Graveur DVD HS ?
Mon pc portable est équipé d'un combo graveur de cd/dvd HITACHI DVD+RW RW8160. Pour les cd pas de problèmes, ca grave. Mais par contre je n'arrive plus à graver de dvd (données ou vidéo). J'ai essayé avec des Vebatim (+R habituellement suppoté par mon graveur), desThinkXtra, avec Nero et CopyToDVD mais rien à faire.
CopyToDVD m'envoie le message suivant:
Write Error - Code 04 91 C1 [Hardware error]
Voilà le journal de Nero:
12:42:50 #2 Text 0 File ThreadedTransfer.cpp, Line 525
ReadBuffer-Pipe got 64512KB of Memory
12:42:50 #3 Text 0 File Reader.cpp, Line 124
Reader running
12:42:50 #4 Text 0 File Writer.cpp, Line 113
Writer D: DVD+RW RW8160 running
12:42:50 #5 ISO9660GEN -11 File Geniso.cpp, Line 3304
First writeable address = 0 (0x00000000)
12:42:50 #6 Text 0 File Burncd.cpp, Line 3301
Turn on Disc-At-Once, using DVD media
12:42:51 #7 Text 0 File DlgWaitCD.cpp, Line 277
Last possible write address on media: 2295103 (510:01.28, 4482MB)
Last address to be written: 2142655 (476:08.55, 4184MB)
12:42:51 #8 Text 0 File DlgWaitCD.cpp, Line 289
Write in overburning mode: NO (enabled: CD)
12:42:51 #9 Text 0 File DlgWaitCD.cpp, Line 2568
Recorder: DVD+RW RW8160, Media type: DVD+R
12:42:51 #10 Text 0 File DlgWaitCD.cpp, Line 456
>>> Protocol of DlgWaitCD activities: <<<
12:42:51 #11 Text 0 File ThreadedTransferInterface.cpp, Line 846
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 2142656 (2142656) = #2142656/476:8.56
relocatable, disc pos for caching/writing not required/ required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2142656 blocks [D: DVD+RW RW8160]
12:42:51 #12 Text 0 File ThreadedTransferInterface.cpp, Line 1058
Prepare recorder [D: DVD+RW RW8160] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4388159488, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0x00
0 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
2142656 | lead-out | 1 | 0x41 | 0x00
12:42:59 #13 Text 0 File SCSIPassThrough.cpp, Line 56
Error on LockVolume: Accès refusé.
12:42:59 #14 Text 0 File SCSIPassThrough.cpp, Line 104
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
12:42:59 #15 Text 0 File Cdrdrv.cpp, Line 9571
SPTIDismountVolume not successfull
12:43:07 #16 Text 0 File SCSIPassThrough.cpp, Line 56
12:43:37 #17 Phase 24 File dlgbrnst.cpp, Line 1724
Caching of files started
12:43:37 #18 Text 0 File Burncd.cpp, Line 4129
Cache writing successful.
12:43:37 #19 Phase 25 File dlgbrnst.cpp, Line 1724
Caching of files completed
12:43:38 #20 Phase 36 File dlgbrnst.cpp, Line 1724
Burn process started at 2,4x (3 324 Ko/s)
12:43:38 #21 Text 0 File ThreadedTransferInterface.cpp, Line 2669
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
12:43:38 #22 SPTI -1066 File SCSIPassThrough.cpp, Line 306
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1066)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x24
Sense Qual: 0x00
CDB Data: 0xAD 00 00 00 00 00 00 00 08 04 00 00
Sense Area: 0x70 00 05 00 00 00 00 0C 00 00 00 00 24
Buffer x048c3400: Len x804
12:43:38 #23 SPTI -1066 File SCSIPassThrough.cpp, Line 306
Sense Code: 0x24
Sense Qual: 0x00
CDB Data: 0xF9 15 01 FF 00 00 00 00 00 00 00 00
12:43:38 #24 Text 0 File DVDR.cpp, Line 6068
Drive: DVD+RW RW8160
Book Type request [gen]: DVD-ROM, write to EEPROM
Changing the Book Type was finished successfully, return code 0
12:43:38 #25 CDR -1207 File DVDR.cpp, Line 5211
Book Type automatically set to: DVD-ROM
12:43:38 #26 Text 0 File DVDPlusRW.cpp, Line 666
Start write address at LBA 0
DVD high compatibility mode: Yes
12:44:19 #27 SPTI -1 File SCSIPassThrough.cpp, Line 306
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1)
Sense Key: 0x04 (KEY_HARDWARE_ERROR)
Sense Code: 0x91
Sense Qual: 0xC1
CDB Data: 0x2A 00 00 00 00 00 00 00 20 00 00 00
Sense Area: 0x70 00 04 00 00 00 00 0C 00 00 00 00 91 C1
Buffer x04b30000: Len x10000
0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
12:44:19 #28 CDR -1 File Writer.cpp, Line 302
Unspecified Recorder Error
D: DVD+RW RW8160
12:44:20 #29 Text 0 File ThreadedTransfer.cpp, Line 228
all writers idle, stopping conversion
12:44:21 #30 Text 0 File ThreadedTransfer.cpp, Line 222
conversion idle, stopping reader
12:44:22 #31 SPTI -1066 File SCSIPassThrough.cpp, Line 306
Sense Code: 0x24
Sense Qual: 0x00
CDB Data: 0x00 00 00 00 00 00 00 00 00 00 00 00
Sense Area: 0x71 00 05 00 00 00 00 0C 00 00 00 00 24
12:44:22 #32 Phase 127 File dlgbrnst.cpp, Line 1724
Generating DVD high compatibility borders
12:44:22 #33 SPTI -1066 File SCSIPassThrough.cpp, Line 306
Sense Code: 0x24
Sense Qual: 0x00
CDB Data: 0xF9 15 A1 02 00 00 00 00 00 00 00 00
12:44:22 #34 Text 0 File DVDR.cpp, Line 6068
Book Type request [gen]: DVD+R, write to EEPROM
12:44:22 #35 CDR -1066 File WriterStatus.cpp, Line 167
Invalid field in command
D: DVD+RW RW8160
12:44:22 #36 TRANSFER -24 File WriterStatus.cpp, Line 167
Could not perform end of Disc-at-once
12:44:22 #37 Phase 38 File dlgbrnst.cpp, Line 1724
Burn process failed at 2,4x (3 324 Ko/s)
Le graveur peut-il être mort alors que j'arrive encore à graver des CD ? Sinon quelqu'un peut-il m'éclairer sur le problème ?
  1. Moi aussi j'ai exactement le même problème avec un graveur de dvd équipant un ordinateur powernet acheté à carrefour. J'ai gravé avec succès 2 dvd verbatim , j'en ai gaché 2 autres et maintenant la séquence finale se termine mal.
    Je crois que le matériel n'est pas de bonne qualité
    1. Salut Luc,
      C'est peut être pas un "combo" mais c'est pas ca le problème. Avant j'arrivais à graver cd et dvd. Maintenant j'arrive plus à graver les dvd.
      Merci quand même.
      1. salut, je sais pas pour ton probleme mais un combo cd/dvd et un graveur cd et lecteur dvd, il ne grave pas les dvd, donc c'est normal, si tu as un graveur dvd ca s'appelle comme ca, et dans ce cas la tu as un probleme
        1. Merci pour ta réponse maxximus,
          J'ai réinstallé nero 6 mais je n'arrive toujours pas à graver. Dans les evenements au cours de la gravure j'ai:
          Burn process started...
          DVD+RW8160
          Unspecified target error
          puis
          Burn process failed
          1. Salut,
            Essaye de désinstaller et de réinstaller Nero.
