Problème resize NTFS
je voudrais passer mon vieil ordi (Win XP SP1) sous puppy (slako). Pour cela je boot sur un live cd de puppy et je lance GParted pour faire une partition. Mon disque dure possède une partition NTFS (37.25 GiB, 16.78GiB used et 20.47GiB unused) et une partie non allouée (7.84MiB).
Je sélectionne la partition NTFS et je met resize/move Je choisi 0 Free space predecing, 19154 New size, et 19000 comme free size following. Mais il affiche après quelques instant un message d'erreur : sous les détails on voit
Shrink /dev/sda1 from 37.25 GiB to 18.71 GiB 00:02:36 (panneau interdit)
&nbsp&nbsp&nbsp&nbspcalibrate /dev/sda1 00:00:03 (checked)
&nbsp&nbsp&nbsp&nbspcheck file system on /dev/sda1 for error and (if possible) fix them 00:00:32 (checked)
&nbsp&nbsp&nbsp&nbspshrink file system 00:01:28 (panneau interdit)
&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsprun simulation 00:01:28 (panneau interdit)
&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbspntfsresize -P --force /dev/sda1 -s 20085441023 --no-action
&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbspntfsresize v2.0.0 (libntfs 10:0:0)
&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbspDevice name : /dev/sda1
&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbspNTFS volume version: 3.1
&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbspCluster size : 4096 bytes
&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbspCurrent volume size: 39999500800 bytes (40000 MB)
&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbspCurrent device size: 39999504384 bytes (40000 MB)
&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbspNew volume size : 20085436928 bytes (200086 MB)
&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbspChecking filesystem consistency ...
&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbspAccounting clusters ...
&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbspSpace in use : 18018 MB (45.0%)
&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbspCollecting resizing constraints ...
&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbspNeeded relocations : 693056 (2839 MB)
&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbspSchedude chkdsk for NTFS consistency check at Windows boot time ...
&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbspResetting $LogFile ... (this might take a while)
&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbspRelocating needed data ...
&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbspERROR Extended record needed (1 0240 > 1024), not yet supported!
&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbspPlease try to free less space
&nbsp&nbsp&nbsp&nbspcheck file system on /dev/sda1 for errors and (if possible) fix them 00:00:32 (checked)
&nbsp&nbsp&nbsp&nbspgrow file system to fill th partition 00:00:01 (checked)
Il me semble qu'il suffit que j' "essaie de libérer de l'espace". Mais qu'est-ce que je dois faire précisément.
Le problème porte sur le redimensionnement d'une partition NTFS sous Puppy Linux via GParted afin de libérer de l'espace pour installer le système, sur un disque comprenant partition NTFS et une portion non allouée. Des messages du journal montrent que l'opération échoue avec des détails NTFS et l'avertissement 'Extended record needed', indiquant que l'espace disponible pour le redimensionnement est insuffisant. Pour corriger, il est conseillé de libérer moins d'espace lors du shrink ou de vérifier et réparer le système de fichiers, puis de réessayer l'opération sur le live CD. Autre information utile: la partition NTFS compte environ 37 Go au total, avec 16–17 Go utilisés et plus de 20 Go libres, ce qui influence les choix de réduction et d'allocation.
  1. Ah oui, au fait, j'avais oublié de dire la solution quand j'ai résolu. Il fallait réduire mois que j'essayais de le faire la partition utilisée par Windows, laisser un petit peu plus d'espace libre. C'était sûrement parce que la défragmentation n'était pas parfaite.
    Merci pour toutes les aides.
    Au fait, je suis passé à Debian finalement.
      tu ne te tromperais pas d'unité, lors de la définition de ta nouvelle partition ?
      Genre prendre des GiB pour des MiB ?
      1. Non, non, j'ai indiquer les tailles en GiB puis, lors des choix, j'ai fait en MiB.
    2. Modérateur
      Salut
      Déjà, quoi que tu fasse, si tu veut être sur de garder tes données, sauvegarde les sur un support externe.
      Ensuite, as tu correctement défragmenté ta partition NTFS avant le redimensionnement ?
      1. J'ai déframenter avec dréfragmenteur Windows
      2. Modérateur
        Correctement ? Il ne reste plus de bout de fichier sur la partie que tu veut libérer ?
      3. Modérateur
        éventuellement, un chkntfs /C c: pour voir ?
      4. Modérateur
        A taper dans une invite de commande windows et coller le resultat ici.
    3. Pouvez-vous reformater?
      Si oui, essayez, lors de l'installation de votre nouveau système, de redimensionner vos partitions vous-même!
      Il vous faut: - Une partition EXT3 ou EXT4 (partition principale), Et une partition SWAP de +- 4GO (ou l'équivalent de 2x votre mémoire RAM).
      En espérant vous avoir aidé!
      Cordialement
      Nael1
      1. Ou essayez de supprimer les autres partitions non windows et de procéder comme ci-dessus
      2. J'aimerais garder mes données ainsi que Windows en cas de problème.
      3. Faites comme je viens de dire, j'ai fais pareil pour mon Ubuntu ;)
      4. Si je "reformate" tout devrai s'éffacer, non? je ne comprend pas?
      5. Modérateur
        Il ne veut pas formater, puisqu'il désire garder sa partition windows...
    4. Contributeur
      Qu'essaies-tu de faire exactement ?
      Veux-tu conserver la partie avec XP et supprimer le reste ?
      Où veux-tu installer puppy ?
      1. J'essaie de faire une nouvelle partition pour y installer puppy
      2. Contributeur
        Oui, mais où ?
        Mon disque dure possède :
        16.78GiB used
        et 20.47GiB unused)
      3. justement, sur une nouvelle partition : je commence par diminuer la partition NTFS avant d'en faire une nouvelle.
      4. Contributeur
        Alors il faut défragmenter tes partitions NTFS avant toutes choses et même deux fois plutôt qu'une, et faire des sauvegardes de tes données, une erreur n'est jamais à exclure.
      5. Comment je fait pour faire facilement une sauvegarde du disque sous Puppy.
        J'ai un disque dur déjà utilisé en partie
