ai une erreur suivant
The method weight() is undefined for the type SpecialCube
at Essaie.Rectangle.main(Rectangle.java:9)
mon prg est suivant:
public class Cube1
 int length;
 int breadth;
 int height;
 public int getVolume()
	 return (length*breadth*height);
 Cube1()
	 this(10,10);
	 System.out.println("Finished with default constructor");
 Cube1(int l,int b)
	 this(l,b,10);
	 System.out.println("Finished with parameterized constructor having 2 params");
 Cube1(int l,int b,int h)
	 length=l;
	 breadth=b;
	 height=h;
	 System.out.println("Finished with parameterized constructor having 3 params");
package Essaie;
public class SpecialCube extends Cube1
 int weight;
 SpecialCube()
	 super();
	 weight=10;
 SpecialCube(int l,int b)
	 this(l,b,10);
	 System.out.println("Finished with parameterized constructor having 2 params of SpecialCube");
 SpecialCube(int l, int b,int h)
	 super(l,b,h);
	 weight=20;
	 System.out.println("Finished with parameterized constructor having 3 params of SpecialCube");
package Essaie;
public class Rectangle
public static void main(String[]args)
	SpecialCube specialObj1=new SpecialCube();
	SpecialCube specialObj2=new SpecialCube(10,20);
	System.out.println("volume of SpecialCube1 is:"+specialObj1.getVolume());
	System.out.println("weight of SpecialCube1 is:"+specialObj1.weight());
	System.out.println("volume of SpecialCube2 is:"+specialObj2.getVolume());
	System.out.println("weight of SpecialCube2 is:"+specialObj2.weight());
aidez moi s'il vous plait
  1. je pense que tu dois faire un .get(weight) car weight est un attribut de special cuble
    1. non, j'attends un résultat comme ceci:
      volume of SpecialCube1 is:1000
      weight of SpecialCube1 is:10
      volume of SpecialCube1 is:2000
      weight of SpecialCube1 is:20
      1. je suis d'accord mais tu n'a pas ecrit ta méthode getWeigt() faudrait rajouter dans specialcube :
        public int getWeight(){
        return weight;
        et ensuite remplacer :
        System.out.println("weight of SpecialCube1 is:"+specialObj1.getWeight());
        System.out.println("weight of SpecialCube2 is:"+specialObj2.getWeight());
        1. merci beaucoup,j'ai corrigé mon erreur
