Probleme gnash
Bonjour, je suis débutant avec linux et j'ai un gros probleme avec gnash j'essaye de l'installais .. mais plein de probleme j'en ai marre :(
Bon je vous explique un peu le truc : voilà ce que donne le ./configure
ERROR: No KDE development package installed!
To disable the KDE gui,
reconfigure using --enable-gui=<list-of-guis>
and omit kde from the list.
When the option --enable-gui=... is omitted,
the default is the same of --enable-gui=kde,gtk
To be able to build the kde gui,
install the KDE development environment from https://kde.org/
or .deb users: apt-get install kdelibs-dev
or .rpm users: yum install <something-else>.
JPEG flags are: default include path
JPEG libs are: -L/usr/lib32 -ljpeg
PNG flags are: default include path
PNG libs are: -lpng12
Gstreamer flags are: -pthread -I/usr/include/gstreamer-0.10 -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -I/usr/include/libxml2
Gstreamer libs are: -lgstreamer-0.10 -lgobject-2.0 -lgmodule-2.0 -ldl -lgthread-2.0 -lxml2 -lglib-2.0
POSIX Threads flags are: -pthread
POSIX Threads lib is: -lpthread
CURL flags are: default include path
CURL libs are: -lcurl
AGG Pixel format is: all
AGG flags are: -I/usr/include/agg2
AGG libs are: -lagg_pic -lagg_pic
ERROR: No BOOST development package installed!
Install it from https://www.boost.org/
or .deb users: apt-get install libboost-dev libboost-thread-dev
or .rpm users: yum install boost-devel
WARNING: You need to have the Ming development and utilities packages
installed to run most of the tests in Gnash testsuite.
Install it from http://www.libming.org
or .deb users: apt-get install libming-dev
MTASC is /usr/bin/mtasc
MTASC CLASSPATH is /usr/share/ocaml/mtasc/std
SWFMILL is /usr/local/bin/swfmill
WARNING: You need to have 'swfc' from SWFTools installed
to run some of the tests in Gnash testsuite.
You can install it from http://www.swftools.org/
PYTHON is /usr/bin/python
Z flags are: default include path
Z libs are: -lz
FreeType flags are: -I/usr/local/include/freetype2 -I/usr/local/include
FreeType libs are: -L/usr/local/lib -lfreetype -lz
Fontconfig flags are: default include path
Fontconfig libs are: -L/usr/lib32 -lfontconfig
configure: error: Please install required packages
j'ai commencer par installer manuellement celui là ... bon après avoir galéré pour récupéré les packages qu'il avais besoin j'ai fini par l'installer mais il ne le reconnais toujours pas ... je commence légèrement perdre patience .. depuis 14h j'installe des package .. esque vous auriez une solution .. parce que la TT ou un tuto .. ( je suis débutant en linux.. )
Z libs are: -lz
Configuration: Linux Debian Mozilla
8 réponses
Contributeur"ftp.debian.fr", de mémoire. Tout simplement. Et même sur google ça se trouve.
Suffit d'y ajouter "etch" dans sources.list, de faire aptitude update, aptitude dist-upgrade, et ta Debian est à jour ^^ -
# deb http://ftp.fr.debian.org/debian/ etch main
deb-src http://ftp.fr.debian.org/debian/ etch main
deb https://www.debian.org/security/ etch/updates main
deb-src https://www.debian.org/security/ etch/updates main
# Source debian woody standard
deb http://ftp.fr.debian.org/debian/ stable main non-free contrib
deb http://non-us.debian.org/debian-non-US stable/non-US main contrib non-free
# Mises a jour de securite
deb https://www.debian.org/security/ stable/updates main contrib non-free
# Source officielle SE3
deb ftp://193.49.66.139/debian woody se3
# Backports pour Debian Woody
deb http://www.backports.org/debian stable acl
deb http://www.backports.org/debian stable kernel-2.6
voilà la mienne que j'ai completer par un post ancien mais sa ne marche pas :( ps : j'ai pris sa au piff
juste pour tester quand je veux telecharger un programe voilà ce que sa fait :
NaVeT:/home/navet# apt-get install gnash
Lecture des listes de paquets... Fait
Construction de l'arbre des dépendances... Fait
W: Impossible de localiser la liste des paquets sources http://non-us.debian.org stable/non-US/main Packages (/var/lib/apt/lists/non-us.debian.org_debian-non-US_dists_stable_non-US_main_binary-amd64_Packages) - stat (2 Aucun fichier ou répertoire de ce type)
W: Impossible de localiser la liste des paquets sources http://non-us.debian.org stable/non-US/contrib Packages (/var/lib/apt/lists/non-us.debian.org_debian-non-US_dists_stable_non-US_contrib_binary-amd64_Packages) - stat (2 Aucun fichier ou répertoire de ce type)
W: Impossible de localiser la liste des paquets sources http://non-us.debian.org stable/non-US/non-free Packages (/var/lib/apt/lists/non-us.debian.org_debian-non-US_dists_stable_non-US_non-free_binary-amd64_Packages) - stat (2 Aucun fichier ou répertoire de ce type)
W: Impossible de localiser la liste des paquets sources ftp://193.49.66.139 woody/se3 Packages (/var/lib/apt/lists/193.49.66.139_debian_dists_woody_se3_binary-amd64_Packages) - stat (2 Aucun fichier ou répertoire de ce type)
W: Impossible de localiser la liste des paquets sources https://backports.debian.org/ stable/acl Packages (/var/lib/apt/lists/www.backports.org_debian_dists_stable_acl_binary-amd64_Packages) - stat (2 Aucun fichier ou répertoire de ce type)
W: Impossible de localiser la liste des paquets sources https://backports.debian.org/ stable/kernel-2.6 Packages (/var/lib/apt/lists/www.backports.org_debian_dists_stable_kernel-2.6_binary-amd64_Packages) - stat (2 Aucun fichier ou répertoire de ce type)
W: Vous pouvez lancer « apt-get update » pour corriger ces problèmes.
E: Impossible de trouver le paquet gnash
ps : je les ai update -
très bien je me suis renseigner j'ai modifier ma source.liste, mais quelqu'un aurait il une bonne source.liste bien complete a me donner car =D svp !!
ContributeurIl te faut configurer tes dépots.
Une recherche sur google devrait t'apporter la lumière :)
mais sa ne règle ne rien mon probleme ... car je l'avais déjà ce fichier :( !! et le reste et expliquer au dessus ..
^^ je débute sous linux .. j'avais entendu parler de "depot" mais je ne m'étais jammais vraiment renseigner dessus merci pour le lien =D
ContributeurPourquoi tu n'as pas essayé avec aptitude?
ContributeurSalut,
essaie ceci en root :apt-get install gnash
