Xin Xp !! Probleme avec JAVA
Jai installer Java pour jouer a un jeu en ligne ... Apres plussieur essait l'instalation se déroule correctement.
Je vais sur le site du jeux et au moment de charger l'applet !! .... Internet Explorer se ferme et un Fichier texte apparait sur mon bureau :
Je fait copier/coller :
# An unexpected error has been detected by Java Runtime Environment:
# EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x05b5f325, pid=1324, tid=1344
# Java VM: Java HotSpot(TM) Client VM (1.6.0_03-b05 mixed mode, sharing)
# Problematic frame:
# V [jvm.dll+0x13f325]
# If you would like to submit a bug report, please visit:
# https://bugreport.java.com/bugreport/crash.jsp
--------------- T H R E A D ---------------
Current thread (0x01e39c00): JavaThread "main" [_thread_in_vm, id=1344]
siginfo: ExceptionCode=0xc0000005, writing address 0x00311ba0
Registers:
EAX=0x05c7a030, EBX=0x0000000c, ECX=0x00311b68, EDX=0x00090109
ESP=0x01ac3380, EBP=0x00000000, ESI=0x00311b68, EDI=0x07cf1ed4
EIP=0x05b5f325, EFLAGS=0x00010202
Top of Stack: (sp=0x01ac3380)
0x01ac3380: 07cf1ed4 00311b68 01e39c00 05ba961a
0x01ac3390: 07cf1ed4 01e39c00 01e39c00 01ac342c
0x01ac33a0: 07cf1d7c 07cf9384 07cf1ed0 07cf1d88
0x01ac33b0: 0000000c 05ba9cc9 01ac342c 07cf1d84
0x01ac33c0: 00000000 01e39c00 01e39c00 01e39c00
0x01ac33d0: 07cf1d7c 05ba9d03 01ac342c 07cf1d7c
0x01ac33e0: 00000000 01e39c00 00000000 01e39c00
0x01ac33f0: 00000000 00000000 05b78118 01e39c00
Instructions: (pc=0x05b5f325)
0x05b5f315: 0c 57 8b f1 e8 e2 6a f7 ff 8b 04 85 00 40 c3 05
0x05b5f325: 89 46 38 89 46 48 8b 46 18 c1 e8 08 83 c4 04 a8
Stack: [0x019d0000,0x01ad0000), sp=0x01ac3380, free space=972k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
[error occurred during error reporting, step 120, id 0xc0000005]
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
j sun.font.FontManager.<clinit>()V+27
v ~StubRoutines::call_stub
j sun.java2d.SunGraphicsEnvironment.addDirFonts(Ljava/lang/String;Ljava/io/File;Ljava/io/FilenameFilter;IZIZZ)V+401
j sun.java2d.SunGraphicsEnvironment.registerFontsInDir(Ljava/lang/String;ZIZZ)V+34
j sun.java2d.SunGraphicsEnvironment.access$200(Lsun/java2d/SunGraphicsEnvironment;Ljava/lang/String;ZIZZ)V+8
j sun.java2d.SunGraphicsEnvironment$2.run()Ljava/lang/Object;+351
j java.security.AccessController.doPrivileged(Ljava/security/PrivilegedAction;)Ljava/lang/Object;+0
j sun.java2d.SunGraphicsEnvironment.<init>()V+44
j sun.awt.Win32GraphicsEnvironment.<init>()V+1
j sun.reflect.NativeConstructorAccessorImpl.newInstance0(Ljava/lang/reflect/Constructor;[Ljava/lang/Object;)Ljava/lang/Object;+0
j sun.reflect.NativeConstructorAccessorImpl.newInstance([Ljava/lang/Object;)Ljava/lang/Object;+72
j sun.reflect.DelegatingConstructorAccessorImpl.newInstance([Ljava/lang/Object;)Ljava/lang/Object;+5
j java.lang.reflect.Constructor.newInstance([Ljava/lang/Object;)Ljava/lang/Object;+92
j java.lang.Class.newInstance0()Ljava/lang/Object;+118
j java.lang.Class.newInstance()Ljava/lang/Object;+15
j java.awt.GraphicsEnvironment.getLocalGraphicsEnvironment()Ljava/awt/GraphicsEnvironment;+27
j java.awt.Window.init(Ljava/awt/GraphicsConfiguration;)V+48
j java.awt.Window.<init>()V+82
j java.awt.Frame.<init>(Ljava/lang/String;)V+1
j java.awt.Frame.<init>()V+3
j sun.plugin.AppletViewer.<clinit>()V+4
j sun.plugin.JavaRunTime.initEnvironment(Ljava/lang/String;Ljava/lang/String;Ljava/lang/String;)V+87
--------------- P R O C E S S ---------------
Java Threads: ( => current thread )
0x07d20400 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=1728]
0x07d1b400 JavaThread "CompilerThread0" daemon [_thread_blocked, id=1724]
0x07d1a400 JavaThread "Attach Listener" daemon [_thread_blocked, id=828]
0x07d19400 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=1720]
0x07d11800 JavaThread "Finalizer" daemon [_thread_blocked, id=1716]
0x07d10800 JavaThread "Reference Handler" daemon [_thread_blocked, id=1712]
=>0x01e39c00 JavaThread "main" [_thread_in_vm, id=1344]
Other Threads:
0x07d0f400 VMThread [id=1708]
0x07d3ac00 WatcherThread [id=1464]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
def new generation total 960K, used 474K [0x20960000, 0x20a60000, 0x210c0000)
eden space 896K, 52% used [0x20960000, 0x209d6a58, 0x20a40000)
from space 64K, 0% used [0x20a40000, 0x20a40000, 0x20a50000)
to space 64K, 0% used [0x20a50000, 0x20a50000, 0x20a60000)
tenured generation total 4096K, used 0K [0x210c0000, 0x214c0000, 0x26960000)
the space 4096K, 0% used [0x210c0000, 0x210c0000, 0x210c0200, 0x214c0000)
compacting perm gen total 12288K, used 176K [0x26960000, 0x27560000, 0x2a960000)
the space 12288K, 1% used [0x26960000, 0x2698c2f8, 0x2698c400, 0x27560000)
ro space 8192K, 62% used [0x2a960000, 0x2ae614a8, 0x2ae61600, 0x2b160000)
rw space 12288K, 52% used [0x2b160000, 0x2b7a7278, 0x2b7a7400, 0x2bd60000)
Dynamic libraries:
0x00400000 - 0x0049b000 C:\Program Files\Internet Explorer\iexplore.exe
0x7c910000 - 0x7c9c7000 C:\WINDOWS\system32\ntdll.dll
0x7c800000 - 0x7c905000 C:\WINDOWS\system32\kernel32.dll
0x77da0000 - 0x77e4c000 C:\WINDOWS\system32\ADVAPI32.dll
0x77e50000 - 0x77ee1000 C:\WINDOWS\system32\RPCRT4.dll
0x77ef0000 - 0x77f37000 C:\WINDOWS\system32\GDI32.dll
0x7e390000 - 0x7e42f000 C:\WINDOWS\system32\USER32.dll
0x77be0000 - 0x77c38000 C:\WINDOWS\system32\msvcrt.dll
0x77f40000 - 0x77fb6000 C:\WINDOWS\system32\SHLWAPI.dll
0x7c9d0000 - 0x7d625000 C:\WINDOWS\system32\SHELL32.dll
0x774a0000 - 0x775dd000 C:\WINDOWS\system32\ole32.dll
0x44160000 - 0x44287000 C:\WINDOWS\system32\urlmon.dll
0x770e0000 - 0x7716b000 C:\WINDOWS\system32\OLEAUT32.dll
0x43e00000 - 0x43e45000 C:\WINDOWS\system32\iertutil.dll
0x77bd0000 - 0x77bd8000 C:\WINDOWS\system32\VERSION.dll
0x76320000 - 0x7633d000 C:\WINDOWS\system32\IMM32.DLL
0x77390000 - 0x77493000 C:\WINDOWS\WinSxS\x86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.2600.2982_x-ww_ac3f9c03\comctl32.dll
0x58b50000 - 0x58bea000 C:\WINDOWS\system32\comctl32.dll
0x44360000 - 0x4492d000 C:\WINDOWS\system32\IEFRAME.dll
0x76ba0000 - 0x76bab000 C:\WINDOWS\system32\PSAPI.DLL
0x5b090000 - 0x5b0c8000 C:\WINDOWS\system32\UxTheme.dll
0x20000000 - 0x2037c000 C:\WINDOWS\system32\xpsp2res.dll
0x75140000 - 0x7516e000 C:\WINDOWS\system32\msctfime.ime
0x5dff0000 - 0x5e01f000 C:\WINDOWS\system32\IEUI.dll
0x76310000 - 0x76315000 C:\WINDOWS\system32\MSIMG32.dll
0x4eb80000 - 0x4ed23000 C:\WINDOWS\WinSxS\x86_Microsoft.Windows.GdiPlus_6595b64144ccf1df_1.0.2600.2180_x-ww_522f9f82\gdiplus.dll
0x47060000 - 0x47081000 C:\WINDOWS\system32\xmllite.dll
0x77b50000 - 0x77b72000 C:\WINDOWS\system32\apphelp.dll
0x76f80000 - 0x76fff000 C:\WINDOWS\system32\CLBCATQ.DLL
0x011d0000 - 0x01336000 C:\WINDOWS\system32\COMRes.dll
0x74660000 - 0x7468a000 C:\WINDOWS\system32\msimtf.dll
0x74690000 - 0x746dc000 C:\WINDOWS\system32\MSCTF.dll
0x01550000 - 0x017c8000 C:\WINDOWS\system32\SETUPAPI.dll
0x77fc0000 - 0x77fd1000 C:\WINDOWS\system32\Secur32.dll
0x61930000 - 0x6197a000 C:\Program Files\Internet Explorer\ieproxy.dll
0x77210000 - 0x772c1000 C:\WINDOWS\system32\SXS.DLL
0x44080000 - 0x4414f000 C:\WINDOWS\system32\WININET.dll
0x01c00000 - 0x01c09000 C:\WINDOWS\system32\Normaliz.dll
0x75d30000 - 0x75dc1000 C:\WINDOWS\system32\MLANG.dll
0x719f0000 - 0x71a07000 C:\WINDOWS\system32\ws2_32.dll
0x719e0000 - 0x719e8000 C:\WINDOWS\system32\WS2HELP.dll
0x6d7c0000 - 0x6d839000 C:\Program Files\Java\jre1.6.0_03\bin\ssv.dll
0x7c340000 - 0x7c396000 C:\Program Files\Java\jre1.6.0_03\bin\MSVCR71.dll
0x10000000 - 0x10387000 c:\program files\google\googletoolbar2.dll
0x01ed0000 - 0x02196000 C:\WINDOWS\system32\msi.dll
0x779e0000 - 0x77a76000 C:\WINDOWS\system32\CRYPT32.dll
0x77a80000 - 0x77a92000 C:\WINDOWS\system32\MSASN1.dll
0x76c40000 - 0x76c68000 C:\WINDOWS\system32\imagehlp.dll
0x76ae0000 - 0x76b0f000 C:\WINDOWS\system32\WINMM.dll
0x76be0000 - 0x76c0e000 C:\WINDOWS\system32\WINTRUST.dll
0x71a10000 - 0x71a1a000 C:\WINDOWS\system32\WSOCK32.dll
0x71990000 - 0x719d0000 C:\WINDOWS\system32\mswsock.dll
0x62e40000 - 0x62e99000 C:\WINDOWS\system32\hnetcfg.dll
0x719d0000 - 0x719d8000 C:\WINDOWS\System32\wshtcpip.dll
0x76e90000 - 0x76ecc000 C:\WINDOWS\system32\RASAPI32.dll
0x76e40000 - 0x76e52000 C:\WINDOWS\system32\rasman.dll
0x6fee0000 - 0x6ff35000 C:\WINDOWS\system32\NETAPI32.dll
0x76e60000 - 0x76e8f000 C:\WINDOWS\system32\TAPI32.dll
0x76e30000 - 0x76e3e000 C:\WINDOWS\system32\rtutils.dll
0x76960000 - 0x76a15000 C:\WINDOWS\system32\USERENV.dll
0x71ca0000 - 0x71cbc000 C:\WINDOWS\system32\ACTXPRXY.DLL
0x76ed0000 - 0x76ef7000 C:\WINDOWS\system32\DNSAPI.dll
0x76d10000 - 0x76d29000 C:\WINDOWS\system32\iphlpapi.dll
0x76f70000 - 0x76f76000 C:\WINDOWS\system32\rasadhlp.dll
0x77c40000 - 0x77c63000 C:\WINDOWS\system32\msv1_0.dll
0x44a40000 - 0x44db4000 C:\WINDOWS\system32\mshtml.dll
0x027b0000 - 0x027d9000 C:\WINDOWS\system32\msls31.dll
0x63380000 - 0x633f8000 C:\WINDOWS\system32\jscript.dll
0x58760000 - 0x58792000 C:\WINDOWS\system32\iepeers.dll
0x72f50000 - 0x72f76000 C:\WINDOWS\system32\WINSPOOL.DRV
0x44000000 - 0x44077000 C:\WINDOWS\system32\mshtmled.dll
0x1b000000 - 0x1b00c000 C:\WINDOWS\system32\ImgUtil.dll
0x1b060000 - 0x1b06e000 C:\WINDOWS\system32\pngfilt.dll
0x72c70000 - 0x72c79000 C:\WINDOWS\system32\wdmaud.drv
0x72c60000 - 0x72c68000 C:\WINDOWS\system32\msacm32.drv
0x77bb0000 - 0x77bc5000 C:\WINDOWS\system32\MSACM32.dll
0x77ba0000 - 0x77ba7000 C:\WINDOWS\system32\midimap.dll
0x6fb80000 - 0x6fbfd000 C:\WINDOWS\system32\USP10.dll
0x73300000 - 0x73365000 C:\WINDOWS\system32\vbscript.dll
0x30000000 - 0x302ef000 C:\WINDOWS\system32\macromed\flash\flash.ocx
0x76340000 - 0x7638a000 C:\WINDOWS\system32\comdlg32.dll
0x76790000 - 0x767b7000 C:\WINDOWS\system32\schannel.dll
0x6d8f0000 - 0x6d8fa000 C:\WINDOWS\system32\ddrawex.dll
0x736b0000 - 0x736f9000 C:\WINDOWS\system32\DDRAW.dll
0x73b10000 - 0x73b16000 C:\WINDOWS\system32\DCIMAN32.dll
0x6d6b0000 - 0x6d6d1000 C:\Program Files\Java\jre1.6.0_03\bin\npjpi160_03.dll
0x6d4a0000 - 0x6d4bb000 C:\Program Files\Java\jre1.6.0_03\bin\jpiexp.dll
0x6d250000 - 0x6d261000 C:\Program Files\Java\jre1.6.0_03\bin\deploy.dll
0x76f60000 - 0x76f68000 C:\WINDOWS\System32\winrnr.dll
0x76f10000 - 0x76f3d000 C:\WINDOWS\system32\WLDAP32.dll
0x6d4f0000 - 0x6d514000 C:\Program Files\Java\jre1.6.0_03\bin\jpishare.dll
0x05a20000 - 0x05c6a000 C:\PROGRA~1\Java\JRE16~1.0_~\bin\client\jvm.dll
0x6d310000 - 0x6d318000 C:\PROGRA~1\Java\JRE16~1.0_~\bin\hpi.dll
0x6d770000 - 0x6d77c000 C:\PROGRA~1\Java\JRE16~1.0_~\bin\verify.dll
0x6d3b0000 - 0x6d3cf000 C:\PROGRA~1\Java\JRE16~1.0_~\bin\java.dll
0x6d7b0000 - 0x6d7bf000 C:\PROGRA~1\Java\JRE16~1.0_~\bin\zip.dll
0x6d000000 - 0x6d1c3000 C:\Program Files\Java\jre1.6.0_03\bin\awt.dll
VM Arguments:
jvm_args: -Xbootclasspath/a:C:\PROGRA~1\Java\JRE16~1.0_~\lib\deploy.jar;C:\PROGRA~1\Java\JRE16~1.0_~\lib\plugin.jar -Xmx96m -Djavaplugin.maxHeapSize=96m -Xverify:remote -Djavaplugin.version=1.6.0_03 -Djavaplugin.nodotversion=160_03 -Dbrowser=sun.plugin -DtrustProxy=true -Dapplication.home=C:\PROGRA~1\Java\JRE16~1.0_~ -Djavaplugin.vm.options=-Djava.class.path=C:\PROGRA~1\Java\JRE16~1.0_~\classes -Xbootclasspath/a:C:\PROGRA~1\Java\JRE16~1.0_~\lib\deploy.jar;C:\PROGRA~1\Java\JRE16~1.0_~\lib\plugin.jar -Xmx96m -Djavaplugin.maxHeapSize=96m -Xverify:remote -Djavaplugin.version=1.6.0_03 -Djavaplugin.nodotversion=160_03 -Dbrowser=sun.plugin -DtrustProxy=true -Dapplication.home=C:\PROGRA~1\Java\JRE16~1.0_~
java_command: <unknown>
Launcher Type: generic
Environment Variables:
PATH=C:\PROGRA~1\Java\JRE16~1.0_~\bin;C:\Program Files\Internet Explorer;;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;.
USERNAME=Ian
OS=Windows_NT
PROCESSOR_IDENTIFIER=x86 Family 6 Model 8 Stepping 0, AuthenticAMD
--------------- S Y S T E M ---------------
OS: Windows XP Build 2600 Service Pack 2
CPU:total 1 (1 cores per cpu, 1 threads per core) family 6 model 8 stepping 0, cmov, cx8, fxsr, mmx, sse, mmxext, 3dnow, 3dnowext
Memory: 4k page, physical 228848k(60836k free), swap 558676k(343728k free)
vm_info: Java HotSpot(TM) Client VM (1.6.0_03-b05) for windows-x86, built on Sep 24 2007 22:24:33 by "java_re" with unknown MS VC++:1310
Jaimerai bien jouer a mon jeux alors que faire pouvez vous maider ???
Merci bien !!
  1. Pas de problème,
    oublie pas de mettre le topic en résolu
    Bonne soirée
    1. Bonsoir,
      Essaye de désinstaller Java, par
      ---> Poste de travail
      ---> Ajout/suppression de programmes
      ---> Cherche Java
      ---> Desinstaller
      Ensuite redémarre ton PC puis :
      Mets JAVA à jour :
      https://www.java.com/fr/download/manual.jsp
      _____________________________________________________
      Tester Java et autres players:
      http://www.chemgapedia.de/vsengine/info/fr/help/requirements/java.html
      Aprés :
      Les animations Flash/Shockwave:
      Pour installer Flash Player:
      https://get.adobe.com/flashplayer/
      Pour installer Shockwave Player:
      Flash et Shockwave fonctionnent dans Internet Explorer, Netscape, Mozilla, Firefox et Opera.
      Pour tester votre installation de Flash et Shockwave :
      https://helpx.adobe.com/shockwave/shockwave-end-of-life-faq.html
      Redis moi aprés tous ça !
