Problème de gravure
Bonjour à la communauté,
Je n'arrive plus à graver avec mon portable ; quelqu'un pourrait-il jeter un oeil sur le log qui suit. Merci pour votre aide.
Asus
asus
1A20-0217-0000-1892-6143-8930*
1A20-8203-0139-2394-4252-0541*
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Ahead\nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 02/11/2004 12:54:32
NT-SPTI used
Nero Version: 6.6.1.4
Internal Version: 6, 6, 1, 4d
(Nero Express)
Recorder: <TSSTcorp CD/DVDW TS-L532U>Version: AS04 - HA 1 TA 0 - 6.6.1.4
Adapter driver: <IDE> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ?
CD-ROM: <TSSTcorp CD/DVDW TS-L532U>Version: AS04 - HA 1 TA 0 - 6.6.1.4
Scsi-Device-Map
DiskPeripheral : HTS541010G9SA00 atapi Port 0 ID 0 DMA: On
CdRomPeripheral : TSSTcorp CD/DVDW TS-L532U atapi Port 1 ID 0 DMA: On
CDRom-Device-Map
TSSTcorp CD/DVDW TS-L532U E: CDRom0
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 1023MB (1047852kB)
Free physical memory: 128MB (131772kB)
Memory in use : 87
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
21.2.2007
===== Disc-Copy over image - 1st step : Copy to image ...
19:19:33 #1 Text 0 File SCSIPassThrough.cpp, Line 38
SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME
19:19:33 #2 Text 0 File SCSIPassThrough.cpp, Line 83
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
19:19:33 #3 Text 0 File ThreadedTransfer.cpp, Line 531
ReadBuffer-Pipe got 192KB of Memory
19:19:33 #4 Text 0 File Reader.cpp, Line 124
Reader running
19:19:33 #5 Text 0 File Writer.cpp, Line 122
Writer Image Recorder running
19:19:33 #6 Phase 48 File dlgbrnst.cpp, Line 1685
Analyzing disc
19:19:33 #7 CDCOPY -1 File CDCopy.cpp, Line 1912
The CD is copyrighted
19:19:37 #8 Text 0 File CDCopy.cpp, Line 2128
_Index0_ _______Index1_______ PostPause ___LastBlockOfTrack_
Track 1: 0 0 ( 0:02.00) 105876 105875 ( 23:33.50)
19:19:37 #9 Text 0 File CDCopy.cpp, Line 840
Copy options: copy on-the-fly: ON
read ISRC/MCN: OFF
use jitter correction: OFF
data options
ignore read error: ON write defekt blocks OFF
read raw data: OFF read r-w subchannel data: OFF
audio options
read indexes: OFF read r-w subchannel data: OFF
source disc does not look like CD Extra
01. 0 - 105876 = 105876, data (TRM_DATA_MODE1, block size 2048)
19:19:37 #10 Text 0 File Burncd.cpp, Line 3305
Turn on Disc-At-Once, using CD-R/RW media
19:19:37 #11 Text 0 File DlgWaitCD.cpp, Line 281
Last possible write address on media: 445499 ( 99:01.74)
Last address to be written: 105875 ( 23:33.50)
19:19:37 #12 Text 0 File DlgWaitCD.cpp, Line 293
Write in overburning mode: NO (enabled: CD)
19:19:37 #13 Text 0 File DlgWaitCD.cpp, Line 459
>>> Protocol of DlgWaitCD activities: <<<
19:19:37 #14 Text 0 File ThreadedTransferInterface.cpp, Line 847
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 (1 - Données (mode 1))
2 indices, index0 (150) not provided
original disc pos #0 + 105876 (105876) = #105876/23:31.51
not relocatable, disc pos for caching/writing not required/not required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 105876 blocks [Image Recorder]
19:19:37 #15 Text 0 File ThreadedTransferInterface.cpp, Line 1059
Prepare recorder [Image Recorder] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 307200 217141248, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep__________
-150 | lead-in | 0 | 0x41 | 0x00
-150 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
105876 | lead-out | 1 | 0x41 | 0x00
19:19:37 #16 Phase 120 File dlgbrnst.cpp, Line 1685
Creating the image for burning
19:19:37 #17 Text 0 File ThreadedTransferInterface.cpp, Line 2685
Verifying disc position of item 0 (not relocatable, no disc pos, no patch infos, orig at #0): write at #0
19:21:30 #18 Text 0 File WriterStatus.cpp, Line 116
< Image Recorder > start writing Lead-Out at LBA 105876 (19D94h), lenght 0 blocks
19:21:30 #19 Text 0 File ThreadedTransfer.cpp, Line 228
all writers idle, stopping conversion
19:21:30 #20 Phase 121 File dlgbrnst.cpp, Line 1685
Creating Image completed successfully
===== Disc-Copy over image - 2nd step : Burn the image ...
19:21:36 #1 Text 0 File Burncd.cpp, Line 3012
Super Link activés
19:21:37 #2 Text 0 File ThreadedTransfer.cpp, Line 531
ReadBuffer-Pipe got 81920KB of Memory
19:21:37 #3 Text 0 File Reader.cpp, Line 124
Reader running
19:21:37 #4 Text 0 File Writer.cpp, Line 122
Writer TSSTcorp CD/DVDW TS-L532U running
19:21:37 #5 IMAGEGEN -10 File ImageGen.cpp, Line 366
Image was written as DAO.
DAOI:
MediaCatalogNumber = ''
TocType = 0x00
Finalized = 1
First/Last Track = 1 / 1
1: ISRC = ''
Blocksize = 2048
TrackMode = 'TRM_DATA_MODE1'
TrackConfig = 0x00
First/Last Index = 0 / 1
Index0FilePos = 0, Index1FilePos = 307200, NextTrackFilePos = 217141248
CUES:
0: Ctrl=0x41 Trk= 0 (0x00) Index=00 Start=954437:08.46 ( -150) RecDep=0x00
1: Ctrl=0x41 Trk= 1 (0x01) Index=00 Start=954437:08.46 ( -150) RecDep=0x00
2: Ctrl=0x41 Trk= 1 (0x01) Index=01 Start=00:00.00 ( 0) RecDep=0x00
3: Ctrl=0x41 Trk=110 (0xAA) Index=01 Start=23:31.51 ( 105876) RecDep=0x00
MTYP: Mediumtype = CD (old format) (0x1)
Image file name: <D:\Mes documents\TempImage.nrg>
19:21:37 #6 Text 0 File Burncd.cpp, Line 3305
19:23:28 #7 Text 0 File DlgWaitCD.cpp, Line 281
Last possible write address on media: 359845 ( 79:59.70)
19:23:28 #8 Text 0 File DlgWaitCD.cpp, Line 293
19:23:28 #9 Text 0 File DlgWaitCD.cpp, Line 2612
Recorder: TSSTcorp CD/DVDW TS-L532U
19:23:28 #10 Text 0 File DlgWaitCD.cpp, Line 459
Insert empty disc to write to.
(Medium in drive: Inconnu. Medium required by compilation: CD-R/RW.)
19:23:28 #11 Text 0 File ThreadedTransferInterface.cpp, Line 847
0: TRM_DATA_MODE1 (1 - Mode CD-ROM 1, Joliet)
2 indices, index0 (150) provided
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 105876 blocks [TSSTcorp CD/DVDW TS-L532U]
19:23:28 #12 Text 0 File ThreadedTransferInterface.cpp, Line 1059
Prepare recorder [TSSTcorp CD/DVDW TS-L532U] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
Tracks 1 to 1:
DAO layout:
19:23:28 #13 Text 0 File SCSIPassThrough.cpp, Line 38
19:23:28 #14 Text 0 File SCSIPassThrough.cpp, Line 83
19:23:28 #15 Phase 36 File dlgbrnst.cpp, Line 1685
Burn process started at 24x (3 600 Ko/s)
19:23:29 #16 Text 0 File ThreadedTransferInterface.cpp, Line 2685
19:23:29 #17 Text 0 File Mmc.cpp, Line 17163
StartDAO : CD-Text - Off
19:23:29 #18 Text 0 File Mmc.cpp, Line 21840
Set BUFE: Super Link -> ON
19:23:29 #19 Text 0 File Mmc.cpp, Line 17394
CueData, Len=32
41 00 00 14 00 00 00 00
41 01 00 10 00 00 00 00
41 01 01 10 00 00 02 00
41 aa 01 14 00 17 21 33
19:26:29 #20 SPTI -1114 File SCSIPassThrough.cpp, Line 289
E: CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1114)
Sense Key: 0x06 (KEY_UNIT_ATTENTION)
Sense Code: 0x29
Sense Qual: 0x00
CDB Data: 0x2A 00 FF FF FF 6A 00 00 20 00 00 00
Sense Area: 0x70 00 06 00 00 00 00 0A 00 00 00 00 29
Buffer x03850000: Len x10000
0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
19:26:29 #21 CDR -1114 File Writer.cpp, Line 311
Reset occurred
E: TSSTcorp CD/DVDW TS-L532U
19:26:30 #22 Text 0 File ThreadedTransfer.cpp, Line 228
19:26:30 #23 Text 0 File ThreadedTransfer.cpp, Line 222
conversion idle, stopping reader
19:26:30 #24 SPTI -1135 File SCSIPassThrough.cpp, Line 289
E: CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1135)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x35 02 00 00 00 00 00 00 00 00 00 00
Sense Area: 0x71 00 03 00 00 00 00 0A 00 00 00 00 0C
19:26:30 #25 CDR -1135 File WriterStatus.cpp, Line 167
Write error
19:26:30 #26 TRANSFER -24 File WriterStatus.cpp, Line 167
Could not perform end of Disc-at-once
19:26:30 #27 Phase 38 File dlgbrnst.cpp, Line 1685
Burn process failed at 24x (3 600 Ko/s)
Existing drivers:
File 'Drivers\PXHELP20.SYS': Ver=2.03.26a, size=20576 bytes, created 04/06/2005 19:02:08 (Prassi/Veritas driver for win 2K)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
====== *** Nero-Burning Rom, History File *** ======
Firefox 2.0.0.1
  1. bonjour
    je viens d acheter des dvd pleomax de samsung
    je n arrive pas a lire sur ces dvd ni le format avi ni dvd
    mon ordi me dit que windos ne peut lire ce type de fichier
    si j enregistre sur des dvd sony verbatim philipps je n ai aucun probleme
    que doit je faire?
    surtout q 1 copain a pu graver sur son ordi a lui
      renomme le fichier PXHELP20.SYS en PXHELP20.OLD...
      et redémarre ton PC...
        Non j'ai dû l'avoir mais apparemment je l'ai viré
        A+
        1. Bonjour et merci pour ta réponse mais comment dois-je faire ? Je vois nullement de prassi/véritas dans ccleaner. J'ai fait une recherche de fichier sur prassi et je ne trouve rien. Quel est logiciel qui utilise ce pilote ?
