Problème survey
J'ai un gros problème de survey qui m'énerve j'essaye de télécharger un logiciel depuis deux jours j'ai essayer de le télécharger avec mediafire mais ce n'est pas le logiciel exact merci de me répondre le plus vite possible
    Je t'ai répondu.
    C'est des attrapes pigeons...
    1. Rebonsoir, je voudrais enlever la survey de ce site est ce possible
      http://hacksgo.com/bcbe1
      revoici mon rapport
      # AdwCleaner v3.003 - Report created 11/09/2013 at 19:07:10
      # Updated 07/09/2013 by Xplode
      # Operating System : Windows 7 Professional Service Pack 1 (32 bits)
      # Username : DELL - DELL-PC
      # Running from : C:\Users\DELL\Desktop\adwcleaner.exe
      # Option : Clean
      ***** [ Services ] *****
      ***** [ Files / Folders ] *****
      Folder Deleted : C:\Users\DELL\AppData\LocalLow\AskToolbar
      Folder Deleted : C:\Users\DELL\AppData\Local\Google\Chrome\User Data\Default\Extensions\apfdadfinodckpcehhdhjlgiphgnbfci
      Folder Deleted : C:\Users\DELL\AppData\Local\Google\Chrome\User Data\Default\Extensions\eooncjejnppfjjklapaamhcdmjbilmde
      Folder Deleted : C:\Users\DELL\AppData\Local\Google\Chrome\User Data\Default\Extensions\jbpkiefagocgkmemidfngdkamloieekf
      Folder Deleted : C:\Users\DELL\AppData\Local\Google\Chrome\User Data\Default\Extensions\jpmbfleldcgkldadpdinhjjopdfpjfjp
      Folder Deleted : C:\Users\DELL\AppData\Local\Google\Chrome\User Data\Default\Extensions\ogccgbmabaphcakpiclgcnmcnimhokcj
      ***** [ Shortcuts ] *****
      ***** [ Registry ] *****
      Key Deleted : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Settings\{1122B43D-30EE-403F-9BFA-3CC99B0CADDD}
      Key Deleted : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Settings\{98889811-442D-49DD-99D7-DC866BE87DBC}
      Key Deleted : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Settings\{A7A6995D-6EE1-4FD1-A258-49395D5BF99C}
      Key Deleted : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Settings\{AE805869-2E5C-4ED4-8F7B-F1F7851A4497}
      Key Deleted : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Settings\{D4027C7F-154A-4066-A1AD-4243D8127440}
      Key Deleted : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Settings\{EEE6C35B-6118-11DC-9C72-001320C79847}
      Key Deleted : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Settings\{EEE6C35C-6118-11DC-9C72-001320C79847}
      Key Deleted : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Settings\{F1AF26F8-1828-4279-ABCE-074EF3235BD7}
      Product Deleted : Ask Toolbar
      ***** [ Browsers ] *****
      -\\ Internet Explorer v9.0.8112.16502
      -\\ Mozilla Firefox v23.0.1 (fr)
      [ File : C:\Users\DELL\AppData\Roaming\Mozilla\Firefox\Profiles\0\prefs.js ]
      [ File : C:\Users\DELL\AppData\Roaming\Mozilla\Firefox\Profiles\njqxosuk.default\prefs.js ]
      -\\ Google Chrome v
      [ File : C:\Users\DELL\AppData\Local\Google\Chrome\User Data\Default\preferences ]
      AdwCleaner[R0].txt - [28846 octets] - [11/09/2013 02:17:09]
      AdwCleaner[R1].txt - [2663 octets] - [11/09/2013 19:04:11]
      AdwCleaner[S0].txt - [28677 octets] - [11/09/2013 02:18:05]
      AdwCleaner[S1].txt - [2616 octets] - [11/09/2013 19:07:10]
      ########## EOF - C:\AdwCleaner\AdwCleaner[S1].txt - [2676 octets] ##########
        C'est de l'arnaque...
        Faut pas télécharger tout ce qu'on te propose.... surtout ce genre de trucs...
        C'est des virus.
        => http://www.malekal.com/2011/06/29/rat-bifrose-botnet-pour-les-nuls/
        1. Salut malke_morte voici le rapport et le lien du site pour telecharger mon logiciel
          # Option : Clean
          -\\ Google Chrome v
          voici le lien du sitepour mon logiciel http://www.facebookhackprofi.blogspot.ca
          Merci de me repondre le plus vite possible
            Télécharge https://www.malekal.com/adwcleaner-supprimer-virus-adwares-pup/?t=33839&start= AdwCleaner ( d'Xplode ) sur ton bureau.
            Sur la page d'AdwCleaner, à droite, clic sur la disquette grise avec la flèche verte pour lancer le téléchargement.
            Lance AdwCleaner, clique sur [Scanner] puis patiente (PAS besoin de copier/coller le rapport ici).
            Quand cela est terminé, clic sur [Nettoyage].
            !!! je répète faire [Nettoyage] !!!
            Clic sur Rapport puis copie/colle le contenu du rapport dans ta prochaine réponse par un copier/coller.
            Si cela ne fonctionne pas, utilise le site http://pjjoint.malekal.com pour héberger le rapport, donne le lien du rapport dans un nouveau message.
            Note : Le rapport est également sauvegardé sous C:\AdwCleaner[S1].txt
