Problème avec Worms 2
J'ai quelques problèmes de connexions pour jouer en ligne sur le jeu de PC Worms 2.
Je suis capabale de me connecter au chatt en ligne du jeu et tout , seulement je ne peux pas commencer de partie ou me joindre <a une autre partie déjà créer.
Voici un pragraphe que j'ai trouvé sur le net qui pourrait être la cause de mon problème:
Voici l'adresse du site > http://www.spadger.uk.ro/
Router Troubleshooting
Why cant i join people?
A router is a security tool. It blocks people connecting to you. It's like a locked door - People outside your house just cant get in (to your game), until you unlock it.
How do i unlock it?
You need to open the PORTS that worms2 uses, so other players can enter your game. This is done in your router settings.
How do i get in to my router settings?
Every router is different. For once in your life you are going to have to read the manual, or run a google search on your specific router model
google this for example: port forwarding microsoft router 7.7b
Which ports do i forward?
Once you have read something about what a router is & how it works, all you need to do is forward the correct ports. Make sure you forward both TCP and UDP. Forward ALL of the ports below, not just some of them :)
Port 47624
range 1000-3212
port 17000 (17171 demo)
port 5431
port 53
What else do i need to do?
You also need to do what we call IP switching. Download the easy-to-use IP Switcher. Open it, run it. Go to www.whatismyip.com to find your internet IP address. Put your internet IP address into the IP switcher. Go into the room you wish to create a game in, click "set IP", THEN host your game.
What does this IP switching do?
If you use a router, worms2 recognises you LAN IP. This IP starts with 192.168.x.x or 10.0.x.x. Without going in to too much detail, the only people who could ever connect to that IP, are people in your house, on your network. IP switching makes worms2 recognise your WAN (internet) IP, so people from anywhere on the internet can connect to you.
Do you have any other advice?
YES! Do your reading. Router settings are 1 thing where you really should know what you're doing. Dont think you can just work it out for yourself. All it takes is 10 minutes. Ask whoever set up your network if you arent sure.
Donc voilà, si quelqu'un pourrait m'indiquer comment faire se qui dise sur le site, ça serait très apprécié.
Configuration: Windows Vista
  1. Est-ce que tu pourrais m'explique plus en profondeur comment faire tout ca ?
    J'ai réussis à me rendre à la place de comment ajouter des ports et tout, j'ai rentrer les ports que tu m'a indiqué, mais sa ne change rien Est-ce que tu pourrais m'expliquer plus en profondeur Svp ?
    1. Salut.
      A ce moment là, vu que tes ports sont bien ouverts et que ton firewall est désactivé, il te faut vérifier si tu as la derniere version du jeu. Pour celà va sur le site officiel et télécharge les derniers patchs.
      Luc
  2. Salut,
    Avant tout, vérifie que ta version du jeu sois la derniere.
    Ensuite ouvre les ports suivant sur ton routeur:
    Port 47624
    range 1000-3212
    port 17000 - 17171
    port 5431
    port 53
    Le tout en TCP ET UDP. Afin de savoir comment le faire, te baser sur le manuel de ton routeur. (Ta box)
    Luc
