Probleme pc lent + cid
j'ai mon pc de plus en plus lent (tres lent même) plus des problemes de pub cid. j'ai fait un scan avec bitfender voici le rapport et merci de votre aide.
BitDefender Online Scanner
Scan report generated at: Fri, Mar 07, 2008 - 18:11:58
Scan path: C:\;E:\;F:\;G:\;H:\;I:\;
Statistics
Time
01:11:34
Files
277072
Folders
9744
Boot Sectors
3
Archives
7656
Packed Files
9998
Results
Identified Viruses
11
Infected Files
29
Suspect Files
Warnings
Disinfected
Deleted Files
29
Engines Info
Virus Definitions
986099
Engine build
AVCORE v1.0 (build 2422) (i386) (Sep 25 2007 08:26:36)
Scan plugins
16
Archive plugins
41
Unpack plugins
7
E-mail plugins
6
System plugins
5
Scan Settings
First Action
Disinfect
Second Action
Delete
Heuristics
Yes
Enable Warnings
Yes
Scanned Extensions
Exclude Extensions
Scan Emails
Yes
Scan Archives
Yes
Scan Packed
Yes
Scan Files
Yes
Scan Boot
Yes
Scanned File
Status
C:\Documents and Settings\guy\Local Settings\Temp\tem123.tmp.exe
Detected with: Adware.Netnucleus.B
Deleted
C:\Documents and Settings\guy\Local Settings\Temp\USDR6V_0001_N19M2604\installer.exe=>(Instyler o)=>(Instyler Module 1)
Detected with: Adware.Systemdoctor.B
Deleted
Update failed
C:\Documents and Settings\guy\Local Settings\Temp\USDR6V_0001_N19M2604\installer.exe=>(Instyler o)=>(Instyler Module 3)
Deleted
Update failed
C:\Documents and Settings\guy\Local Settings\Temp\USDR6V_0001_N19M2604\installer.exe=>(Instyler o)=>(Instyler Module 4)
Infected with: Trojan.Downloader.Winfixer.T
Deleted
Update failed
C:\Documents and Settings\guy\Local Settings\Temp\USDR6V_0001_N19M2604\installer.exe=>(Instyler o)=>(Instyler Module 5)
Detected with: Application.SystemDoctor.2006.A
Disinfection failed
Deleted
Update failed
C:\Documents and Settings\guy\Local Settings\Temp\USDR6V_0001_N19M2604\installer.exe=>(Instyler o)=>(Instyler Module 6)
Infected with: Trojan.Downloader.Winfixer.E
Deleted
Update failed
C:\Documents and Settings\guy\Local Settings\Temp\USDR6V_0001_N19M2604\installer.exe=>(Instyler o)=>(Instyler Module 7)
Deleted
Update failed
C:\Documents and Settings\guy\Local Settings\Temp\USDR6V_0001_N19M2604\installer.exe=>(Instyler o)=>(Instyler Module 20)
Detected with: Application.Winfixer.DG
Disinfection failed
Deleted
Update failed
C:\Documents and Settings\guy\Mes documents\Aline \recipes_fr.exe=>(NSIS o)=>lzma_solid_nsis0011
Detected with: Adware.Starware.AF
Deleted
Update failed
C:\Documents and Settings\guy\Mes documents\Aline \recipes_fr.exe=>(NSIS o)=>lzma_solid_nsis0012
Detected with: Adware.Starware.AE
Deleted
Update failed
C:\System Volume Information\_restore{7AFC631D-71A6-4CBE-9F8F-EFDBDC0F94C6}\RP268\A0123158.exe
Infected with: Trojan.Obfus.6.Gen
Disinfection failed
Deleted
C:\System Volume Information\_restore{7AFC631D-71A6-4CBE-9F8F-EFDBDC0F94C6}\RP269\A0123179.exe
Disinfection failed
Deleted
C:\System Volume Information\_restore{7AFC631D-71A6-4CBE-9F8F-EFDBDC0F94C6}\RP269\A0123209.exe
Disinfection failed
Deleted
C:\System Volume Information\_restore{7AFC631D-71A6-4CBE-9F8F-EFDBDC0F94C6}\RP270\A0123211.exe
Disinfection failed
Deleted
C:\System Volume Information\_restore{7AFC631D-71A6-4CBE-9F8F-EFDBDC0F94C6}\RP271\A0123280.exe
Disinfection failed
Deleted
C:\System Volume Information\_restore{7AFC631D-71A6-4CBE-9F8F-EFDBDC0F94C6}\RP272\A0125300.exe
Disinfection failed
Deleted
C:\System Volume Information\_restore{7AFC631D-71A6-4CBE-9F8F-EFDBDC0F94C6}\RP273\A0127303.exe
Disinfection failed
Deleted
C:\System Volume Information\_restore{7AFC631D-71A6-4CBE-9F8F-EFDBDC0F94C6}\RP273\A0127326.exe
Disinfection failed
Deleted
C:\System Volume Information\_restore{7AFC631D-71A6-4CBE-9F8F-EFDBDC0F94C6}\RP274\A0127327.exe
Disinfection failed
Deleted
C:\System Volume Information\_restore{7AFC631D-71A6-4CBE-9F8F-EFDBDC0F94C6}\RP274\A0129336.exe
Disinfection failed
Deleted
C:\System Volume Information\_restore{7AFC631D-71A6-4CBE-9F8F-EFDBDC0F94C6}\RP276\A0129764.exe
Disinfection failed
Deleted
C:\System Volume Information\_restore{7AFC631D-71A6-4CBE-9F8F-EFDBDC0F94C6}\RP276\A0129765.exe
Disinfection failed
Deleted
C:\System Volume Information\_restore{7AFC631D-71A6-4CBE-9F8F-EFDBDC0F94C6}\RP276\A0129766.exe
Disinfection failed
Deleted
C:\System Volume Information\_restore{7AFC631D-71A6-4CBE-9F8F-EFDBDC0F94C6}\RP276\A0129767.exe
Disinfection failed
Deleted
C:\System Volume Information\_restore{7AFC631D-71A6-4CBE-9F8F-EFDBDC0F94C6}\RP280\A0132859.exe
Disinfection failed
Deleted
C:\System Volume Information\_restore{7AFC631D-71A6-4CBE-9F8F-EFDBDC0F94C6}\RP280\A0132861.exe
Disinfection failed
Deleted
C:\System Volume Information\_restore{7AFC631D-71A6-4CBE-9F8F-EFDBDC0F94C6}\RP281\A0133018.dll
Deleted
C:\WINDOWS\Downloaded Program Files\USDR6V_0001_N19M2604NetInstaller.exe
Infected with: Trojan.Downloader.CGW
Deleted
C:\WINDOWS\system32\=>:123456.exe
Infected with: Trojan.Generic.75660
Deleted
plus des fenetres cid non stop
Statistics
Time
01:11:34
Files
277072
Folders
9744
Boot Sectors
3
Archives
7656
Packed Files
9998
Results
Identified Viruses
11
Infected Files
29
Suspect Files
Warnings
Disinfected
Deleted Files
29
Engines Info
Virus Definitions
986099
Engine build
Scan plugins
16
Archive plugins
41
Unpack plugins
7
E-mail plugins
6
System plugins
5
Scan Settings
First Action
Disinfect
Second Action
Delete
Heuristics
Yes
Enable Warnings
Yes
Scanned Extensions
Exclude Extensions
Scan Emails
Yes
Scan Archives
Yes
Scan Packed
Yes
Scan Files
Yes
Scan Boot
Yes
Scanned File
Status
Deleted
Deleted
Update failed
Deleted
Update failed
Deleted
Update failed
Disinfection failed
Deleted
Update failed
Deleted
Update failed
Deleted
Update failed
Disinfection failed
Deleted
Update failed
Deleted
Update failed
Deleted
Update failed
Disinfection failed
Deleted
Disinfection failed
Deleted
Disinfection failed
Deleted
Disinfection failed
Deleted
Disinfection failed
Deleted
Disinfection failed
Deleted
Disinfection failed
Deleted
Disinfection failed
Deleted
Disinfection failed
Deleted
Disinfection failed
Deleted
Disinfection failed
Deleted
Disinfection failed
Deleted
Disinfection failed
Deleted
Disinfection failed
Deleted
Disinfection failed
Deleted
Disinfection failed
Deleted
Deleted
Deleted
Deleted
ok merci donc pour l'immédiat je ne peux rien faire pour reparer ?
Ouaip,
Dsl de pas t'avoir répondu plus tôt. En fait tu as beau avoir Avast, c'est pas le meilleur antivirus qui puisse exister. Je sais que je tournais avec ça par le passé et puis un beau jour j'ai décidé d'essayer un antivirus payant qui lui m'a detecté bien des choses qu'avast ne m'avait pas detecté. Je te parle d'une décision personnel, qui n'engage que moi. Beaucoup te diront qu'Avast est parfait. N'empêche que quand on compare les test antivirus réalisés par des revues indépendantes on arrive souvent à la constatation que les antivirus payant sont plus fiable que les gratuits comme Avast. Donc il s'agit toujours d'un conseil perso mais moi j'ai investi dans Kaspersky comme ça j'ai pas trop de question à me poser même si je dois payer chaque année quelquechose comme 50 euros pour deux licences.
Ton PC est complètement infecté, BitDefender t'a trouvé 11 virus. Le problème c'est que tu utilises une version online de Bitdefender qui à ma connaissance ne permet pas de désinfecter ton PC, pour cela il te faut investir dans un antivirus ou en télécharger un gratuit comme Avast. Tant que tu ne fais pas ça ton PC restera infecté donc inutilisable.
@guy1964je me suis lancé j'ai fait un rapport Hijackthis mais sans rien comprendre...........à l'aide svp
merci à voous tous par avance.
Scan saved at 17:53:51, on 08/03/2008
MSIE: Internet Explorer v7.00 (7.00.6000.16608)
Boot mode: Normal
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\lsass.exe
C:\Program Files\Alwil Software\Avast4\aswUpdSv.exe
C:\Program Files\Alwil Software\Avast4\ashServ.exe
C:\PROGRA~1\FICHIE~1\AOL\ACS\AOLacsd.exe
C:\Program Files\Fichiers communs\Apple\Mobile Device Support\bin\AppleMobileDeviceService.exe
c:\Apps\Powercinema\Kernel\TV\CLCapSvc.exe
C:\Program Files\CyberLink\Shared Files\CLML_NTService\CLMLServer.exe
C:\Program Files\CyberLink\Shared Files\CLML_NTService\CLMLService.exe
C:\WINDOWS\System32\FTRTSVC.exe
C:\Program Files\Controle Parental\bin\optproxy.exe
C:\WINDOWS\wanmpsvc.exe
c:\Apps\Powercinema\Kernel\TV\CLSched.exe
C:\Program Files\Alwil Software\Avast4\ashMaiSv.exe
C:\Program Files\Alwil Software\Avast4\ashWebSv.exe
C:\WINDOWS\Explorer.EXE
C:\WINDOWS\SOUNDMAN.EXE
C:\Program Files\Fichiers communs\Real\Update_OB\realsched.exe
C:\Program Files\QuickTime\qttask.exe
C:\Apps\Powercinema\PCMService.exe
C:\Program Files\HP\HP Software Update\HPWuSchd2.exe
C:\PROGRA~1\Wanadoo\TaskBarIcon.exe
C:\Program Files\Java\jre1.6.0_03\bin\jusched.exe
C:\Program Files\iTunes\iTunesHelper.exe
C:\Program Files\Adobe\Photoshop Album Edition Découverte\3.2\Apps\apdproxy.exe
C:\PROGRA~1\ALWILS~1\Avast4\ashDisp.exe
C:\WINDOWS\system32\ctfmon.exe
C:\Program Files\Internet Explorer\IEXPLORE.EXE
C:\Program Files\Windows Live\Messenger\msnmsgr.exe
C:\PROGRA~1\Wanadoo\GestionnaireInternet.exe
C:\program files\orange\player orange\Orange Player.exe
C:\PROGRA~1\Wanadoo\ComComp.exe
C:\Program Files\HP\Digital Imaging\bin\hpqtra08.exe
C:\PROGRA~1\Wanadoo\Toaster.exe
C:\PROGRA~1\Wanadoo\Inactivity.exe
C:\PROGRA~1\Wanadoo\PollingModule.exe
C:\WINDOWS\System32\ALERTM~1\ALERTM~1.EXE
C:\Program Files\OpenOffice.org 2.3\program\soffice.exe
C:\Program Files\OpenOffice.org 2.3\program\soffice.BIN
C:\Program Files\HP\Digital Imaging\bin\hpqSTE08.exe
C:\PROGRA~1\Wanadoo\Watch.exe
C:\Program Files\iPod\bin\iPodService.exe
C:\Program Files\Java\jre1.6.0_03\bin\jucheck.exe
C:\PROGRA~1\Wanadoo\WOOBrowser\WOOBrowser.exe
C:\Program Files\Windows Live\Messenger\usnsvc.exe
C:\Program Files\Trend Micro\HijackThis\HijackThis.exe
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Search Bar = https://www.bing.com/?FORM=TOOLBR&cc=fr&toHttps=1&redig=4527FFF1C12746FC9EDB535C75E80ECC
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Search Page = https://www.bing.com/?FORM=TOOLBR&cc=fr&toHttps=1&redig=4527FFF1C12746FC9EDB535C75E80ECC
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = https://www.orange.fr/portail
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = https://www.msn.com/fr-fr/?ocid=iehp
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Search_URL = https://www.bing.com/?toHttps=1&redig=5FC791212101479BAFBE1A679848B1AF
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Page = https://www.bing.com/?toHttps=1&redig=5FC791212101479BAFBE1A679848B1AF
R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = https://www.msn.com/fr-fr/?ocid=iehp
R1 - HKCU\Software\Microsoft\Internet Explorer\SearchURL,(Default) = https://www.bing.com/?FORM=TOOLBR&cc=fr&toHttps=1&redig=4527FFF1C12746FC9EDB535C75E80ECC
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Window Title = Orange
R3 - URLSearchHook: Search Class - {08C06D61-F1F3-4799-86F8-BE1A89362C85} - C:\PROGRA~1\Wanadoo\SEARCH~1.DLL
O2 - BHO: Aide pour le lien d'Adobe PDF Reader - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Fichiers communs\Adobe\Acrobat\ActiveX\AcroIEHelper.dll
O2 - BHO: GamesBar - {6F282B65-56BF-4BD1-A8B2-A4449A05863D} - C:\Program Files\GamesBar\oberontb.dll
O2 - BHO: SSVHelper Class - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Program Files\Java\jre1.6.0_03\bin\ssv.dll
O2 - BHO: (no name) - {7E853D72-626A-48EC-A868-BA8D5E23E045} - (no file)
O2 - BHO: ContextAdvisor - {87E68009-29A8-D669-F7C2-B31D08635C50} - C:\Program Files\ContextAdvisor\ContextAdvisor-2.dll
O2 - BHO: Programme d'aide de l'Assistant de connexion Windows Live - {9030D464-4C02-4ABF-8ECC-5164760863C6} - C:\Program Files\Fichiers communs\Microsoft Shared\Windows Live\WindowsLiveLogin.dll
O3 - Toolbar: GamesBar - {6F282B65-56BF-4BD1-A8B2-A4449A05863D} - C:\Program Files\GamesBar\oberontb.dll
O4 - HKLM\..\Run: [SoundMan] SOUNDMAN.EXE
O4 - HKLM\..\Run: [TkBellExe] "C:\Program Files\Fichiers communs\Real\Update_OB\realsched.exe" -osboot
O4 - HKLM\..\Run: [AOLDialer] C:\Program Files\Fichiers communs\AOL\ACS\AOLDial.exe
O4 - HKLM\..\Run: [PCMService] "c:\Apps\Powercinema\PCMService.exe"
O4 - HKLM\..\Run: [HP Software Update] C:\Program Files\HP\HP Software Update\HPWuSchd2.exe
O4 - HKLM\..\Run: [USB Storage Toolbox] C:\Documents and Settings\alexia\Mes documents\Ma musique\Res.EXE
O4 - HKLM\..\Run: [WOOWATCH] C:\PROGRA~1\Wanadoo\Watch.exe
O4 - HKLM\..\Run: [WOOTASKBARICON] C:\PROGRA~1\Wanadoo\GestMaj.exe TaskBarIcon.exe
O4 - HKLM\..\Run: [SunJavaUpdateSched] "C:\Program Files\Java\jre1.6.0_03\bin\jusched.exe"
O4 - HKLM\..\Run: [iTunesHelper] "C:\Program Files\iTunes\iTunesHelper.exe"
O4 - HKLM\..\Run: [DC6V_Check] "C:\Program Files\Fichiers communs\SystemDoctor\usdrdc.exe"
O4 - HKLM\..\Run: [MDRV_Check] "C:\Program Files\Fichiers communs\SystemDoctor\usdrmdr.exe"
O4 - HKLM\..\Run: [Adobe Photo Downloader] "C:\Program Files\Adobe\Photoshop Album Edition Découverte\3.2\Apps\apdproxy.exe"
O4 - HKLM\..\Run: [avast!] C:\PROGRA~1\ALWILS~1\Avast4\ashDisp.exe
O4 - HKLM\..\Run: [Adobe Reader Speed Launcher] "C:\Program Files\Adobe\Reader 8.0\Reader\Reader_sl.exe"
O4 - HKLM\..\Run: [Mode Load Mpeg Less] C:\Documents and Settings\All Users\Application Data\two setup mode load\Title Show.exe
O4 - HKCU\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\ctfmon.exe
O4 - HKCU\..\Run: [WOOKIT] C:\PROGRA~1\Wanadoo\Shell.exe appLaunchClientZone.shl|PARAM= cnx
O4 - HKCU\..\Run: [MsnMsgr] "C:\Program Files\Windows Live\Messenger\msnmsgr.exe" /background
O4 - HKCU\..\Run: [OrangePlayer] c:\program files\orange\player orange\Orange Player.exe /systray
O4 - HKUS\S-1-5-19\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\CTFMON.EXE (User 'SERVICE LOCAL')
O4 - HKUS\S-1-5-19\..\Run: [OrangePlayer] c:\program files\orange\player orange\Orange Player.exe /systray (User 'SERVICE LOCAL')
O4 - HKUS\S-1-5-20\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\CTFMON.EXE (User 'SERVICE RÉSEAU')
O4 - HKUS\S-1-5-21-876863040-2685688708-502279472-1005\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\ctfmon.exe (User 'Owner')
O4 - HKUS\S-1-5-21-876863040-2685688708-502279472-1005\..\Run: [Shareaza] "C:\Program Files\Shareaza\Shareaza.exe" -tray (User 'Owner')
O4 - HKUS\S-1-5-21-876863040-2685688708-502279472-1005\..\Run: [coal skip] C:\DOCUME~1\Owner\APPLIC~1\BOREME~1\TrustNew.exe (User 'Owner')
O4 - HKUS\S-1-5-18\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\CTFMON.EXE (User 'SYSTEM')
O4 - HKUS\.DEFAULT\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\CTFMON.EXE (User 'Default user')
O4 - Startup: OpenOffice.org 2.3.lnk = C:\Program Files\OpenOffice.org 2.3\program\quickstart.exe
O4 - Global Startup: HP Digital Imaging Monitor.lnk = C:\Program Files\HP\Digital Imaging\bin\hpqtra08.exe
O9 - Extra button: Messenger - -{FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe
O9 - Extra 'Tools' menuitem: Windows Messenger - -{FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe
O9 - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.6.0_03\bin\ssv.dll
O9 - Extra 'Tools' menuitem: Console Java (Sun) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.6.0_03\bin\ssv.dll
O9 - Extra button: (no name) - {1A93C934-025B-4c3a-B38E-9654A7003239} - C:\Program Files\GamesBar\oberontb.dll
O9 - Extra 'Tools' menuitem: GamesBar - {1A93C934-025B-4c3a-B38E-9654A7003239} - C:\Program Files\GamesBar\oberontb.dll
O9 - Extra button: (no name) - {85d1f590-48f4-11d9-9669-0800200c9a66} - C:\WINDOWS\bdoscandel.exe
O9 - Extra 'Tools' menuitem: Uninstall BitDefender Online Scanner v8 - {85d1f590-48f4-11d9-9669-0800200c9a66} - C:\WINDOWS\bdoscandel.exe
O9 - Extra button: (no name) - {e2e2dd38-d088-4134-82b7-f2ba38496583} - C:\WINDOWS\Network Diagnostic\xpnetdiag.exe
O9 - Extra 'Tools' menuitem: @xpsp3res.dll,-20001 - {e2e2dd38-d088-4134-82b7-f2ba38496583} - C:\WINDOWS\Network Diagnostic\xpnetdiag.exe
O9 - Extra button: Orange - {1462651F-F4BA-4C76-A001-C4284D0FE16E} - https://www.orange.fr/portail (file missing) (HKCU)
O16 - DPF: {09F1ADAC-76D8-4D0F-99A5-5C907DADB988} - http://cdn.downloadcontrol.com/files/installers/cab/SystemDoctor2006FreeInstall_fr.cab
O16 - DPF: {17492023-C23A-453E-A040-C7C580BBF700} (Windows Genuine Advantage Validation Tool) - http://download.microsoft.com/download/E/5/6/E5611B10-0D6D-4117-8430-A67417AA88CD/LegitCheckControl.cab
O16 - DPF: {20A60F0D-9AFA-4515-A0FD-83BD84642501} (Checkers Class) - http://messenger.zone.msn.com/binary/msgrchkr.cab56986.cab
O16 - DPF: {2250C29C-C5E9-4F55-BE4E-01E45A40FCF1} (CMediaMix Object) - http://musicmix.messenger.msn.com/Medialogic.CAB
O16 - DPF: {4F1E5B1A-2A80-42CA-8532-2D05CB959537} (MSN Photo Upload Tool) - http://gfx1.hotmail.com/mail/w2/pr02/resources/MSNPUpld.cab
O16 - DPF: {5C051655-FCD5-4969-9182-770EA5AA5565} (Solitaire Showdown Class) - http://messenger.zone.msn.com/binary/SolitaireShowdown.cab56986.cab
O16 - DPF: {5D6F45B3-9043-443D-A792-115447494D24} (UnoCtrl Class) - http://messenger.zone.msn.com/FR-FR/a-UNO1/GAME_UNO1.cab
O16 - DPF: {5D86DDB5-BDF9-441B-9E9E-D4730F4EE499} (BDSCANONLINE Control) - http://download.bitdefender.com/resources/scan8/oscan8.cab
O16 - DPF: {74D05D43-3236-11D4-BDCD-00C04F9A3B61} (HouseCall Control) - https://www.trendmicro.com/en_us/forHome/products/housecall.html
O16 - DPF: {7E980B9B-8AE5-466A-B6D6-DA8CF814E78A} (MJLauncherCtrl Class) - http://jeuxentelechargement.orange.fr/gameshell/online/fr/luxor_amun_rising/mjolauncher.cab
O16 - DPF: {80DD2229-B8E4-4C77-B72F-F22972D723EA} - http://www.inoculer.com/antivirus/Msie/bitdefender.cab
O16 - DPF: {B8BE5E93-A60C-4D26-A2DC-220313175592} (MSN Games - Installer) - http://messenger.zone.msn.com/binary/ZIntro.cab56649.cab
O16 - DPF: {C3F79A2B-B9B4-4A66-B012-3EE46475B072} (MessengerStatsClient Class) - http://messenger.zone.msn.com/binary/MessengerStatsPAClient.cab56907.cab
O16 - DPF: {CF40ACC5-E1BB-4AFF-AC72-04C2F616BCA7} (get_atlcom Class) - http://www.adobe.com/products/acrobat/nos/gp.cab
O16 - DPF: {D0C0F75C-683A-4390-A791-1ACFD5599AB8} (Oberon Flash Game Host) - http://jeuxenligne.orange.fr/Gameshell/GameHost/1.0/OberonGameHost.cab
O16 - DPF: {D821DC4A-0814-435E-9820-661C543A4679} (CRLDownloadWrapper Class) - http://drmlicense.one.microsoft.com/crlupdate/en/crlocx.ocx
O16 - DPF: {DFB5BCF1-06AE-4ABB-BFA8-1E228F41C50A} (CamfrogWEB Advanced Unicode Control) - https://www.bobtv.fr/download/cfweb_www.bobtv.fr-download_instmodule.exe
O16 - DPF: {F5A7706B-B9C0-4C89-A715-7A0C6B05DD48} (Minesweeper Flags Class) - http://messenger.zone.msn.com/binary/MineSweeper.cab56986.cab
O23 - Service: AOL Connectivity Service (AOL ACS) - AOL LLC - C:\PROGRA~1\FICHIE~1\AOL\ACS\AOLacsd.exe
O23 - Service: Apple Mobile Device - Apple, Inc. - C:\Program Files\Fichiers communs\Apple\Mobile Device Support\bin\AppleMobileDeviceService.exe
O23 - Service: avast! iAVS4 Control Service (aswUpdSv) - ALWIL Software - C:\Program Files\Alwil Software\Avast4\aswUpdSv.exe
O23 - Service: avast! Antivirus - ALWIL Software - C:\Program Files\Alwil Software\Avast4\ashServ.exe
O23 - Service: avast! Mail Scanner - ALWIL Software - C:\Program Files\Alwil Software\Avast4\ashMaiSv.exe
O23 - Service: avast! Web Scanner - ALWIL Software - C:\Program Files\Alwil Software\Avast4\ashWebSv.exe
O23 - Service: CyberLink Background Capture Service (CBCS) (CLCapSvc) - Unknown owner - c:\Apps\Powercinema\Kernel\TV\CLCapSvc.exe
O23 - Service: CyberLink Task Scheduler (CTS) (CLSched) - Unknown owner - c:\Apps\Powercinema\Kernel\TV\CLSched.exe
O23 - Service: CyberLink Media Library Service - Cyberlink - C:\Program Files\CyberLink\Shared Files\CLML_NTService\CLMLServer.exe
O23 - Service: France Telecom Routing Table Service (FTRTSVC) - France Telecom - C:\WINDOWS\System32\FTRTSVC.exe
O23 - Service: Service de l'iPod (iPod Service) - Apple Inc. - C:\Program Files\iPod\bin\iPodService.exe
O23 - Service: Control Parental (OPTENET_FILTER) - Contrôle Parental - C:\Program Files\Controle Parental\bin\optproxy.exe
O23 - Service: Pml Driver HPZ12 - HP - C:\WINDOWS\system32\HPZipm12.exe
O23 - Service: WAN Miniport (ATW) Service (WANMiniportService) - America Online, Inc. - C:\WINDOWS\wanmpsvc.exe
