Minecraft sur Windows 8 [HELP]
depuis que j'ai Windows 8 je n'arrive pas à jouer à Minecraft.
Et à chaque fois que j'essai de l'utiliser ça me met ça :
Bad video card drivers!
Minecraft was unable to start because it failed to find an accelerated OpenGL mode.
This can usually be fixed by updating the video card drivers.
--- BEGIN ERROR REPORT 7fe0271 --------
Generated 25/11/12 20:00
-- System Details --
Details:
Minecraft Version: 1.4.5
Operating System: Windows NT (unknown) (x86) version 6.2
Java Version: 1.6.0_37, Sun Microsystems Inc.
Java VM Version: Java HotSpot(TM) Client VM (mixed mode), Sun Microsystems Inc.
Memory: 772709320 bytes (736 MB) / 1037959168 bytes (989 MB) up to 1037959168 bytes (989 MB)
JVM Flags: 5 total; -Xbootclasspath/a:C:\\PROGRA~2\\Java\\jre6\\lib\\deploy.jar;C:\\PROGRA~2\\Java\\jre6\\lib\\javaws.jar;C:\\PROGRA~2\\Java\\jre6\\lib\\plugin.jar -Xmx1g -Xms1024M -Xmx1g -Xms1024M
AABB Pool Size: 0 (0 bytes; 0 MB) allocated, 0 (0 bytes; 0 MB) used
Suspicious classes: No suspicious classes found.
IntCache: cache: 0, tcache: 0, allocated: 0, tallocated: 0
LWJGL: 2.4.2
OpenGL: ~~ERROR~~ NullPointerException: null
Is Modded: Probably not. Jar signature remains and client brand is untouched.
Type: Client (map_client.txt)
Texture Pack: ~~ERROR~~ NullPointerException: null
Profiler Position: N/A (disabled)
Vec3 Pool Size: ~~ERROR~~ NullPointerException: null[failed to get system properties (java.lang.NullPointerException)]
org.lwjgl.LWJGLException: Pixel format not accelerated
at org.lwjgl.opengl.WindowsPeerInfo.nChoosePixelFormat(Native Method)
at org.lwjgl.opengl.WindowsPeerInfo.choosePixelFormat(WindowsPeerInfo.java:52)
at org.lwjgl.opengl.WindowsDisplay.createWindow(WindowsDisplay.java:185)
at org.lwjgl.opengl.Display.createWindow(Display.java:311)
at org.lwjgl.opengl.Display.create(Display.java:856)
at org.lwjgl.opengl.Display.create(Display.java:784)
at org.lwjgl.opengl.Display.create(Display.java:765)
at net.minecraft.client.Minecraft.a(SourceFile:232)
at net.minecraft.client.Minecraft.run(SourceFile:515)
at java.lang.Thread.run(Unknown Source)
--- END ERROR REPORT 69a3c730 ----------
QUE DOIS-JE FAIRE !!!!!!!!!!!!!!!!!!!!!!!!!
10 réponses
  1. Salut,
    Essaye de trouver le pilote en fesant une analyse de ton pc sur https://www.touslesdrivers.com/ puis dans Mes drivers et tu installe leur petit logiciel pour scanner ton ordinateur. Et ton internet fera la recherche tout seul. Et t'aura plus qu'a chercher ta carte graphique dans la liste et télécharger le pilote si il y en n'a un.
    Cordialement
    1. Merci !
  2. Modérateur
    Ok ?
    J'ai besoin du résumé pour trouver un pilote pour ta carte graphique.
    1. Version du plugin : 6.5.0.3
      Version de la base : 22
      Date de la détection : 21/12/2012 21:31
      Nom de la machine : maison
    2. Modérateur
      Ce n'est pas suffisant.
      A la rigueur, tu peux faire ceci :
      https://www.commentcamarche.net/faq/16194-faire-un-lien-vers-sa-configuration-pc
    3. Champ Valeur
      Ordinateur
      Type de système PC ACPI avec processeur x64 (Mobile)
      Système d'exploitation Microsoft Windows 8
      Service Pack du système [ TRIAL VERSION ]
      Internet Explorer 10.0.8250.0 (IE 10.0 - Windows 8 Consumer Preview)
      DirectX DirectX 11.0
      Nom du système MAISON
      Nom de l'utilisateur yoa.000
      Domaine de connexion [ TRIAL VERSION ]
      Date / Heure 2012-12-22 / 11:08
      Carte mère
      Type de processeur Mobile DualCore Intel Pentium, 2100 MHz
      Nom de la carte mère Hewlett-Packard Compaq Presario CQ71 Notebook PC
      Chipset de la carte mère Intel Cantiga GL40/GM45/GM47/GS45
      Mémoire système [ TRIAL VERSION ]
      Type de Bios Insyde (08/21/2009)
      Moniteur
      Carte vidéo Famille de jeu de puces Express Mobile Intel(R) 4 Series (Microsoft Corporation - WDDM 1.1) (1850840 Ko)
      Moniteur LG Philips LP173WD1-TLC1 [17.3" LCD]
      Multimédia
      Carte audio IDT 92HD75B1/92HD75B2 @ Intel 82801IB ICH9 - High Definition Audio Controller [A-3]
      Carte audio Intel Cantiga HDMI @ Intel 82801IB ICH9 - High Definition Audio Controller [A-3]
      Stockage
      Contrôleur IDE Contrôleur AHCI SATA standard
      Contrôleur de stockage Contrôleur des espaces de stockage Microsoft
      Disque dur ST9320325AS (320 Go, 5400 RPM, SATA-II)
      Lecteur optique hp CDDVDW TS-L633M
      État des disques durs SMART Inconnu
      Partitions
      C: (NTFS) [ TRIAL VERSION ]
      D: (NTFS) 12854 Mo (2142 Mo libre)
      Taille totale [ TRIAL VERSION ]
      Entrée
      Clavier Clavier standard PS/2
      Souris Souris compatible PS/2
      Souris Souris HID
      Réseau
      Adresse IP principale [ TRIAL VERSION ]
      Adresse MAC principale 00-26-5E-72-63-3B
      Carte réseau Carte de miniport Microsoft Virtual WiFi
      Carte réseau Carte WiFi Atheros AR9285 802.11b/g/n (192. [ TRIAL VERSION ])
      Carte réseau Contrôleur Realtek PCIe FE Family
      Périphériques
      Imprimante Fax
      Imprimante Microsoft XPS Document Writer
      Contrôleur USB1 Intel 82801IB ICH9 - USB Universal Host Controller [A-3]
      Contrôleur USB2 Intel 82801IB ICH9 - USB2 Enhanced Host Controller [A-3]
      Périphérique USB HP Webcam-101
      Périphérique USB Périphérique d'entrée USB
      Périphérique USB Périphérique USB composite
      Batterie Adaptateur secteur Microsoft
      Batterie Batterie à méthode de contrôle compatible ACPI Microsoft
      DMI
      Distributeur du Bios Hewlett-Packard
      Version du Bios F.11
      Fabricant du système Hewlett-Packard
      Nom du système Compaq Presario CQ71 Notebook PC
      Version du système Rev 1
      N° de série du système [ TRIAL VERSION ]
      UUID du système [ TRIAL VERSION ]
      Fabricant de la carte mère Quanta
      Nom de la carte mère 306B
      Version de la carte mère 21.12
      N° de série de la carte mère [ TRIAL VERSION ]
      Fabricant du châssis Quanta
      Version du châssis N/A
      N° de série du châssis [ TRIAL VERSION ]
      Identifiant du châssis [ TRIAL VERSION ]
      Type du châssis Notebook
    4. Je sais pas trop....
      Et comment on fait les versions de
      Windows Update
  3. Modérateur
    https://www.commentcamarche.net/faq/9265-identifier-son-materiel-avec-aida64
    Copie-colle le résumé généré par AIDA64 dans ton prochain message.
    1. Pourquoi il detecte Windows NT, j'en sais rien, après regarde dans panneau de configuration -> Système et regarde la version qu'il t'indique.
      1. Si vous lisez bien, le tout premier message dit : bad video card drivers... Met ta carte graphique a jour (tu peux chercher sur le site du constructeur) ;)
        1. MAIS WTF il reconnais comme si tu avais un windows NT?
          "Operating System: Windows NT (unknown) (x86) version 6.2 "
          MDR Il reconnait pas windows8 il reconnait un système d'exploitation qui était avant windows 95 je crois
