Probléme de gravure
Quand je grave un blu-ray j'ai parfois des erreurs :
usi@persoprincipal:~$ cdrskin -v dev=/dev/sr1 -dao /media/usi/Elements/gravuretmp/gg56.iso
cdrskin 1.5.2 : limited cdrecord compatibility wrapper for libburn
cdrskin: verbosity level : 1
cdrskin: NOTE : greying out all drives besides given dev='/dev/sr1'
cdrskin: scanning for devices ...
cdrskin: ... scanning for devices done
cdrskin: beginning to burn disc
cdrskin: status 1 burn_disc_blank "The drive holds a blank disc"
Current: BD-R sequential recording
Track 01: data  44489 MB
Total size:    44489 MB (5061:59.76) = 22778832 sectors
Lout start:    44489 MB (5062:01/76) = 22778982 sectors
Starting to write CD/DVD at speed MAX in real SAO mode for single session.
Last chance to quit, starting real write in   0 seconds. Operation starts.
Waiting for reader process to fill input buffer ... input buffer ready.
Starting new track at sector: 0
Track 01: 24467 of 44489 MB written (fifo 100%) [buf 100%]   4.1x.cdrskin: FATAL : SCSI error on write(12527520,32): [3 0C 00] Medium error. Write error.
cdrskin: FATAL : CDB= WRITE(10) : 2a 00 00 bf 27 a0 00 00 20 00  : dxfer_len= 65536
cdrskin: thank you for being patient for 1461 seconds
Track 01: Total bytes read/written: 25656426496/25656360960 (12527520 sectors).
Writing  time:  1460.752s
Cdrskin: fifo had 12529631 puts and 12527583 gets.
Cdrskin: fifo was 0 times empty and 450367 times full, min fill was 99%.
Min drive buffer fill was 20%
cdrskin: burning failed
cdrskin: FATAL : burning failed.
Marque du bd : MediaRange BD recordable Media double layer BD-R DL 50GB
dmesg me retourne une erreur suspecte :
[10067.712065] [b]sr 9:0:0:0: Power-on or device reset occurred[/b]
[10453.113360] userif-3: sent link down event.
[10453.113364] userif-3: sent link up event.
[12966.698433] ISO 9660 Extensions: RRIP_1991A
Marque du graveur : Initio Corporation external DVD burner ECD819-SU3
Pourquoi ces erreurs ?
Comment y remédier ?
Linux / Firefox 102.0
    OK, tu dis:  "avoir gravé avec succès... et aussi l'erreur est aléatoire"... que faut-il comprendre..??
    S'agit-il de Blue Ray réinscriptible..??  genre R/W.
    1. J'ai regraver 2 BDR mais avec succès.
      L'erreur est aléatoire.
        Il vaut mieux 3A, voir un peu plus...  pour moi, 1A, ce n'est pas suffisant...
        J'ai eu le cas d'un hub livré avec  alimentation de 2A pour un lecteur CD; et ce n'était pas assez... J'ai donc bien conservé le HUB et installé avec une autre alimentation plus puissante  (3.5 A et ça marche)
        Toi aussi, si tu as un HUB, tu peux l'alimenter avec un autre Bloc, le problème c'est la prise... mais tu peux bricoler un peu. Il faut surtout bien respecter le sens des fils  ++++  et ----
        1. Il est alimenter par un adaptateur alimentation 5V 1A,
          Si pas assez je vais en trouver un de 3A.
            OK, à mon avis, c'est la liaison USB 2.0 qui est le problème... ce n'est pas une liaison assez rapide...pour les Datas, de plus, il est bien décrit pour de l'USB3 avec câble USB3.
            De plus, je suppose qu'il est alimenté par le 5 volts de la prise USB..?? et à mon avis, ce n'est pas assez puissant, Il faudrait un système de prise USB alimenté avec sa propre alimentation. ce modèle là ou similaire avec alim de 3 Ampères
            https://www.amazon.fr/RSHTECH-RSH-A37-aluminium-dalimentation-transfert/dp/B08JHYVZQ8/ref=sr_1_27?keywords=hub+usb+3.0+avec+alimentation&qid=1675523279&sr=8-27
            Les prises USB2 sont limités à 500 mA de courant et les USB3 à 900 mA, ce n'est pas assez pour ton graveur... Il doit frôler les 2.5 Ampères... Même en couplant 5 prises USB, ce serait limite...
            Le problème est qu'on ne trouve pas de fiche technique sur cet appareil, qui affiche sa consommation minimum..
            Rien ne vaut le graveur interne... mais essaie ce HUB alimenté, J'ai eu ce problème sur un simple lecteur CD.
            1. Graveur bd externe relié par USB 2.0 et brancher sur USB 2.0.
                Ton graveur de BD est externe...??  il est relié comment au PC..?
                Je pense que la liaison n'est pas assez rapide, alors que tu lui demande d'aller vite..
                Essaie avec une vitesse de gravure assez basse voir lente...
                CDR skin Fatal erreur , donc c'est l'habillage... Ton fichier peut aussi avoir des erreurs..??
