Problème sous android
atcom.example.user.designapp.ProfileActivity.onCreateProfileActi -
Lors de l’exécution de mon application, elle s'affiche "s'est arreté"
    Tu n'as que ça dans les logs?
    A priori, il y a une erreur dans ton fichier xml
    1. 02-26 16:08:26.139 32759-32759/com.example.user.designapp E/dalvikvm: Could not find class 'android.graphics.drawable.RippleDrawable', referenced from method android.support.v7.widget.AppCompatImageHelper.hasOverlappingRendering
      02-26 16:08:26.229 32759-32759/com.example.user.designapp E/AndroidRuntime: FATAL EXCEPTION: main
      Process: com.example.user.designapp, PID: 32759
      java.lang.RuntimeException: Unable to start activity ComponentInfo{com.example.user.designapp/com.example.user.designapp.ProfileActivity}: android.view.InflateException: Binary XML file line #0: Error inflating class ImageView
      at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:2436)
      at android.app.ActivityThread.handleLaunchActivity(ActivityThread.java:2498)
      at android.app.ActivityThread.access$900(ActivityThread.java:179)
      at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1324)
      at android.os.Handler.dispatchMessage(Handler.java:102)
      at android.os.Looper.loop(Looper.java:146)
      at android.app.ActivityThread.main(ActivityThread.java:5641)
      at java.lang.reflect.Method.invokeNative(Native Method)
      at java.lang.reflect.Method.invoke(Method.java:515)
      at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:1288)
      at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:1104)
      at dalvik.system.NativeStart.main(Native Method)
      Caused by: android.view.InflateException: Binary XML file line #0: Error inflating class ImageView
      at android.view.LayoutInflater.createViewFromTag(LayoutInflater.java:719)
      at android.view.LayoutInflater.rInflate(LayoutInflater.java:761)
      at android.view.LayoutInflater.rInflate(LayoutInflater.java:769)
      at android.view.LayoutInflater.inflate(LayoutInflater.java:498)
      at android.view.LayoutInflater.inflate(LayoutInflater.java:398)
      at android.view.LayoutInflater.inflate(LayoutInflater.java:354)
      at android.support.v7.app.AppCompatDelegateImplV9.setContentView(AppCompatDelegateImplV9.java:287)
      at android.support.v7.app.AppCompatActivity.setContentView(AppCompatActivity.java:139)
      at com.example.user.designapp.ProfileActivity.onCreate(ProfileActivity.java:14)
      at android.app.Activity.performCreate(Activity.java:5484)
      at android.app.Instrumentation.callActivityOnCreate(Instrumentation.java:1093)
      at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:2400)
      Caused by: android.content.res.Resources$NotFoundException: Resource is not a Drawable (color or path): TypedValue{t=0x1/d=0x7f06005c a=-1 r=0x7f06005c}
      at android.content.res.Resources.loadDrawable(Resources.java:3402)
      at android.content.res.TypedArray.getDrawable(TypedArray.java:602)
      at android.widget.ImageView.<init>(ImageView.java:133)
      at android.support.v7.widget.AppCompatImageView.<init>(AppCompatImageView.java:72)
      at android.support.v7.widget.AppCompatImageView.<init>(AppCompatImageView.java:68)
      at android.support.v7.app.AppCompatViewInflater.createView(AppCompatViewInflater.java:106)
      at android.support.v7.app.AppCompatDelegateImplV9.createView(AppCompatDelegateImplV9.java:1024)
      at android.support.v7.app.AppCompatDelegateImplV9.onCreateView(AppCompatDelegateImplV9.java:1081)
      at android.view.LayoutInflater.createViewFromTag(LayoutInflater.java:690)
  2. bjr
    On ne sait pas de quoi vous parlez ... si vous pouvez la désinstaller , faites le , puis réinstallez la.
    1. Error: at com.example.user.designapp.ProfileActivity.onCreate(ProfileActivity.java:16)
    2. package com.example.user.designapp;
      import android.support.v7.app.AppCompatActivity;
      import android.os.Bundle;
      import android.view.View;
      import android.widget.Button;
      import android.widget.TextView;
      public class ProfileActivity extends AppCompatActivity {
      private Button button;
      private TextView nom;
      private TextView text;
      @Override
      protected void onCreate(Bundle savedInstanceState) {
      super.onCreate(savedInstanceState);
      setContentView(R.layout.activity_profile);
      button=findViewById(R.id.b1);
      text=findViewById(R.id.text);
      nom=findViewById(R.id.nom);
      button.setOnClickListener(new View.OnClickListener() {
      @Override
      public void onClick(View view) {
      text.setText(nom.getText().toString());
    3. package com.example.user.designapp;
          @Override
