Probleme connexion durant gravure avec Nero
Durant toutes mes gravures, j'ai une erreur de connexion qui fait tout échouer. Je ne comprends pas.
Voici le rapport:
Windows XP 5.1
IA32
WinAspi: File 'Wnaspi32.dll': Ver=4.57 (1008), size=48128 bytes, created 23/12/1997 01:23:24
ahead WinASPI: File 'C:\Program Files\Ahead\nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 26/10/2004 17:35:32
Nero Version: 6.6.0.15
Internal Version: 6, 6, 0, 15h
(Nero Express)
Recorder: <PIONEER DVD-RW DVR-108> Version: 1.14 - HA 0 TA 1 - 6.6.0.15
Adapter driver: <atapi> HA 0
Drive buffer : 2000kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
CD-ROM: <PIONEER DVD-RW DVR-108 >Version: 1.14 - HA 0 TA 1 - 6.6.0.15
Scsi-Device-Map
DiskPeripheral : ST340823A atapi Port 0 ID 0 DMA: On
CdRomPeripheral : PIONEER DVD-RW DVR-108 atapi Port 0 ID 1 DMA: On
CdRomPeripheral : CD-RW CDR-6S52 atapi Port 1 ID 1 DMA: On
CDRom-Device-Map
PIONEER DVD-RW DVR-108 D: CDRom0
CD-RW CDR-6S52 E: CDRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 57671680 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 383MB (392736kB)
Free physical memory: 62MB (64232kB)
Memory in use : 83 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
10.2.2007
Compilation ISO
11:07:59 #1 Text 0 File Isodoc.cpp, Line 6314
Iso document burn settings
Determine maximum speed : TRUE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
11:07:59 #2 Text 0 File Reader.cpp, Line 127
Reader running
11:07:59 #3 Text 0 File Writer.cpp, Line 122
Writer PIONEER DVD-RW DVR-108 running
11:07:59 #4 ISO9660GEN -11 File geniso.cpp, Line 3309
First writeable address = 0 (0x00000000)
11:07:59 #5 Text 0 File Burncd.cpp, Line 3231
Turn on Disc-At-Once, using DVD media
11:08:00 #6 Text 0 File DlgWaitCD.cpp, Line 269
Last possible write address on media: 2295103 (510:01.28, 4482MB)
Last address to be written: 2261151 (502:28.51, 4416MB)
11:08:00 #7 Text 0 File DlgWaitCD.cpp, Line 281
Write in overburning mode: NO (enabled: CD DVD)
11:08:00 #8 Text 0 File DlgWaitCD.cpp, Line 2477
Recorder: PIONEER DVD-RW DVR-108, Media type: DVD+R
Disc Manufacturer ID: INFOME, Media Type ID: R20, Product revision number: 0
Disc Application Code: 0, Extended Information Indicators: 3
11:08:00 #9 Text 0 File DlgWaitCD.cpp, Line 447
>>> Protocol of DlgWaitCD activities: <<<
11:08:00 #10 Text 0 File ThreadedTransferInterface.cpp, Line 830
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 2261152 (2261152) = #2261152/502:28.52
relocatable, disc pos for caching/writing not required/ required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2261152 blocks [PIONEER DVD-RW DVR-108]
11:08:00 #11 Text 0 File ThreadedTransferInterface.cpp, Line 1043
Prepare recorder [PIONEER DVD-RW DVR-108] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4630839296, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0x00
0 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
2261152 | lead-out | 1 | 0x41 | 0x00
11:08:00 #12 Phase 24 File dlgbrnst.cpp, Line 1832
Caching of files started
11:08:00 #13 Text 0 File Burncd.cpp, Line 4116
Cache writing successful.
11:08:00 #14 Phase 25 File dlgbrnst.cpp, Line 1832
Caching of files completed
11:08:00 #15 Phase 28 File dlgbrnst.cpp, Line 1832
Speed measurement started
11:08:00 #16 Text 0 File ThreadedTransferInterface.cpp, Line 2643
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
11:13:29 #17 Text 0 File WriterStatus.cpp, Line 116
<PIONEER DVD-RW DVR-108 > start writing Lead-Out at LBA 2261152 (2280A0h), lenght 0 blocks
11:13:29 #18 Text 0 File ThreadedTransfer.cpp, Line 228
all writers idle, stopping conversion
11:13:29 #19 Phase 29 File dlgbrnst.cpp, Line 1781
Speed measurement completed: 10x (13 924 Ko/s)
11:13:29 #20 Phase 36 File dlgbrnst.cpp, Line 1832
Burn process started at 4x (5 540 Ko/s)
11:13:29 #21 Text 0 File ThreadedTransferInterface.cpp, Line 2643
11:13:29 #22 Text 0 File Cdrdrv.cpp, Line 8821
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD+R (10), Part Version: 1
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 26053F h
End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
Data in Burst Cutting Area (BCA) does not exist
Disc Application Code: 0 / 0 h
Extended Information indicators: 3 h
Disc Manufacturer ID: INFOME..
Media type ID: R20
Number of Physical format information bytes in use in ADIP up to byte 63: 56
Media Specific [16..63]:
00 00 03 49 4E 46 4F 4D - 45 00 00 52 32 30 00 38 ...INFOME..R20.8
23 54 37 15 02 52 6C 02 - B4 63 15 15 0B 0A 08 08 #T7..Rl..c......
01 19 1B 0C 0C 0C 0D 01 - 00 00 00 00 00 00 00 00 ................
11:13:29 #23 Text 0 File DVDPlusRW.cpp, Line 663
Start write address at LBA 0
DVD high compatibility mode: No
11:13:33 #24 Text 0 File Cdrdrv.cpp, Line 1288
11:13:33.989 - PIONEER DVD-RW DVR-108\H0 T1 : Queue again later
11:18:11 #25 SCSI -1024 File Cdrdrv.cpp, Line 1436
SCSI Exec, HA 0, TA 1, LUN 0, buffer 0x03720000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x04 (KEY_HARDWARE_ERROR)
Sense Code: 0x08
Sense Qual: 0x03
CDB Data: 0x2A 0x00 0x00 0x0B 0x00 0x60 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x04 0x00 0x00 0x00 0x00 0x0E
0x00 0x00 0x00 0x00 0x08 0x03
11:18:11 #26 CDR -1024 File Writer.cpp, Line 311
Communication failure
11:18:11 #27 Text 0 File ThreadedTransfer.cpp, Line 228
11:18:11 #28 Text 0 File ThreadedTransfer.cpp, Line 222
conversion idle, stopping reader
11:18:14 #29 Phase 38 File dlgbrnst.cpp, Line 1832
Burn process failed at 4x (5 540 Ko/s)
Existing drivers:
File 'Drivers\ASPI32.SYS': Ver=4.57 (1008), size=23936 bytes, created 23/12/1997 02:02:46
File 'Drivers\atapi.sys': Ver=5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), size=95360 bytes, created 02/03/2006 13:00:00 (Adapter driver for rec)
Merci d'avance
Firefox 2.0.0.1
  1. Salut à tous. Je viens de formater et j'ai ce même problème de gravure avec Nero 6 (communication failure).
    Avant de formater j'avais solutionné le problème de moitié en traficotant un peu le mode de transfert (DMA si disponible) du cannal IDE primaire et secondaire via le gestionnaire de périphérique. Donc après diverse manipulation un peu hasardeuses j'ai reussi à faire fonctionner mon graveur dvd qui etait tout neuf mais le soucis etait que, il me fallait au moins trois fois plus de temps que la normale pour graver un cd( 12min pour 700mb)
    Je suis tombé sur ce topic et j'ai lu qu'il fallait des nappes IDE de 80 fils et non 40, hors je viens de m'apercevoir que mes lecteurs/graveurs cd/dvd etaient branchée sur une nappe de 40 fils.
    J'ai aussi constaté que mes disques durs étaient branchés sur des nappes de 80 fils.
    Donc ma question est simple, j'aimerais savoir si l'on peut brancher des disques dures sur des nappes de 40 fils.
    1. Merci, je vais essayer
