Probléme avec LFS 6.6
bon jour
j'utilise le livre LFS 6.6 au 5eme chapitre lors de la compilation de gcc a la fin de la compilation il m'affiche le message d'éreure suivant:"
make[2]: Entering directory '/mnt/lfs/sources/gcc-4.4.3/i686-lfs-linux-gnu/libgcc'
Makefile:143: ../.././gcc/libgcc.mvars: No such file or directory
make[2]: *** No rule to make target '../.././gcc/libgcc.mvars'. Stop.
make[2]: Leaving directory '/mnt/lfs/sources/gcc-4.4.3/i686-lfs-linux-gnu/libgcc'
make[1]: *** [all-target-libgcc] Error 2
make[1]: Leaving directory '/mnt/lfs/sources/gcc-4.4.3'
make: *** [all] Error 2"
et lors de exécution de la commende "make install" il m'affiche un autre message son contenu est
" make[1]: Entering directory '/mnt/lfs/sources/gcc-4.4.3'
/bin/sh ./mkinstalldirs /tools /tools
make[2]: Entering directory '/mnt/lfs/sources/gcc-4.4.3/host-i686-pc-linux-gnu/fixincludes'
rm -rf /tools/libexec/gcc/i686-lfs-linux-gnu/4.4.3/install-tools
rm: cannot remove '/tools/libexec/gcc/i686-lfs-linux-gnu/4.4.3/install-tools/mkheaders': Permission denied
rm: cannot remove '/tools/libexec/gcc/i686-lfs-linux-gnu/4.4.3/install-tools/fixincl': Permission denied
rm: cannot remove '/tools/libexec/gcc/i686-lfs-linux-gnu/4.4.3/install-tools/fixinc.sh': Permission denied
rm: cannot remove '/tools/libexec/gcc/i686-lfs-linux-gnu/4.4.3/install-tools/mkinstalldirs': Permission denied
make[2]: [install] Error 1 (ignored)
/bin/sh ../.././fixincludes/../mkinstalldirs /tools/libexec/gcc/i686-lfs-linux-gnu/4.4.3/install-tools
/bin/sh ../.././fixincludes/../mkinstalldirs /tools/lib/gcc/i686-lfs-linux-gnu/4.4.3/install-tools/include
/usr/bin/install -c -m 644 ../.././fixincludes/README-fixinc \
/tools/lib/gcc/i686-lfs-linux-gnu/4.4.3/install-tools/include/README
/usr/bin/install -c fixinc.sh /tools/libexec/gcc/i686-lfs-linux-gnu/4.4.3/install-tools/fixinc.sh
/usr/bin/install: cannot remove '/tools/libexec/gcc/i686-lfs-linux-gnu/4.4.3/install-tools/fixinc.sh': Permission denied
make[2]: *** [install] Error 1
make[2]: Leaving directory '/mnt/lfs/sources/gcc-4.4.3/host-i686-pc-linux-gnu/fixincludes'
make[1]: *** [install-fixincludes] Error 2
make: *** [install] Error 2"
c'est quoi le problème ?
merci d'avance pour votre aide
  1. merci KuKrApOk59
    j'ai vérifier les droit de l'utilisateur lfs sur les dossiers sources et tools je n'ai pas de problèmes la dessus les périssions sont correctes
    si je n'arrive pas a déterminer le problème comment faire pour recommencer à partir de quelle étape je dois reprendre sachons que la compilation et l'installation de Binutils est correcte
    1. SAlut,
      Au vu de
      Je te conseille de vérifier que les droits sur tes fichiers sont corrects ...
      Si vous avez votre réponse, pensez à spécifier : [Résolu]
