Minecraft ne se lance pas sur mon pc
Bonjour bonsoir,
Je viens d'acquérir un pc fixe, sous vista. Une étiquette porte l'inscription "LENOVO A61 9143 Sempron 3600+ 2.00Ghz 2Go 80Go Windows vista pro sp2".
Le rapport d'erreur de minecraft me dit "
Bad video card drivers!
Minecraft was unable to start because it failed to find an accelerated OpenGL mode.
This can usually be fixed by updating the video card drivers.
--- BEGIN ERROR REPORT 7fe0271 --------
Generated 02/01/15 19:12
-- System Details --
Details:
Minecraft Version: 1.5.2
Operating System: Windows Vista (x86) version 6.0
Java Version: 1.8.0_25, Oracle Corporation
Java VM Version: Java HotSpot(TM) Client VM (mixed mode), Oracle Corporation
Memory: 456405872 bytes (435 MB) / 518979584 bytes (494 MB) up to 1037959168 bytes (989 MB)
JVM Flags: 2 total; -Xms512m -Xmx1024m
AABB Pool Size: 0 (0 bytes; 0 MB) allocated, 0 (0 bytes; 0 MB) used
Suspicious classes: No suspicious classes found.
IntCache: cache: 0, tcache: 0, allocated: 0, tallocated: 0
LWJGL: 2.4.2
OpenGL: ~~ERROR~~ NullPointerException: null
Is Modded: Probably not. Jar signature remains and client brand is untouched.
Type: Client (map_client.txt)
Texture Pack: Default
Profiler Position: N/A (disabled)
Vec3 Pool Size: ~~ERROR~~ NullPointerException: null[failed to get system properties (java.lang.NullPointerException)]
org.lwjgl.LWJGLException: Pixel format not accelerated
at org.lwjgl.opengl.WindowsPeerInfo.nChoosePixelFormat(Native Method)
at org.lwjgl.opengl.WindowsPeerInfo.choosePixelFormat(WindowsPeerInfo.java:52)
at org.lwjgl.opengl.WindowsDisplay.createWindow(WindowsDisplay.java:185)
at org.lwjgl.opengl.Display.createWindow(Display.java:311)
at org.lwjgl.opengl.Display.create(Display.java:856)
at org.lwjgl.opengl.Display.create(Display.java:784)
at org.lwjgl.opengl.Display.create(Display.java:765)
at net.minecraft.client.Minecraft.a(SourceFile:235)
at avv.a(SourceFile:56)
at net.minecraft.client.Minecraft.run(SourceFile:507)
at java.lang.Thread.run(Unknown Source)
--- END ERROR REPORT 884de0d6 ----------
La carte graphique (qui est une chipset je crois vu l'inscription "Carte graphique VGA standard" dans le gestionnaire de périphériques). Je devrais donc me payer une nouvelle carte graphique non ? Je ne sais pas quel modèle prendre, avec un budget de moins de 50€.
J'apprécie chaque réponse, dès qu'elle a une utilité, merci.
  1. Alors, redémarre ton pc cela devrait marcher, réinstalle java en la version d'exploitation de ton pc, sinon je suis navré, mais tu devras économiser pour investir dans une carte graphique.
    1. Je l'ai déjà fait. J'ai cherché le nom de cette carte, mais elle n'en a pas, tout ce que je trouve c'est "Carte graphique VGA standard". Je venais d'installer java quand j'ai écrit ce topic.
      1. Bonsoir.
        Surtout n'achète pas de carte graphique!
        Car avec un budget de 50€ tu peux oublié.
        Mais, met ta carte graphique a jour, pour cela fait :
        Menu Démarrer -> Ordinateur -> Propriétés Système -> Gestionnaire de Périphériques
        Il y aura une liste de périphérique, choisi celle ou il y a ta carte graphique ensuite :
        Clique droit sur ta carte graphique -> Mettre à jour les pilotes
        Redémarre ton ordinateur, si cela ne marche pas, télécharge des pilotes du nom de ta carte graphique sur le net.
        Si cela persiste, désinstalle java, et réinstalle le
        /!\ Installe java avec le bon système d'exploitation de ton ordinateur (32/64 bits) /!\
        Si cela continue, contacte un informaticien.
