Probleme de pc avec activetoolband
le pc a ma copine presente une infection a priori avec active toolband, j ai fait un log hijack ths mais je n arrive pas a le supprimer, pourrais t on m aide a m en debarraser???
comme symptome j ai le dereglage de l horloge a chaque demmarrage du pc, je ne sais pas si c est lier ou pas
merci d avance
Scan saved at 12:00:54, on 20/06/2010
Platform: Windows Vista SP2 (WinNT 6.00.1906)
MSIE: Internet Explorer v8.00 (8.00.6001.18928)
Boot mode: Normal
Running processes:
C:\Windows\system32\taskeng.exe
C:\Windows\system32\Dwm.exe
C:\Windows\Explorer.EXE
C:\Acer\Empowering Technology\eDataSecurity\eDSloader.exe
C:\Windows\RtHDVCpl.exe
C:\Program Files\Avira\AntiVir Desktop\avgnt.exe
C:\Program Files\Zone Labs\ZoneAlarm\zlclient.exe
C:\Program Files\Windows Sidebar\sidebar.exe
C:\Windows\ehome\ehtray.exe
C:\Windows\System32\rundll32.exe
C:\Windows\ehome\ehmsas.exe
C:\Users\cynthia\AppData\Local\Temp\RtkBtMnt.exe
C:\Windows\system32\wbem\unsecapp.exe
C:\Program Files\Windows Live\Messenger\msnmsgr.exe
C:\Program Files\Windows Live\Contacts\wlcomm.exe
C:\Program Files\Trend Micro\HijackThis\HijackThis.exe
C:\Program Files\Mozilla Firefox\firefox.exe
C:\Windows\system32\DllHost.exe
R0 - HKLM\Software\Microsoft\Internet Explorer\Search,SearchAssistant =
R0 - HKLM\Software\Microsoft\Internet Explorer\Search,CustomizeSearch =
O2 - BHO: AcroIEHelperStub - {18DF081C-E8AD-4283-A596-FA578C2EBDC3} - C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelperShim.dll
O2 - BHO: (no name) - {5C255C8A-E604-49b4-9D64-90988571CECB} - (no file)
O2 - BHO: ShowBarObj Class - {83A2F9B1-01A2-4AA5-87D1-45B6B8505E96} - C:\Windows\system32\ActiveToolBand.dll
O2 - BHO: Programme d'aide de l'Assistant de connexion Windows Live - {9030D464-4C02-4ABF-8ECC-5164760863C6} - C:\Program Files\Common Files\Microsoft Shared\Windows Live\WindowsLiveLogin.dll
O2 - BHO: Java(tm) Plug-In 2 SSV Helper - {DBC80044-A445-435b-BC74-9C25C1C588A9} - C:\Program Files\Java\jre6\bin\jp2ssv.dll
O4 - HKLM\..\Run: [eDataSecurity Loader] C:\Acer\Empowering Technology\eDataSecurity\eDSloader.exe
O4 - HKLM\..\Run: [MSConfig] "C:\Windows\system32\msconfig.exe" /auto
O4 - HKLM\..\Run: [RtHDVCpl] RtHDVCpl.exe
O4 - HKLM\..\Run: [NvSvc] RUNDLL32.EXE C:\Windows\system32\nvsvc.dll,nvsvcStart
O4 - HKLM\..\Run: [avgnt] "C:\Program Files\Avira\AntiVir Desktop\avgnt.exe" /min
O4 - HKLM\..\Run: [ZoneAlarm Client] "C:\Program Files\Zone Labs\ZoneAlarm\zlclient.exe"
O4 - HKLM\..\Run: [Adobe Reader Speed Launcher] "C:\Program Files\Adobe\Reader 9.0\Reader\Reader_sl.exe"
O4 - HKLM\..\Run: [Adobe ARM] "C:\Program Files\Common Files\Adobe\ARM\1.0\AdobeARM.exe"
O4 - HKCU\..\Run: [Sidebar] C:\Program Files\Windows Sidebar\sidebar.exe /autoRun
O4 - HKCU\..\Run: [ehTray.exe] C:\Windows\ehome\ehTray.exe
O13 - Gopher Prefix:
O20 - AppInit_DLLs: enethook.dll
O23 - Service: Avira AntiVir Planificateur (AntiVirSchedulerService) - Avira GmbH - C:\Program Files\Avira\AntiVir Desktop\sched.exe
O23 - Service: Avira AntiVir Guard (AntiVirService) - Avira GmbH - C:\Program Files\Avira\AntiVir Desktop\avguard.exe
O23 - Service: eDSService.exe (eDataSecurity Service) - HiTRSUT - C:\Acer\Empowering Technology\eDataSecurity\eDSService.exe
O23 - Service: eLock Service (eLockService) - Acer Inc. - C:\Acer\Empowering Technology\eLock\Service\eLockServ.exe
O23 - Service: eNet Service - Acer Inc. - C:\Acer\Empowering Technology\eNet\eNet Service.exe
O23 - Service: eRecovery Service (eRecoveryService) - Acer Inc. - C:\Acer\Empowering Technology\eRecovery\eRecoveryService.exe
O23 - Service: eSettings Service (eSettingsService) - Unknown owner - C:\Acer\Empowering Technology\eSettings\Service\capuserv.exe
O23 - Service: LightScribeService Direct Disc Labeling Service (LightScribeService) - Hewlett-Packard Company - C:\Program Files\Common Files\LightScribe\LSSrvc.exe
O23 - Service: Ma-Config Service (maconfservice) - CybelSoft - C:\Program Files\ma-config.com\maconfservice.exe
O23 - Service: Cyberlink RichVideo Service(CRVS) (RichVideo) - Unknown owner - C:\Program Files\CyberLink\Shared Files\RichVideo.exe
O23 - Service: TrueVector Internet Monitor (vsmon) - Check Point Software Technologies LTD - C:\Windows\System32\ZoneLabs\vsmon.exe
O23 - Service: ePower Service (WMIService) - acer - C:\Acer\Empowering Technology\ePower\ePowerSvc.exe
End of file - 4149 bytes
merci d avance
Boot mode: Normal
Running processes:
Salut fred68
1) * Télécharge OTM (OldTimer) sur ton Bureau
>> OTM (OldTimer)
- Clique droit sur "OTMoveIt3.exe" et choisis "exécuter en tant qu'administrateur" afin de le lancer.
- Copie (Ctrl+C) le texte suivant en gras ci-dessous :
:files
:reg
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{83A2F9B1-01A2-4AA5-87D1-45B6B8505E96}]
ShowBarObj Class =-
:commands
[purity]
[emptytemp]
[Reboot]
- Colle (Ctrl+V) le texte précédemment copié dans le cadre: Paste Instructions for Items to be Moved.
- Clique maintenant sur le bouton MoveIt!
Si un fichier ou dossier ne peut pas être supprimé immédiatement, le logiciel te demandera de redémarrer.
Accepte en cliquant sur YES.
- Poste le rapport situé dans ce dossier : C:\_OTMoveIt\MovedFiles\
Le nom du rapport correspond au moment de sa création : date_heure.log
ensuite
2) * Désactives ton antivirus
* Telecharge et install UsbFix (de El Desaparecido et C_XX )
* Déconnectes toi et fermes toutes applications en cours
* Au message >> Branche tes sources de données externes à ton PC, (clé USB, disque dur externe, etc...) susceptibles d avoir été infectés sans les ouvrir
* Double clic sur le raccourci UsbFix présent sur ton bureau .
* Choisi >> l option 2 ( Suppression )
* Laisse travailler l outil.
* Ensuite poste le rapport UsbFix.txt qui apparaitra.
* Note : Le rapport UsbFix.txt est sauvegardé a la racine du disque. ( C:\UsbFix.txt )
( CTRL+A Pour tout selectionner , CTRL+C pour copier et CTRL+V pour coller )
* Réactives ton antivirus
VIRUS/C/C Helper - Formation - Qualification Helper
Contributeur sécurité -
Salut
* Bienvenue sur CCM !
* Ensemble nous allons essayer de régler ton problème .
* N'ouvre pas d'autres sujets pour le même problème >> sur ce forum ou sur un autre
* N'hésite pas à poser des questions en cas de besoin
* Sois patient(e) quand tu postes un message,
* En tant que bénévole et je ne suis pas en permanence devant mon PC.
* La désinfection se déroulera en plusieurs étapes.
* Même si les symptômes de l'infection te semblent avoir disparu,
* la désinfection ne sera terminée que quand je te le dirai
* Merçi de revenir jusqu'au bout, sinon ce qu'on a fait n'aura servi à rien.
1)* Télécharge Random's System Information Tool (RSIT) par random/random et sauvegarde-le sur ton Bureau.
* Double-clique sur RSIT.exe afin de lancer RSIT.
* Sous ==> Windows7/ Vista.
* Clic droit sur l'icône RSIT.exe , puis sur Exécuter en tant qu'administrateur dans le menu déroulant,afin de lancer RSIT.
* Clique sur Continue à l'écran Disclaimer.
* Si l'outil HijackThis (version à jour) n'est pas présent ou non détecté sur l'ordinateur, RSIT le téléchargera et tu devras accepter la licence.
* Lorsque l'analyse sera terminée, deux fichiers texte s'ouvriront.
* Poste le contenu de log.txt (<==qui sera affiché) ainsi que de info.txt (<==qui sera réduit dans la Barre des Tâches).
* Héberge les rapports un par un sur ce site,
cijoint.fr
* Copie/colle les liens générés ici
* Note : Les deux rapports sont également sauvegardés %systemroot%\rsit
Pour les rapports
* rends toi sur http://www.cijoint.fr
* clic sur Parcourir
* trouve >> le rapport que tu viens d'enregistrer qui doit par exemple être sur ton bureau
* et valide en cliquant sur >> Cliquez ici pour déposer le Fichier
* un lien de ce genre http://www.cijoint.fr/cjlink.php?file=cj201004/cijecaEGX.txt te sera généré,
* il te suffit de le poster
ensuite
2)*Télécharges --> Malwarebytes' (mbam)
* installes + mise a jour
* Lances--> Malwarebytes (MBAM)
* Puis vas dans l'onglet "Recherche", coche >>Exécuter un examen complet
* puis "Rechercher"
* Sélectionnes tes disques durs" puis clique sur "Lancer l'examen"
* A la fin du scan, clique sur Afficher les résultats puis sur Enregistrer le rapport
*Si MalwareBytes' détecte des infections, clique sur ==>Afficher les résultats, puis sur ==>Supprimer la sélection
* S'il t' es demandé de redémarrer, clique sur "oui "
* aprés la suppression(s) de ou des infections trouvées --> poste le rapport ici
deja merci d avoir repondus et pour ton aide, j ai fait ce que tu m as dit avec RSIT et je poste le resultat, pour mbam j ai deja fait un scan et il ne me trouve rien, j ai supprime l entree dans le system32 avec files assassin mais j ai toujours la ligne dans hijack this !!!!
http://www.cijoint.fr/cjlink.php?file=cj201006/cijXCNBWDN.txt pour le fichier log
http://www.cijoint.fr/cjlink.php?file=cj201006/cijBDWRDqB.txt pour le fichier info
