Changement de processeur sur pc portable
bonjour j'aimerai changer de proc sur un ppc portable vers un I7
voila ce que j'ai
2NGCM 1 LABEL, INTEL, NOTEBOOK, PENTIUM, RBDG
RY6YR 1 PROCESSOR, B960, 2.2, SNB, 2C, Q0, P
Service Tag J5Q04S1
Computer Model Inspiron 17R N7110
Shipping Date 12/29/2011
Country France
CPU-Z TXT Report dispo
voila ce que j'ai
Service Tag J5Q04S1
Country France
CPU-Z TXT Report
Binaries
CPU-Z version 1.79.1.x64
Processors
Number of sockets 1
Number of threads 2
APICs
Socket 0
-- Core 0
-- Thread 0 0
-- Core 2
-- Thread 0 2
Timers
ACPI timer 3.580 MHz
Perf timer 2.141 MHz
Sys timer 1.000 KHz
Processors Information
Socket 1 ID = 0
Number of cores 2 (max 2)
Number of threads 2 (max 2)
Name Intel Pentium B960
Codename Sandy Bridge
Specification Intel(R) Pentium(R) CPU B960 @ 2.20GHz
Package (platform ID) Socket 988B rPGA (0x4)
CPUID 6.A.7
Extended CPUID 6.2A
Core Stepping D2
Technology 32 nm
TDP Limit 35.0 Watts
Tjmax 85.0 °C
Core Speed 2193.2 MHz
Multiplier x Bus Speed 22.0 x 99.7 MHz
Stock frequency 2200 MHz
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T
L1 Data cache 2 x 32 KBytes, 8-way set associative, 64-byte line size
L1 Instruction cache 2 x 32 KBytes, 8-way set associative, 64-byte line size
L2 cache 2 x 256 KBytes, 8-way set associative, 64-byte line size
L3 cache 2 MBytes, 8-way set associative, 64-byte line size
Max CPUID level 0000000Dh
Max CPUID ext. level 80000008h
Cache descriptor Level 1, D, 32 KB, 2 thread(s)
Cache descriptor Level 1, I, 32 KB, 2 thread(s)
Cache descriptor Level 2, U, 256 KB, 2 thread(s)
Cache descriptor Level 3, U, 2 MB, 16 thread(s)
FID/VID Control yes
Turbo Mode not supported
Max non-turbo ratio 22x
Max turbo ratio 22x
Max efficiency ratio 8x
Max Power 44 Watts
Min Power 24 Watts
O/C bins none
Ratio 1 core 22x
Ratio 2 cores 22x
Ratio 3 cores 22x
Ratio 4 cores 22x
Temperature 0 63 degC (145 degF) (Package)
Temperature 1 63 degC (145 degF) (Core #0)
Temperature 2 63 degC (145 degF) (Core #2)
Voltage 0 1.16 Volts (VID)
Power 0 10.30 W (Package)
Power 1 5.71 W (IA Cores)
Power 2 1.22 W (GT)
Power 3 3.38 W (Uncore)
Clock Speed 0 2193.19 MHz (Core #0)
Clock Speed 1 2193.19 MHz (Core #2)
Core 0 max ratio 22.0 (effective 22.0)
Core 1 max ratio 22.0 (effective 22.0)
Thread dumps
CPU Thread 0
APIC ID 0
Topology Processor ID 0, Core ID 0, Thread ID 0
CPUID
0x00000000 0x0000000D 0x756E6547 0x6C65746E 0x49656E69
0x00000001 0x000206A7 0x00100800 0x0DBAE39F 0xBFEBFBFF
0x00000002 0x76035A01 0x00F0B0FF 0x00000000 0x00CA0000
0x00000003 0x00000000 0x00000000 0x00000000 0x00000000
0x00000004 0x1C004121 0x01C0003F 0x0000003F 0x00000000
0x00000004 0x1C004122 0x01C0003F 0x0000003F 0x00000000
0x00000004 0x1C004143 0x01C0003F 0x000001FF 0x00000000
0x00000004 0x1C03C163 0x01C0003F 0x00000FFF 0x00000006
0x00000005 0x00000040 0x00000040 0x00000003 0x00021120
0x00000006 0x00000075 0x00000002 0x00000009 0x00000000
0x00000007 0x00000000 0x00000000 0x00000000 0x00000000
0x00000008 0x00000000 0x00000000 0x00000000 0x00000000
0x00000009 0x00000000 0x00000000 0x00000000 0x00000000
0x0000000A 0x07300803 0x00000000 0x00000000 0x00000603
0x0000000B 0x00000001 0x00000001 0x00000100 0x00000000
0x0000000B 0x00000004 0x00000002 0x00000201 0x00000000
0x0000000C 0x00000000 0x00000000 0x00000000 0x00000000
0x0000000D 0x00000003 0x00000240 0x00000240 0x00000000
0x0000000D 0x00000001 0x00000000 0x00000000 0x00000000
0x80000000 0x80000008 0x00000000 0x00000000 0x00000000
0x80000001 0x00000000 0x00000000 0x00000001 0x28100800
0x80000002 0x20202020 0x20202020 0x746E4920 0x52286C65
0x80000003 0x65502029 0x7569746E 0x2952286D 0x55504320
0x80000004 0x36394220 0x20402030 0x30322E32 0x007A4847
0x80000005 0x00000000 0x00000000 0x00000000 0x00000000
0x80000006 0x00000000 0x00000000 0x01006040 0x00000000
0x80000007 0x00000000 0x00000000 0x00000000 0x00000100
0x80000008 0x00003024 0x00000000 0x00000000 0x00000000
MSR 0x0000001B 0x00000000 0xFEE00900
MSR 0x000001A0 0x00000000 0x00850088
MSR 0x000000CE 0x00000800 0x60011600
MSR 0x00000017 0x00100000 0x00000000
MSR 0x00000035 0x00000000 0x00020002
MSR 0x000000C1 0x00000000 0x00000000
MSR 0x000000C2 0x00000000 0x00000000
MSR 0x000000C3 0x00000000 0x00000000
MSR 0x000000C4 0x00000000 0x00000000
MSR 0x00000186 0x00000000 0x00000000
MSR 0x00000187 0x00000000 0x00000000
MSR 0x000001AD 0x00000000 0x16161616
MSR 0x00000194 0x00000000 0x00010000
MSR 0x0000019A 0x00000000 0x00000000
MSR 0x000001A4 0x00000000 0x00000000
MSR 0x000001FC 0x00000000 0x0004005F
MSR 0x00000601 0x18141494 0x8000030C
MSR 0x00000602 0x18141494 0x80000104
MSR 0x00000606 0x00000000 0x000A1003
MSR 0x00000610 0x0000815E 0x00148118
MSR 0x00000611 0x00000000 0x131C7AC0
MSR 0x00000639 0x00000000 0x9EF92B26
MSR 0x00000641 0x00000000 0x1A0F47E1
MSR 0x00000614 0x000F0160 0x00C00118
MSR 0x0000019C 0x00000000 0x880F0000
MSR 0x000001A2 0x00000000 0x00550500
MSR 0x000001B1 0x00000000 0x880F0180
MSR 0x00000198 0x00002526 0x00001600
MSR 0x00000199 0x00000000 0x00001600
CPU Thread 1
APIC ID 2
Topology Processor ID 0, Core ID 2, Thread ID 0
CPUID
0x00000001 0x000206A7 0x02100800 0x0DBAE39F 0xBFEBFBFF
0x0000000B 0x00000001 0x00000001 0x00000100 0x00000002
0x0000000B 0x00000004 0x00000002 0x00000201 0x00000002
MSR 0x0000001B 0x00000000 0xFEE00800
MSR 0x00000611 0x00000000 0x131CBA18
MSR 0x00000639 0x00000000 0x9EF95AF6
MSR 0x00000641 0x00000000 0x1A0F4B5B
MSR 0x0000019C 0x00000000 0x88100000
MSR 0x000001B1 0x00000000 0x88100180
Chipset
Northbridge Intel Sandy Bridge rev. 09
Southbridge Intel HM67 rev. B3
Memory Type DDR3
Memory Size 8 GBytes
Channels Dual
Memory Frequency 664.6 MHz (1:5)
CAS# latency (CL) 9.0
RAS# to CAS# delay (tRCD) 9
RAS# Precharge (tRP) 9
Cycle Time (tRAS) 24
Command Rate (CR) 1T
Host Bridge 0x0104
Memory SPD
DIMM # 1
SMBus address 0x50
Memory type DDR3L
Module format SO-DIMM
Manufacturer (ID) Samsung (CE00000000000000000000)
Size 4096 MBytes
Max bandwidth PC3-12800 (800 MHz)
Part number M471B5273CH0-YK0
Serial number E15003EF
Manufacturing date Week 40/Year 12
Number of banks 8
Nominal Voltage 1.35 Volts
EPP no
XMP no
AMP no
JEDEC timings table CL-tRCD-tRP-tRAS-tRC @ frequency
JEDEC #1 5.0-5-5-14-19 @ 380 MHz
JEDEC #2 6.0-6-6-16-22 @ 457 MHz
JEDEC #3 7.0-7-7-19-26 @ 533 MHz
JEDEC #4 8.0-8-8-22-30 @ 609 MHz
JEDEC #5 9.0-9-9-24-33 @ 685 MHz
JEDEC #6 10.0-10-10-27-37 @ 761 MHz
JEDEC #7 11.0-11-11-28-39 @ 800 MHz
DIMM # 2
SMBus address 0x52
Memory type DDR3
Size 4096 MBytes
Max bandwidth PC3-10700 (667 MHz)
Part number M471B5273CH0-CH9
Serial number 845C7B0E
Manufacturing date Week 03/Year 11
Number of banks 8
Nominal Voltage 1.50 Volts
EPP no
XMP no
AMP no
JEDEC #2 6.0-6-6-17-23 @ 457 MHz
JEDEC #3 7.0-7-7-20-27 @ 533 MHz
JEDEC #5 9.0-9-9-24-33 @ 666 MHz
DIMM # 1
SPD registers
00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
00 92 10 0B 03 03 19 02 09 03 52 01 08 0A 00 FE 00
10 69 78 69 30 69 11 18 81 00 05 3C 3C 00 F0 83 01
20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 00 00 00 00 00 00 00 00 0F 11 65 00
40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
70 00 00 00 00 00 80 CE 03 12 40 E1 50 03 EF B5 E7
80 4D 34 37 31 42 35 32 37 33 43 48 30 2D 59 4B 30
90 20 20 00 00 80 CE 00 00 00 4B 30 45 53 30 30 30
A0 01 00 01 00 00 00 00 00 00 00 00 00 00 00 E1 02
B0 00 00 00 00 00 00 00 00 00 00 00 00 00 30 34 00
C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
DIMM # 2
SPD registers
00 92 10 0B 03 03 19 00 09 03 52 01 08 0C 00 3E 00
10 69 78 69 30 69 11 20 89 00 05 3C 3C 00 F0 83 01
30 00 00 00 00 00 00 00 00 00 00 00 00 0F 11 45 00
70 00 00 00 00 00 80 CE 02 11 03 84 5C 7B 0E 0E 59
80 4D 34 37 31 42 35 32 37 33 43 48 30 2D 43 48 39
90 20 20 00 00 80 CE 00 00 00 53 31 41 56 4A 31 30
A0 01 00 00 00 00 00 00 00 00 00 00 00 00 30 31 05
B0 01 A0 04 97 20 04 45 38 00 00 00 00 00 00 00 00
Monitoring
Mainboard Model 0YH79Y (0x0000019A - 0x005A6D20)
LPCIO
Hardware Monitors
Hardware monitor Battery
Voltage 0 12.44 Volts [0x309B] (Current Voltage)
Capacity 0 48840 mWh [0xBEC8] (Designed Capacity)
Capacity 1 7004 mWh [0x1B5C] (Full Charge Capacity)
Capacity 2 7004 mWh [0x1B5C] (Current Capacity)
Level 0 86 pc [0xE] (Wear Level)
Level 1 100 pc [0x64] (Charge Level)
PCI Devices
Description Host Bridge
Location bus 0 (0x00), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x0104
Revision ID 0x09
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Subvendor ID 0x1028
Subsystem ID 0x04D8
Int. Line 0x00
Int. Pin 0x00
PCI capability
Caps class Vendor Dependant
Caps offset 0xE0
PCI registers
00 86 80 04 01 06 00 90 20 09 00 00 06 00 00 00 00
10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 28 10 D8 04
30 00 00 00 00 E0 00 00 00 00 00 00 00 00 00 00 00
40 01 90 D1 FE 00 00 00 00 01 00 D1 FE 00 00 00 00
50 11 02 00 00 11 00 00 00 0F 00 90 BF 01 00 00 BB
60 05 00 00 F8 00 00 00 00 01 80 D1 FE 00 00 00 00
70 00 00 80 FF 01 00 00 00 00 0C 80 FF 7F 00 00 00
80 10 11 11 11 11 11 11 00 1A 00 00 00 00 00 00 00
90 01 00 80 FF 01 00 00 00 01 00 D0 3F 02 00 00 00
A0 01 00 00 00 02 00 00 00 01 00 E0 3F 02 00 00 00
B0 01 00 A0 BB 01 00 80 BB 01 00 00 BB 01 00 A0 BF
E0 09 00 0C 01 96 61 80 E2 90 00 00 02 00 00 00 00
F0 00 00 00 01 00 00 00 00 B8 0F 06 00 00 00 00 00
Description VGA Controller
Location bus 0 (0x00), device 2 (0x02), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x0106
Revision ID 0x09
PI 0x00
SubClass 0x00
BaseClass 0x03
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xD0000000
Address 2 (memory) 0xC0000000
Address 4 (port) 0x00003000
Subvendor ID 0x1028
Subsystem ID 0x04D8
Int. Line 0x00
Int. Pin 0x01
PCI capability
Caps class Message Signalled Interrupts
Caps offset 0x90
PCI capability
Caps class Power Management
Caps offset 0xD0
Caps version 1.1
PCI capability
Caps class 0x13
Caps offset 0xA4
PCI registers
00 86 80 06 01 07 04 90 00 09 00 00 03 00 00 00 00
10 04 00 00 D0 00 00 00 00 0C 00 00 C0 00 00 00 00
20 01 30 00 00 00 00 00 00 00 00 00 00 28 10 D8 04
30 00 00 00 00 90 00 00 00 00 00 00 00 00 01 00 00
40 09 00 0C 01 96 61 80 E2 90 00 00 02 00 00 00 00
50 11 02 00 00 11 00 00 00 00 00 00 00 01 00 A0 BB
60 00 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00
70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
90 05 D0 01 00 0C 30 E0 FE 61 49 00 00 00 00 00 00
A0 00 00 00 00 13 00 06 03 00 00 00 00 00 00 00 00
B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D0 01 A4 22 00 00 00 00 00 00 00 00 00 00 00 00 00
E0 00 00 00 00 00 00 00 00 00 80 00 00 00 00 00 00
F0 00 00 00 00 00 00 00 00 00 00 06 00 18 00 E1 BA
Description Communication Device
Location bus 0 (0x00), device 22 (0x16), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x1C3A
Revision ID 0x04
PI 0x00
SubClass 0x80
BaseClass 0x07
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Address 0 (memory) 0xD0705000
Subvendor ID 0x1028
Subsystem ID 0x04D8
Int. Line 0x00
Int. Pin 0x01
PCI capability
Caps offset 0x50
Caps version 1.2
PCI capability
Caps offset 0x8C
PCI registers
00 86 80 3A 1C 06 04 10 00 04 00 80 07 00 00 80 00
10 04 50 70 D0 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 50 00 00 00 00 00 00 00 00 01 00 00
40 45 02 00 1E 08 00 01 80 06 00 00 60 F8 1F 00 10
50 01 8C 03 C8 08 00 00 00 00 00 00 00 00 00 00 00
80 00 00 00 00 00 00 00 00 00 00 00 00 05 00 81 00
90 0C 30 E0 FE 00 00 00 00 51 49 00 00 00 00 00 00
A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B0 00 00 00 00 00 00 00 00 00 00 00 00 02 00 00 C0
C0 35 83 28 70 EF B0 4E BF 10 BF 6D F7 22 8A 6B 30
D0 25 C0 D9 81 1E F6 25 9B 3D 85 64 4E CE 26 D5 9E
Description USB 2.0 Controller (EHCI)
Location bus 0 (0x00), device 26 (0x1A), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x1C2D
Revision ID 0x05
PI 0x20
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xD070A000
Subvendor ID 0x1028
Subsystem ID 0x04D8
Int. Line 0x10
Int. Pin 0x01
PCI capability
Caps offset 0x50
Caps version 1.1
PCI capability
Caps class Debug Port
Caps offset 0x58
PCI capability
Caps class 0x13
Caps offset 0x98
PCI registers
00 86 80 2D 1C 06 00 90 02 05 20 03 0C 00 00 00 00
10 00 A0 70 D0 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 50 00 00 00 00 00 00 00 10 01 00 00
50 01 58 C2 C9 00 00 00 00 0A 98 A0 20 00 00 00 00
60 20 20 FF 07 00 00 00 00 01 00 00 01 00 20 00 C0
70 00 00 DF 3F 00 00 00 00 00 00 00 00 00 00 00 00
80 00 00 80 00 11 88 0C 93 30 0D 00 24 00 00 00 00
90 00 00 00 00 00 00 00 00 13 00 06 03 00 00 00 00
D0 00 00 00 00 00 AA FF 00 00 00 00 00 00 00 00 00
E0 00 00 00 00 00 00 00 00 00 00 00 00 04 80 C0 BA
F0 00 00 00 00 88 85 80 00 87 0F 06 08 08 17 5B 20
Description Multimedia device
Location bus 0 (0x00), device 27 (0x1B), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x1C20
Revision ID 0x05
PI 0x00
SubClass 0x03
BaseClass 0x04
Cache Line 0x10
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xD0700000
Subvendor ID 0x1028
Subsystem ID 0x04D8
Int. Line 0x16
Int. Pin 0x01
PCI capability
Caps offset 0x50
Caps version 1.1
PCI capability
Caps offset 0x60
PCI capability
Caps class PCI Express
Caps offset 0x70
Device type Root Complex Integrated Endpoint Device
Port 0
Version 1.0
Link width 0x (max 0x)
PCI registers
00 86 80 20 1C 06 00 10 00 05 00 03 04 10 00 00 00
10 04 00 70 D0 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 50 00 00 00 00 00 00 00 16 01 00 00
40 01 00 00 45 00 00 00 00 00 00 00 00 00 00 00 00
50 01 60 42 C8 00 00 00 00 00 00 00 00 00 00 00 00
60 05 70 80 00 00 00 00 00 00 00 00 00 00 00 00 00
70 10 00 91 00 00 00 00 10 00 08 10 00 00 00 00 00
90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
C0 00 04 00 01 02 24 00 40 00 0C A3 82 10 00 33 02
D0 00 0C A3 02 10 00 33 02 00 00 00 00 00 00 00 00
F0 00 00 00 00 00 00 00 00 87 0F 06 08 00 00 00 00
Description PCI to PCI Bridge
Location bus 0 (0x00), device 28 (0x1C), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x1C10
Revision ID 0xB5
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x10
Latency 0x00
Header 0x81
PCI header
Primary bus 0x00
Secondary bus 0x01
Int. Line 0x0B
Int. Pin 0x01
PCI capability
Caps offset 0x40
Device type Root Port of PCI-E Root Complex
Port 1
Version 2.0
Physical slot #0
Presence detect yes
Link width 1x (max 1x)
PCI capability
Caps offset 0x80
PCI capability
Caps class Subsystem Vendor
Caps offset 0x90
SubVendor ID 0x1028
SubSystem ID 0x04D8
PCI capability
Caps offset 0xA0
Caps version 1.1
PCI registers
00 86 80 10 1C 06 04 10 00 B5 00 04 06 10 00 81 00
10 00 00 00 00 00 00 00 00 00 01 01 00 F0 00 00 00
20 60 D0 60 D0 F1 FF 01 00 00 00 00 00 00 00 00 00
30 00 00 00 00 40 00 00 00 00 00 00 00 0B 01 00 00
40 10 80 42 01 00 80 00 00 00 00 10 00 12 3C 12 01
50 42 00 11 70 00 B2 04 00 00 00 40 01 00 00 00 00
60 00 00 00 00 16 00 00 00 00 00 00 00 00 00 00 00
70 02 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00
80 05 90 00 00 00 00 00 00 00 00 00 00 00 00 00 00
90 0D A0 00 00 28 10 D8 04 00 00 00 00 00 00 00 00
A0 01 00 02 C8 00 00 00 00 00 00 00 00 00 00 00 00
D0 00 00 00 01 02 0B 00 00 00 80 11 01 00 00 00 00
E0 00 3F 00 00 00 00 00 00 01 00 00 00 00 00 00 00
Location bus 0 (0x00), device 28 (0x1C), function 2 (0x02)
Common header
Vendor ID 0x8086
Model ID 0x1C14
Revision ID 0xB5
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x10
Latency 0x00
Header 0x81
PCI header
Primary bus 0x00
Secondary bus 0x02
Int. Line 0x0A
Int. Pin 0x03
PCI capability
Caps offset 0x40
Port 3
Version 2.0
Physical slot #0
Presence detect yes
PCI capability
Caps offset 0x80
PCI capability
Caps offset 0x90
SubVendor ID 0x1028
SubSystem ID 0x04D8
PCI capability
Caps offset 0xA0
Caps version 1.1
PCI registers
00 86 80 14 1C 06 04 10 00 B5 00 04 06 10 00 81 00
10 00 00 00 00 00 00 00 00 00 02 02 00 F0 00 00 00
20 50 D0 50 D0 F1 FF 01 00 00 00 00 00 00 00 00 00
30 00 00 00 00 40 00 00 00 00 00 00 00 0A 03 00 00
40 10 80 42 01 00 80 00 00 00 00 10 00 12 3C 12 03
50 42 00 12 70 00 B2 14 00 00 00 40 01 00 00 00 00
70 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
E0 00 03 00 00 00 00 00 00 01 00 00 00 00 00 00 00
Location bus 0 (0x00), device 28 (0x1C), function 4 (0x04)
Common header
Vendor ID 0x8086
Model ID 0x1C18
Revision ID 0xB5
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x10
Latency 0x00
Header 0x81
PCI header
Primary bus 0x00
Secondary bus 0x03
Int. Line 0x0B
Int. Pin 0x01
PCI capability
Caps offset 0x40
Port 5
Version 2.0
Physical slot #0
Presence detect yes
PCI capability
Caps offset 0x80
PCI capability
Caps offset 0x90
SubVendor ID 0x1028
SubSystem ID 0x04D8
PCI capability
Caps offset 0xA0
Caps version 1.1
PCI registers
00 86 80 18 1C 07 04 10 00 B5 00 04 06 10 00 81 00
10 00 00 00 00 00 00 00 00 00 03 03 00 20 20 00 00
20 F0 FF 00 00 41 D0 41 D0 00 00 00 00 00 00 00 00
40 10 80 42 01 00 80 00 00 00 00 10 00 12 3C 12 05
50 42 00 11 70 00 B2 24 00 00 00 40 01 00 00 00 00
Location bus 0 (0x00), device 29 (0x1D), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x1C26
Revision ID 0x05
PI 0x20
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xD0709000
Subvendor ID 0x1028
Subsystem ID 0x04D8
Int. Line 0x17
Int. Pin 0x01
PCI capability
Caps offset 0x50
Caps version 1.1
PCI capability
Caps offset 0x58
PCI capability
Caps class 0x13
Caps offset 0x98
PCI registers
00 86 80 26 1C 06 00 90 02 05 20 03 0C 00 00 00 00
10 00 90 70 D0 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 50 00 00 00 00 00 00 00 17 01 00 00
E0 00 00 00 00 00 00 00 00 00 00 00 00 84 C0 C2 BA
Description PCI to ISA Bridge
Location bus 0 (0x00), device 31 (0x1F), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x1C4B
Revision ID 0x05
PI 0x00
SubClass 0x01
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x1028
Subsystem ID 0x04D8
Int. Line 0x00
Int. Pin 0x00
PCI capability
Caps offset 0xE0
PCI registers
00 86 80 4B 1C 07 00 10 02 05 00 01 06 00 00 80 00
40 01 04 00 00 80 00 00 00 01 05 00 00 10 00 00 00
50 F8 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60 8B 80 8A 8B D0 00 00 00 80 80 8A 89 F8 F0 00 00
70 78 00 79 00 7A 00 7B 00 7C 00 7D 00 7E 00 7F 00
80 10 00 0F 3F 69 00 04 00 11 09 04 00 00 00 00 00
90 A1 06 0C 00 00 0F 00 00 00 00 00 00 00 00 00 00
A0 04 0A 80 00 01 10 06 00 00 47 00 00 00 00 00 80
B0 00 00 00 00 00 00 00 00 84 88 00 24 00 00 00 00
D0 0F 00 00 00 67 45 00 00 00 FF 00 00 08 00 00 00
E0 09 00 0C 10 00 00 00 00 93 02 64 0E 00 00 00 00
F0 01 C0 D1 FE 00 00 00 00 87 0F 06 08 00 00 00 00
Description Serial ATA Controller
Location bus 0 (0x00), device 31 (0x1F), function 2 (0x02)
Common header
Vendor ID 0x8086
Model ID 0x1C03
Revision ID 0x05
PI 0x01
SubClass 0x06
BaseClass 0x01
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 0 (port) 0x00003088
Address 1 (port) 0x00003094
Address 2 (port) 0x00003080
Address 3 (port) 0x00003090
Address 4 (port) 0x00003060
Address 5 (memory) 0xD0708000
Subvendor ID 0x1028
Subsystem ID 0x04D8
Int. Line 0x00
Int. Pin 0x02
PCI capability
Caps offset 0x80
PCI capability
Caps offset 0x70
Caps version 1.2
PCI capability
Caps class 0x12
Caps offset 0xA8
PCI capability
Caps class 0x13
Caps offset 0xB0
PCI registers
00 86 80 03 1C 07 04 B0 02 05 01 06 01 00 00 00 00
10 89 30 00 00 95 30 00 00 81 30 00 00 91 30 00 00
20 61 30 00 00 00 80 70 D0 00 00 00 00 28 10 D8 04
30 00 00 00 00 80 00 00 00 00 00 00 00 00 02 00 00
40 00 80 00 80 00 00 00 00 00 00 00 00 00 00 00 00
70 01 A8 03 40 08 00 00 00 00 00 00 00 00 00 00 00
80 05 70 01 00 0C 30 E0 FE 50 49 00 00 00 00 00 00
90 60 2C 13 83 83 01 00 2C 08 42 5C 01 00 00 00 00
A0 E0 00 00 00 39 00 39 00 12 B0 10 00 48 00 00 00
B0 13 00 06 03 00 00 00 00 00 00 00 00 00 00 00 00
C0 00 00 00 00 05 00 00 00 00 00 00 00 00 00 00 00
Description SMBus Controller
Location bus 0 (0x00), device 31 (0x1F), function 3 (0x03)
Common header
Vendor ID 0x8086
Model ID 0x1C22
Revision ID 0x05
PI 0x00
SubClass 0x05
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xD0704000
Address 4 (port) 0x0000EFA0
Subvendor ID 0x1028
Subsystem ID 0x04D8
Int. Line 0x0A
Int. Pin 0x03
PCI registers
00 86 80 22 1C 03 00 80 02 05 00 05 0C 00 00 00 00
10 04 40 70 D0 00 00 00 00 00 00 00 00 00 00 00 00
20 A1 EF 00 00 00 00 00 00 00 00 00 00 28 10 D8 04
30 00 00 00 00 00 00 00 00 00 00 00 00 0A 03 00 00
40 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60 03 04 04 00 00 00 08 08 00 00 00 00 00 00 00 00
80 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Description Network Controller
Location bus 1 (0x01), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x168C
Model ID 0x002B
Revision ID 0x01
PI 0x00
SubClass 0x80
BaseClass 0x02
Cache Line 0x10
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xD0600000
Subvendor ID 0x1028
Subsystem ID 0x0205
Int. Line 0x10
Int. Pin 0x01
PCI capability
Caps offset 0x40
Caps version 1.2
PCI capability
Caps offset 0x50
PCI capability
Caps offset 0x60
Device type Legacy PCI-E Endpoint Device
Port 0
Version 2.0
PCI registers
00 8C 16 2B 00 46 01 10 00 01 00 80 02 10 00 00 00
10 04 00 60 D0 00 00 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 28 10 05 02
30 00 00 00 00 40 00 00 00 00 00 00 00 10 01 00 00
40 01 50 C3 5B 00 00 00 00 00 00 00 00 00 00 00 00
50 05 60 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60 10 00 12 00 C0 8C 90 05 10 20 09 00 11 3C 03 00
70 42 00 11 10 00 00 00 00 00 00 00 00 00 00 00 00
80 00 00 00 00 10 00 00 00 00 00 00 00 00 00 00 00
Description USB Controller
Location bus 2 (0x02), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x1033
Model ID 0x0194
Revision ID 0x04
PI 0x30
SubClass 0x03
BaseClass 0x0C
Cache Line 0x10
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xD0500000
Subvendor ID 0x1028
Subsystem ID 0x04D8
Int. Line 0x00
Int. Pin 0x01
PCI capability
Caps offset 0x50
Caps version 1.2
PCI capability
Caps offset 0x70
PCI capability
Caps class MSI-X
Caps offset 0x90
PCI capability
Caps offset 0xA0
Device type PCI-E Endpoint Device
Port 0
Version 2.0
PCI registers
00 33 10 94 01 06 04 10 00 04 30 03 0C 10 00 00 00
10 04 00 50 D0 00 00 00 00 00 00 00 00 00 00 00 00
50 01 70 C3 C9 08 00 00 00 00 00 00 00 00 00 00 00
60 30 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00
70 05 90 86 00 00 00 00 00 00 00 00 00 00 00 00 00
90 11 A0 07 80 00 10 00 00 80 10 00 00 00 00 00 00
A0 10 00 02 00 C0 8F 00 00 00 28 19 00 12 EC 07 00
B0 42 01 12 10 00 00 00 00 00 00 00 00 00 00 00 00
C0 00 00 00 00 10 08 00 00 00 00 00 00 00 00 00 00
D0 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
E0 FC 1F 00 00 00 00 00 00 00 00 00 00 00 00 00 00
F0 08 14 60 00 00 00 00 00 00 00 00 00 00 00 00 00
Description Ethernet Controller
Location bus 3 (0x03), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x10EC
Model ID 0x8136
Revision ID 0x05
PI 0x00
SubClass 0x00
BaseClass 0x02
Cache Line 0x10
Latency 0x00
Header 0x00
PCI header
Address 0 (port) 0x00002000
Address 2 (memory) 0xD0404000
Address 4 (memory) 0xD0400000
Subvendor ID 0x1028
Subsystem ID 0x04D8
Int. Line 0x00
Int. Pin 0x01
PCI capability
Caps offset 0x40
Caps version 1.2
PCI capability
Caps offset 0x50
PCI capability
Caps offset 0x70
Port 0
Version 2.0
PCI capability
Caps class MSI-X
Caps offset 0xB0
PCI capability
Caps class Virtual Product Data
Caps offset 0xD0
PCI registers
00 EC 10 36 81 07 04 10 00 05 00 00 02 10 00 00 00
10 01 20 00 00 00 00 00 00 0C 40 40 D0 00 00 00 00
20 0C 00 40 D0 00 00 00 00 00 00 00 00 28 10 D8 04
30 00 00 00 00 40 00 00 00 00 00 00 00 00 01 00 00
40 01 50 C3 FF 08 00 00 00 00 00 00 00 00 00 00 00
50 05 70 80 00 00 00 00 00 00 00 00 00 00 00 00 00
70 10 B0 02 02 C0 8C 90 05 10 20 19 00 11 7C 07 00
80 40 00 11 10 00 00 00 00 00 00 00 00 00 00 00 00
90 00 00 00 00 10 00 00 00 10 00 00 00 00 00 00 00
B0 11 D0 03 80 04 00 00 00 04 08 00 00 00 00 00 00
D0 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
DMI
DMI BIOS
vendor Dell Inc.
version A13
date 09/05/2012
ROM size 2560 KB
DMI System Information
manufacturer Dell Inc.
product Dell System Inspiron N7110
version unknown
serial J5Q04S1
UUID {4C4C4544-0035-5110-8030-CAC04F345331}
SKU System SKUNumber
family HuronRiver System
DMI Baseboard
vendor Dell Inc.
model 0YH79Y
revision A00
serial .J5Q04S1.CN486431CT0788.
DMI System Enclosure
chassis type Portable
chassis serial J5Q04S1
DMI Port Connector
designation None (internal)
designation Keyboard (external)
port type Keyboard Port
connector PS/2
DMI Port Connector
designation Mouse (external)
port type Mouse Port
connector PS/2
DMI Port Connector
designation COM 1 (external)
port type Serial Port 16550A
DMI Port Connector
designation USB2.0 - 1# (external)
port type USB
connector Access Bus (USB)
DMI Port Connector
designation USB2.0 - 2# (external)
port type USB
DMI Port Connector
designation USB2.0 - 3# (external)
port type USB
DMI Port Connector
designation USB2.0 - 4# (external)
port type USB
DMI Port Connector
designation USB2.0 - 5# (external)
port type USB
DMI Port Connector
designation USB2.0 - 6# (external)
port type USB
DMI Port Connector
designation USB2.0 - 7# (external)
port type USB
DMI Port Connector
designation USB2.0 - 8# (external)
port type USB
DMI Port Connector
designation USB2.0 - 9# (external)
port type USB
DMI Port Connector
designation USB2.0 - 10# (external)
port type USB
DMI Port Connector
designation USB2.0 - 11# (external)
port type USB
DMI Port Connector
designation USB2.0 - 12# (external)
port type USB
DMI Port Connector
designation USB2.0 - 13# (external)
port type USB
DMI Port Connector
designation USB2.0 - 14# (external)
port type USB
DMI Port Connector
designation Ethernet (external)
port type Network Port
connector RJ-45
DMI Port Connector
designation SATA Port 1 J8J1 (internal)
designation None (external)
DMI Port Connector
designation SATA Port 2 J7G1 (internal)
DMI Port Connector
designation SATA Port 3(ODD) J9E7 (internal)
DMI Port Connector
designation eSATA Port 1 J6J1 (external)
DMI Port Connector
designation eSATA Port 2 J7J1 (external)
DMI Port Connector
designation SATA Port 6(Docking) (external)
DMI Extension Slot
designation PEG Gen1/Gen2 X16
type AA
populated no
DMI Extension Slot
designation PCI-Express 1 X1
type A5
populated yes
DMI Extension Slot
designation PCI-Express 2 X1
type A5
populated no
DMI Extension Slot
designation PCI-Express 3 X1
type A5
populated yes
DMI Extension Slot
designation PCI-Express 4 X1
type A5
populated no
DMI Extension Slot
designation PCI-Express 5 X1
type A5
populated yes
DMI Processor
manufacturer Intel(R) Corporation
model Intel(R) Pentium(R) CPU B960 @ 2.20GHz
clock speed 2200.0 MHz
FSB speed 100.0 MHz
multiplier 22.0x
DMI Physical Memory Array
location Motherboard
usage System Memory
correction None
max capacity 8192 MBytes
max# of devices 2
DMI Memory Device
designation ChannelA-DIMM0
format SODIMM
type unknown
total width 64 bits
data width 64 bits
size 4096 MBytes
DMI Memory Device
designation ChannelB-DIMM0
format SODIMM
type unknown
total width 64 bits
data width 64 bits
size 4096 MBytes
DMI OEM Strings
string[0] Dell System
string[1] 1[04D8]
string[2] 13[PP36S]
Storage
Drive 0
Device Path \\?\usbstor#disk&ven_generic-&prod_multi-card&rev_1.00#20090516388200000&0#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}
Type Removable
Bus Type 7
Name Generic- Multi-Card
SMART Support Yes
Drive 1
Device Path \\?\scsi#disk&ven_toshiba&prod_mq01abd075#4&37da4fbe&0&000000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}
Type Fixed
Bus Type 11
Name TOSHIBA MQ01ABD075
Capacity 698.6 GB
SMART Support Yes
Volume c:\, 340.9 GBytes (60.0 percent available)
Volume d:\, 356.8 GBytes (80.6 percent available)
USB Devices
USB Device Generic USB Hub, class=0x09, subclass=0x00, vendor=0x8087, product=0x0024
USB Device Dispositif de stockage de masse USB, class=0x00, subclass=0x00, vendor=0x0BDA, product=0x0138
USB Device Périphérique USB composite, class=0xEF, subclass=0x02, vendor=0x1BCF, product=0x2980
USB Device Périphérique USB composite, class=0x00, subclass=0x00, vendor=0x1D57, product=0xFA20
USB Device Qualcomm Atheros AR3011 Bluetooth 3.0, class=0xE0, subclass=0x01, vendor=0x0CF3, product=0x3002
Graphics
Number of adapters 1
Graphic APIs
API Intel I/O
Display Adapters
Display adapter 0
ID 0x4000000
Display name \\.\DISPLAY1
Name Intel(R) HD Graphics
Board Manufacturer 0x1028 (0x04D8)
PCI device bus 0 (0x0), device 2 (0x2), function 0 (0x0)
Vendor ID 0x8086 (0x1028)
Model ID 0x0106 (0x04D8)
Performance Level 0
Win32_VideoController AdapterRAM = 0x83C00000 (2210398208)
Win32_VideoController DriverVersion = 9.17.10.4459
Win32_VideoController DriverDate = 05/19/2016
Monitor 0
Model (Seiko Epson)
ID SEC544B
Serial
Manufacturing Date Week 0, Year 2010
Size 17.1 inches
Max Resolution 1600 x 900 @ 60 Hz
Horizontal Freq. Range 0-0 kHz
Vertical Freq. Range 0-0 Hz
Max Pixel Clock 0 MHz
Gamma Factor 2.2
Software
Windows Version Microsoft Windows 10 (10.0) Professional 64-bit (Build 15063)
DirectX Version 12.0
Register Spaces
Register space PCI
Register space PCI #2
Register space SMBus, base address = 0x0EFA0
Le processeur le disque dur et la ram se change sur les pcS portable.
@madmykePour moi tout est ok pour le prix la ram changer en 8go) et le dd ( changer en 500go) donc il me reste le proc à changer
Tu peux tenter de changer ton CPU vu que tu es sur un socket PGA (cf CPU Z).
En restant en SandyBridge tu peux prendre un I5 - 2540 M ou mieux un I7-2740M .
Le mieux est de rester dans le même TDP de 35 W .
Si tu prends un I7 4 coeurs (les QM) ca risque de chauffer plus voire trop ....
CPU à trouver sur Ebay entre 30 et 50€.
N'oublie pas de mettre à jour le Bios et d'activer dans le bios le mode turbo.
Dommage que tu n'es pas mis un SSD les perf auraient été encore meilleures. -
@arnoleb5900Merci l'ami pour tes conseils ;)
pour le SSD c'est prevu mais je voulais changer le proc avant
merci pour tout je vais voir pour le I7-2640M, 740M je ne trouve pas
ModérateurBonjour
SUr les portable laplupart du temps les éléments ne sont pas démontables.
Il faut d'abord vérifier si ce composant peut être changé.
bav
