Problème installation scilab !!!!!!!!!!!!
Bonsoir à tous,
j'essai d'installer la dernière version de scilab et quand je tape la commande : ./configure il me sort des erreurs
voici ce que cela m'affiche:
[root@localhost scilab-4.1.2]# ./configure
checking build system type... i686-pc-linux-gnu
checking host system type... i686-pc-linux-gnu
configuration of libtool
checking for gcc... gcc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking for a sed that does not truncate output... /bin/sed
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for ld used by gcc... /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... yes
checking for /usr/bin/ld option to reload object files... -r
checking for BSD-compatible nm... /usr/bin/nm -B
checking whether ln -s works... yes
checking how to recognise dependent libraries... pass_all
checking how to run the C preprocessor... gcc -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking dlfcn.h usability... yes
checking dlfcn.h presence... yes
checking for dlfcn.h... yes
checking for g++... g++
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking how to run the C++ preprocessor... g++ -E
checking for g77... no
checking for xlf... no
checking for f77... no
checking for frt... no
checking for pgf77... no
checking for cf77... no
checking for fort77... no
checking for fl32... no
checking for af77... no
checking for xlf90... no
checking for f90... no
checking for pgf90... no
checking for pghpf... no
checking for epcf90... no
checking for gfortran... gfortran
checking whether we are using the GNU Fortran 77 compiler... yes
checking whether gfortran accepts -g... yes
checking the maximum length of command line arguments... 32768
checking command to parse /usr/bin/nm -B output from gcc object... ok
checking for objdir... .libs
checking for ar... ar
checking for ranlib... ranlib
checking for strip... strip
checking if gcc static flag works... yes
checking if gcc supports -fno-rtti -fno-exceptions... no
checking for gcc option to produce PIC... -fPIC
checking if gcc PIC flag -fPIC works... yes
checking if gcc supports -c -o file.o... yes
checking whether the gcc linker (/usr/bin/ld) supports shared libraries... yes
checking whether -lc should be explicitly linked in... no
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... yes
configure: creating libtool
appending configuration tag "CXX" to libtool
checking for ld used by g++... /usr/bin/ld
checking whether the g++ linker (/usr/bin/ld) supports shared libraries... yes
checking for g++ option to produce PIC... -fPIC
checking if g++ PIC flag -fPIC works... yes
checking if g++ supports -c -o file.o... yes
appending configuration tag "F77" to libtool
checking for gfortran option to produce PIC... -fPIC
checking if gfortran PIC flag -fPIC works... yes
checking if gfortran supports -c -o file.o... yes
checking whether the gfortran linker (/usr/bin/ld) supports shared libraries...
yes
end of configuration of libtool
checking for main in -lieee... yes
checking for gfortran... yes
checking for X... no
configure: error: X Window not found
Je suis désolé si ma question vous semble idiote mais je suis débutant et je ne trouve pas d'aide à ce sujet.
Merci par avance.
yes
Merci par avance.
Configuration: Linux Mandriva Firefox 2.0.0.8
10 réponses
je souhaite travailler avec le langage fortran 77 j'ai un lunix (Mandriva 2007) comment faire pour avoir le fortran 77
problème résolu!!
Il me manquait seulement libxorg-x11-devel !!
Et voila le tour est joué.
Merci à tous -
Voila ce que le gestionaire de paquetages me donne lorsque je fais une recherche sur xorg.
[root@localhost Sundials]# urpmq xorg
Pas de paquetage nommé xorg
Les paquetages suivants contiennent xorg :
libxorg-x11
libxorg-x11-devel
libxorg-x11-static-devel
x11-server-xorg
xorg-x11
xorg-x11-100dpi-fonts
xorg-x11-75dpi-fonts
xorg-x11-Xdmx
xorg-x11-Xnest
xorg-x11-Xvfb
xorg-x11-cyrillic-fonts
xorg-x11-doc
xorg-x11-server
xorg-x11-xauth
xorg-x11-xfs
Je précise que x11-server-xorg est déja installé. Lequel de ces paquetages doi-je installé?? -
ContributeurOk alors installes les sources de X-Window.
Dans ton gestionnaire de paquetages, fais une recherche "xorg + source" ou "xorg + header".
Konsole...pardon
C'est bien ce que je fais je compile depuis console. ;-) -
J'ai le même problème en compilant la version SVN...
Quelqu'un peux t'il me dire à quoi sert ce X Window??? -
Merci de vos réponses.
J'avais déja la version binaire d'installé. Je l'ai désinstallé car maintenant j'ai besoin de la version source justement.
Pour répondre à chocobn, je complie scilab à partir d'une console classique que j'ouvre en faisant f4 lorsque je suis dans le répertoire par exemple. C'est ma propre machine, j'ai installé la dernière version de mandriva dessus. Je ne pense pas passer par un serveur...
J'espère que ça pourra vous aider... et que vous arriverez à m'aider.
Merci encore
Damien -
Contributeur... ou alors passer par son gestionnaire de paquetage.
C'est étrange ça, vu ton système.. Est-ce que tu n'est pas en train de compiler scilab dans un terminal en mode non graphique ? (ou sur un serveur où X n'est pas installé) ?
Sinon, tu peux télécharger la version binaire de Scilab, ça s'installe quasiment tout seul :
tu télécharges : https://www.scilab.org/download/4.1.2/scilab-4.1.2.bin.linux-i686.tar.gz
tu décompresses
tu te déplaces dans le répertoire scilab-4.1.2 et tu tapes "make"
tu lances scilab (qui est dans "scilab-4.1.2/bin"
