Problem de gravure,,,
bonjour j n'arrive pas a a gravee mes cd,,, sa f la 5 em fois q mon gravure echoue a gravee,, comment j p faire?? tou le temps quand j grave mes cd il ya tjrs un message qui di burning failed,, quelq'un p m'aider?? j meme enregistre des erreur...
C.C.M
Moi
1A20-020K-0000-2522-5589-7617
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Ahead\nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 26/10/2004 19:35:32
Nero Version: 6.6.0.14
Internal Version: 6, 6, 0, 14d
(Nero Express)
Recorder: <MATSHITA DVD-RAM UJ-841S>Version: 1.70 - HA 1 TA 0 - 6.6.0.14
Adapter driver: <atapi> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
CD-ROM: <MATSHITA DVD-RAM UJ-841S >Version: 1.70 - HA 1 TA 0 - 6.6.0.14
=== Scsi-Device-Map ===
DiskPeripheral : TOSHIBA MK1234GSX atapi Port 0 ID 0 DMA: On
CdRomPeripheral : MATSHITA DVD-RAM UJ-841S atapi Port 1 ID 0 DMA: On
=== CDRom-Device-Map ===
MATSHITA DVD-RAM UJ-841S E: CDRom0
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 73400320 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 502MB (514092kB)
Free physical memory: 108MB (111272kB)
Memory in use : 78 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
18.11.2007
Audio CD
15:27:23 #1 CDADOC -1 File Cdadoc.cpp, Line 1465
Audio item log info:
Audio document burn settings:
Burn mode: DAO,
CD Text: On,
Cache disk or network files: No,
Cache small files: No,
Cache files smaller than 65536 bytes.
Audio Multisession: No
List of audio tracks:
Track 01: Length: 04:02.72, Pause frames: 150, Filters: 1, Name: '01 Westlife - You Raise Me Up.mp3'.
Track 02: Length: 03:13.69, Pause frames: 150, Filters: 1, Name: 'Baby Can I Hold U-Chapman, Tracy .mp3'.
Track 03: Length: 04:05.04, Pause frames: 150, Filters: 1, Name: 'bee gees - how deep is your love.mp3'.
Track 04: Length: 05:55.25, Pause frames: 150, Filters: 1, Name: 'bryan adams - please forgive me.mp3'.
Track 05: Length: 04:03.54, Pause frames: 150, Filters: 1, Name: 'Breakin' ma heart.mp3'.
Track 06: Length: 05:18.05, Pause frames: 150, Filters: 1, Name: 'Copy of 02 Goodbye the saddest word.wma'.
Track 07: Length: 03:07.26, Pause frames: 150, Filters: 1, Name: 'Copy of 13 Imagine.wma'.
Track 08: Length: 04:15.12, Pause frames: 150, Filters: 1, Name: 'Copy of 18 It must have been Love.wma'.
Track 09: Length: 03:55.17, Pause frames: 150, Filters: 1, Name: 'elton john - daniel.mp3'.
Track 10: Length: 05:08.39, Pause frames: 150, Filters: 1, Name: 'elton john - elton john - sacrifice.mp3'.
Track 11: Length: 05:43.57, Pause frames: 150, Filters: 1, Name: 'EVERYDAY.MP3'.
Track 12: Length: 04:09.48, Pause frames: 150, Filters: 1, Name: 'lionel richie - hello.mp3'.
Track 13: Length: 03:15.14, Pause frames: 150, Filters: 1, Name: 'lionel richie - stuck on you.mp3'.
Track 14: Length: 03:39.08, Pause frames: 150, Filters: 1, Name: 'marcos hernandez - c about me() - if you were mine.mp3'.
Track 15: Length: 04:36.20, Pause frames: 150, Filters: 1, Name: 'phil collins - do you remember.mp3'.
Track 16: Length: 05:35.42, Pause frames: 150, Filters: 1, Name: 'phill collins- all of my life.mp3'.
Track 17: Length: 04:12.60, Pause frames: 150, Filters: 1, Name: 'roxete - take my breath away.mp3'.
Track 18: Length: 04:45.50, Pause frames: 150, Filters: 1, Name: 'westlife - unbreakable.mp3'.
Total size: 79:39.22
15:27:23 #2 Text 0 File Burncd.cpp, Line 2945
SmoothLink activated
15:27:23 #3 Text 0 File Reader.cpp, Line 127
Reader running
15:27:23 #4 Text 0 File AudioCompilationImpl.cpp, Line 842
DRM: StartDrmRecording(RealRec:1, ImageRec:0, Copies:1)
DRM: Beginning burn process.
15:27:23 #5 Text 0 File Writer.cpp, Line 122
Writer MATSHITA DVD-RAM UJ-841S running
15:27:23 #6 Text 0 File Burncd.cpp, Line 3230
Turn on Disc-At-Once, using CD-R/RW media
15:27:23 #7 Text 0 File DlgWaitCD.cpp, Line 267
Last possible write address on media: 359848 ( 79:59.73)
Last address to be written: 358296 ( 79:39.21)
15:27:23 #8 Text 0 File DlgWaitCD.cpp, Line 279
Write in overburning mode: NO (enabled: CD)
15:27:23 #9 Text 0 File DlgWaitCD.cpp, Line 2433
Recorder: MATSHITA DVD-RAM UJ-841S;
CDR code: 00 97 27 18; OSJ entry from: Plasmon Data systems Ltd.
ATIP Data:
Special Info [hex] 1: D0 00 A0, 2: 61 1B 12 (LI 97:27.18), 3: 4F 3B 4A (LO 79:59.74)
Additional Info [hex] 1: 00 00 00 (invalid), 2: 00 00 00 (invalid), 3: 00 00 00 (invalid)
15:27:23 #10 Text 0 File DlgWaitCD.cpp, Line 445
>>> Protocol of DlgWaitCD activities: <<<
15:27:23 #11 Text 0 File ThreadedTransferInterface.cpp, Line 830
Setup items (after recorder preparation)
0: TRM_AUDIO_NOPRE (01 Westlife - You Raise Me Up.mp3)
2 indices, index0 (150) not provided
original disc pos #0 + 18222 (18222) = #18222/4:2.72
relocatable, disc pos for caching/writing not required/not required, no patch infos
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 18222 blocks [MATSHITA DVD-RAM UJ-841S]
1: TRM_AUDIO_NOPRE (Baby Can I Hold U-Chapman, Tracy .mp3)
original disc pos #0 + 14544 (14544) = #14544/3:13.69
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 14544 blocks [MATSHITA DVD-RAM UJ-841S]
2: TRM_AUDIO_NOPRE (bee gees - how deep is your love.mp3)
original disc pos #0 + 18379 (18379) = #18379/4:5.4
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 18379 blocks [MATSHITA DVD-RAM UJ-841S]
3: TRM_AUDIO_NOPRE (bryan adams - please forgive me.mp3)
original disc pos #0 + 26650 (26650) = #26650/5:55.25
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 26650 blocks [MATSHITA DVD-RAM UJ-841S]
4: TRM_AUDIO_NOPRE (Breakin' ma heart.mp3)
original disc pos #0 + 18279 (18279) = #18279/4:3.54
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 18279 blocks [MATSHITA DVD-RAM UJ-841S]
5: TRM_AUDIO_NOPRE (Copy of 02 Goodbye the saddest word.wma)
original disc pos #0 + 23855 (23855) = #23855/5:18.5
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 23855 blocks [MATSHITA DVD-RAM UJ-841S]
6: TRM_AUDIO_NOPRE (Copy of 13 Imagine.wma)
original disc pos #0 + 14051 (14051) = #14051/3:7.26
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 14051 blocks [MATSHITA DVD-RAM UJ-841S]
7: TRM_AUDIO_NOPRE (Copy of 18 It must have been Love.wma)
original disc pos #0 + 19137 (19137) = #19137/4:15.12
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 19137 blocks [MATSHITA DVD-RAM UJ-841S]
8: TRM_AUDIO_NOPRE (elton john - daniel.mp3)
original disc pos #0 + 17642 (17642) = #17642/3:55.17
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 17642 blocks [MATSHITA DVD-RAM UJ-841S]
9: TRM_AUDIO_NOPRE (elton john - elton john - sacrifice.mp3)
original disc pos #0 + 23139 (23139) = #23139/5:8.39
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 23139 blocks [MATSHITA DVD-RAM UJ-841S]
10: TRM_AUDIO_NOPRE (EVERYDAY.MP3)
original disc pos #0 + 25782 (25782) = #25782/5:43.57
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 25782 blocks [MATSHITA DVD-RAM UJ-841S]
11: TRM_AUDIO_NOPRE (lionel richie - hello.mp3)
original disc pos #0 + 18723 (18723) = #18723/4:9.48
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 18723 blocks [MATSHITA DVD-RAM UJ-841S]
12: TRM_AUDIO_NOPRE (lionel richie - stuck on you.mp3)
original disc pos #0 + 14639 (14639) = #14639/3:15.14
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 14639 blocks [MATSHITA DVD-RAM UJ-841S]
13: TRM_AUDIO_NOPRE (marcos hernandez - c about me() - if you were mine.mp3)
original disc pos #0 + 16433 (16433) = #16433/3:39.8
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 16433 blocks [MATSHITA DVD-RAM UJ-841S]
14: TRM_AUDIO_NOPRE (phil collins - do you remember.mp3)
original disc pos #0 + 20720 (20720) = #20720/4:36.20
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 20720 blocks [MATSHITA DVD-RAM UJ-841S]
15: TRM_AUDIO_NOPRE (phill collins- all of my life.mp3)
original disc pos #0 + 25167 (25167) = #25167/5:35.42
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 25167 blocks [MATSHITA DVD-RAM UJ-841S]
16: TRM_AUDIO_NOPRE (roxete - take my breath away.mp3)
original disc pos #0 + 18960 (18960) = #18960/4:12.60
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 18960 blocks [MATSHITA DVD-RAM UJ-841S]
17: TRM_AUDIO_NOPRE (westlife - unbreakable.mp3)
original disc pos #0 + 21425 (21425) = #21425/4:45.50
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 21425 blocks [MATSHITA DVD-RAM UJ-841S]
15:27:23 #12 Text 0 File ThreadedTransferInterface.cpp, Line 1043
Prepare recorder [MATSHITA DVD-RAM UJ-841S] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 18:
1: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 0 352800 43210944, ISRC ""
2: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 43210944 43563744 77771232, ISRC ""
3: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 77771232 78124032 121351440, ISRC ""
4: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 121351440 121704240 184385040, ISRC ""
5: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 184385040 184737840 227730048, ISRC ""
6: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 227730048 228082848 284189808, ISRC ""
7: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 284189808 284542608 317590560, ISRC ""
8: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 317590560 317943360 362953584, ISRC ""
9: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 362953584 363306384 404800368, ISRC ""
10: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 404800368 405153168 459576096, ISRC ""
11: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 459576096 459928896 520568160, ISRC ""
12: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 520568160 520920960 564957456, ISRC ""
13: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 564957456 565310256 599741184, ISRC ""
14: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 599741184 600093984 638744400, ISRC ""
15: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 638744400 639097200 687830640, ISRC ""
16: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 687830640 688183440 747376224, ISRC ""
17: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 747376224 747729024 792322944, ISRC ""
18: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 792322944 792675744 843067344, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep__________
-150 | lead-in | 0 | 0x01 | 0x00
-150 | 1 | 0 | 0x21 | 0x00
0 | 1 | 1 | 0x21 | 0x00
18222 | 2 | 0 | 0x21 | 0x00
18372 | 2 | 1 | 0x21 | 0x00
32916 | 3 | 0 | 0x21 | 0x00
33066 | 3 | 1 | 0x21 | 0x00
51445 | 4 | 0 | 0x21 | 0x00
51595 | 4 | 1 | 0x21 | 0x00
78245 | 5 | 0 | 0x21 | 0x00
78395 | 5 | 1 | 0x21 | 0x00
96674 | 6 | 0 | 0x21 | 0x00
96824 | 6 | 1 | 0x21 | 0x00
120679 | 7 | 0 | 0x21 | 0x00
120829 | 7 | 1 | 0x21 | 0x00
134880 | 8 | 0 | 0x21 | 0x00
135030 | 8 | 1 | 0x21 | 0x00
154167 | 9 | 0 | 0x21 | 0x00
154317 | 9 | 1 | 0x21 | 0x00
171959 | 10 | 0 | 0x21 | 0x00
172109 | 10 | 1 | 0x21 | 0x00
195248 | 11 | 0 | 0x21 | 0x00
195398 | 11 | 1 | 0x21 | 0x00
221180 | 12 | 0 | 0x21 | 0x00
221330 | 12 | 1 | 0x21 | 0x00
240053 | 13 | 0 | 0x21 | 0x00
240203 | 13 | 1 | 0x21 | 0x00
254842 | 14 | 0 | 0x21 | 0x00
254992 | 14 | 1 | 0x21 | 0x00
271425 | 15 | 0 | 0x21 | 0x00
271575 | 15 | 1 | 0x21 | 0x00
292295 | 16 | 0 | 0x21 | 0x00
292445 | 16 | 1 | 0x21 | 0x00
317612 | 17 | 0 | 0x21 | 0x00
317762 | 17 | 1 | 0x21 | 0x00
336722 | 18 | 0 | 0x21 | 0x00
336872 | 18 | 1 | 0x21 | 0x00
358297 | lead-out | 1 | 0x01 | 0x00
15:28:21 #13 Phase 36 File dlgbrnst.cpp, Line 1832
Burn process started at 16x (2,400 KB/s)
15:28:21 #14 Text 0 File ThreadedTransferInterface.cpp, Line 2643
Verifying disc position of item 0 (relocatable, no disc pos, no patch infos, orig at #0): write at #0
15:28:21 #15 Text 0 File ThreadedTransferInterface.cpp, Line 2643
Verifying disc position of item 1 (relocatable, no disc pos, no patch infos, orig at #0): write at #18372
15:28:21 #16 Text 0 File ThreadedTransferInterface.cpp, Line 2643
Verifying disc position of item 2 (relocatable, no disc pos, no patch infos, orig at #0): write at #33066
15:28:21 #17 Text 0 File ThreadedTransferInterface.cpp, Line 2643
Verifying disc position of item 3 (relocatable, no disc pos, no patch infos, orig at #0): write at #51595
15:28:21 #18 Text 0 File ThreadedTransferInterface.cpp, Line 2643
Verifying disc position of item 4 (relocatable, no disc pos, no patch infos, orig at #0): write at #78395
15:28:21 #19 Text 0 File ThreadedTransferInterface.cpp, Line 2643
Verifying disc position of item 5 (relocatable, no disc pos, no patch infos, orig at #0): write at #96824
15:28:21 #20 Text 0 File ThreadedTransferInterface.cpp, Line 2643
Verifying disc position of item 6 (relocatable, no disc pos, no patch infos, orig at #0): write at #120829
15:28:21 #21 Text 0 File ThreadedTransferInterface.cpp, Line 2643
Verifying disc position of item 7 (relocatable, no disc pos, no patch infos, orig at #0): write at #135030
15:28:21 #22 Text 0 File ThreadedTransferInterface.cpp, Line 2643
Verifying disc position of item 8 (relocatable, no disc pos, no patch infos, orig at #0): write at #154317
15:28:21 #23 Text 0 File ThreadedTransferInterface.cpp, Line 2643
Verifying disc position of item 9 (relocatable, no disc pos, no patch infos, orig at #0): write at #172109
15:28:21 #24 Text 0 File ThreadedTransferInterface.cpp, Line 2643
Verifying disc position of item 10 (relocatable, no disc pos, no patch infos, orig at #0): write at #195398
15:28:21 #25 Text 0 File ThreadedTransferInterface.cpp, Line 2643
Verifying disc position of item 11 (relocatable, no disc pos, no patch infos, orig at #0): write at #221330
15:28:21 #26 Text 0 File ThreadedTransferInterface.cpp, Line 2643
Verifying disc position of item 12 (relocatable, no disc pos, no patch infos, orig at #0): write at #240203
15:28:21 #27 Text 0 File ThreadedTransferInterface.cpp, Line 2643
Verifying disc position of item 13 (relocatable, no disc pos, no patch infos, orig at #0): write at #254992
15:28:21 #28 Text 0 File ThreadedTransferInterface.cpp, Line 2643
Verifying disc position of item 14 (relocatable, no disc pos, no patch infos, orig at #0): write at #271575
15:28:21 #29 Text 0 File ThreadedTransferInterface.cpp, Line 2643
Verifying disc position of item 15 (relocatable, no disc pos, no patch infos, orig at #0): write at #292445
15:28:21 #30 Text 0 File ThreadedTransferInterface.cpp, Line 2643
Verifying disc position of item 16 (relocatable, no disc pos, no patch infos, orig at #0): write at #317762
15:28:21 #31 Text 0 File ThreadedTransferInterface.cpp, Line 2643
Verifying disc position of item 17 (relocatable, no disc pos, no patch infos, orig at #0): write at #336872
15:28:21 #32 Text 0 File Mmc.cpp, Line 16810
StartDAO : CD-Text - On
15:28:21 #33 Text 0 File Mmc.cpp, Line 21592
Set BUFE: SmoothLink -> ON
15:28:21 #34 Text 0 File Mmc.cpp, Line 17099
CueData, Len=304
21 00 00 41 00 00 00 00
21 01 00 00 00 00 00 00
21 01 01 00 00 00 02 00
21 02 00 00 00 04 04 48
21 02 01 00 00 04 06 48
21 03 00 00 00 07 14 42
21 03 01 00 00 07 16 42
21 04 00 00 00 0b 1b 46
21 04 01 00 00 0b 1d 46
21 05 00 00 00 11 19 14
21 05 01 00 00 11 1b 14
21 06 00 00 00 15 1e 4a
21 06 01 00 00 15 20 4a
21 07 00 00 00 1a 33 04
21 07 01 00 00 1a 35 04
21 08 00 00 00 1e 00 1e
21 08 01 00 00 1e 02 1e
21 09 00 00 00 22 11 2a
21 09 01 00 00 22 13 2a
21 0a 00 00 00 26 0e 3b
21 0a 01 00 00 26 10 3b
21 0b 00 00 00 2b 19 17
21 0b 01 00 00 2b 1b 17
21 0c 00 00 00 31 0b 05
21 0c 01 00 00 31 0d 05
21 0d 00 00 00 35 16 35
21 0d 01 00 00 35 18 35
21 0e 00 00 00 38 27 43
21 0e 01 00 00 38 29 43
21 0f 00 00 00 3c 15 00
21 0f 01 00 00 3c 17 00
21 10 00 00 00 40 3b 14
21 10 01 00 00 41 01 14
21 11 00 00 00 46 24 3e
21 11 01 00 00 46 26 3e
21 12 00 00 00 4a 33 2f
21 12 01 00 00 4a 35 2f
01 aa 01 01 00 4f 27 16
15:29:31 #35 SCSI -1135 File Cdrdrv.cpp, Line 1436
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x07240000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x2A 0x00 0x00 0x00 0x44 0xA9 0x00 0x00 0x1B 0x00 0x00 0x00
Sense Data: 0xF1 0x00 0x03 0x00 0x00 0x42 0x36 0x0A
0x00 0x2B 0x00 0x00 0x0C 0x00
15:29:31 #36 CDR -1135 File Writer.cpp, Line 311
Write error
15:29:31 #37 Text 0 File ThreadedTransfer.cpp, Line 228
all writers idle, stopping conversion
15:29:31 #38 Text 0 File ThreadedTransfer.cpp, Line 222
conversion idle, stopping reader
15:29:31 #39 Phase 38 File dlgbrnst.cpp, Line 1832
Burn process failed at 16x (2,400 KB/s)
15:29:31 #40 Text 0 File AudioCompilationImpl.cpp, Line 867
DRM: DRM burn session terminated.
15:29:31 #41 Text 0 File AudioCompilationImpl.cpp, Line 896
DRM: Closing entire DRM handling. Bye.
Existing drivers:
File 'Drivers\CDRALW2K.SYS': Ver=8.0.0.212 , size=2560 bytes, created 27/03/2007 10:55:32
File 'Drivers\PXHELP20.SYS': Ver=3.00.43J, size=36624 bytes, created 27/03/2007 10:55:31 (Prassi/Veritas driver for win 2K)
File 'Drivers\InCDfs.SYS': Ver=4, 3, 15, 1, size=99584 bytes, created 13/05/2005 17:03:52 (InCD4 driver for win NT/2K/XP)
File 'Drivers\InCDpass.SYS': Ver=4, 3, 15, 1, size=29696 bytes, created 13/05/2005 17:03:30 (InCD4 driver for win NT/2K/XP)
File 'Drivers\InCDrec.SYS': Ver=4, 3, 15, 1, size=8704 bytes, created 13/05/2005 17:03:54 (InCD4 driver for win NT/2K/XP)
File 'Drivers\atapi.sys': Ver=5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), size=95360 bytes, created 04/08/2004 00:59:44 (Adapter driver for rec)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Firefox 2.0.0.9
  1. salut,, j'utilise nero start smart 6,, et j gravee de music audio sur cd,,,j meme essayer de gravee les fichier faire un data cd,, pour ajouter un logicier sur mon cd de donne,,j aussi echoue,,, j aussi utiliser windows media player mais j n'arrive pas a termine avec succees
    1. bjr,
      ouououo !!!! t utilise koi kom logiciel de gravure deja ?
      ensuite kel fichier gav tu ? video (divix, dvd, avi...) ou audio (mp3 ,wav...) ?
