Problem Could not load file or assembly forum
bonjour,
j'ai un probleme grave stp aide moi
quand j'entre sur le forum startimes2.com, ou forum kooora il me dit ca
Server Error in '/' Application.
Could not load file or assembly 'forum' or one of its dependencies. There is not enough space on the disk. (Exception from HRESULT: 0x80070070)
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.IO.FileLoadException: Could not load file or assembly 'forum' or one of its dependencies. There is not enough space on the disk. (Exception from HRESULT: 0x80070070)
Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.
Assembly Load Trace: The following information can be helpful to determine why the assembly 'forum' could not be loaded.
WRN: Assembly binding logging is turned OFF.
To enable assembly bind failure logging, set the registry value [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1.
Note: There is some performance penalty associated with assembly bind failure logging.
To turn this feature off, remove the registry value [HKLM\Software\Microsoft\Fusion!EnableLog].
Stack Trace:
[FileLoadException: Could not load file or assembly 'forum' or one of its dependencies. There is not enough space on the disk. (Exception from HRESULT: 0x80070070)]
[FileLoadException: Could not load file or assembly 'forum, Version=1.0.3751.17816, Culture=neutral, PublicKeyToken=null' or one of its dependencies. There is not enough space on the disk. (Exception from HRESULT: 0x80070070)]
System.Reflection.Assembly._nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, Assembly locationHint, StackCrawlMark& stackMark, Boolean throwOnFileNotFound, Boolean forIntrospection) +0
System.Reflection.Assembly.InternalLoad(AssemblyName assemblyRef, Evidence assemblySecurity, StackCrawlMark& stackMark, Boolean forIntrospection) +416
System.Reflection.Assembly.InternalLoad(String assemblyString, Evidence assemblySecurity, StackCrawlMark& stackMark, Boolean forIntrospection) +166
System.Reflection.Assembly.Load(String assemblyString) +35
System.Web.Configuration.CompilationSection.LoadAssemblyHelper(String assemblyName, Boolean starDirective) +190
[ConfigurationErrorsException: Could not load file or assembly 'forum, Version=1.0.3751.17816, Culture=neutral, PublicKeyToken=null' or one of its dependencies. There is not enough space on the disk. (Exception from HRESULT: 0x80070070)]
System.Web.Configuration.CompilationSection.LoadAssemblyHelper(String assemblyName, Boolean starDirective) +11204104
System.Web.Configuration.CompilationSection.LoadAllAssembliesFromAppDomainBinDirectory() +388
System.Web.Configuration.CompilationSection.LoadAssembly(AssemblyInfo ai) +232
System.Web.Configuration.AssemblyInfo.get_AssemblyInternal() +48
System.Web.Compilation.BuildManager.GetReferencedAssemblies(CompilationSection compConfig) +210
System.Web.Compilation.BuildProvidersCompiler..ctor(VirtualPath configPath, Boolean supportLocalization, String outputAssemblyName) +76
System.Web.Compilation.ApplicationBuildProvider.GetGlobalAsaxBuildResult(Boolean isPrecompiledApp) +283
System.Web.Compilation.BuildManager.CompileGlobalAsax() +50
System.Web.Compilation.BuildManager.EnsureTopLevelFilesCompiled() +676
[HttpException (0x80004005): Could not load file or assembly 'forum, Version=1.0.3751.17816, Culture=neutral, PublicKeyToken=null' or one of its dependencies. There is not enough space on the disk. (Exception from HRESULT: 0x80070070)]
System.Web.Compilation.BuildManager.ReportTopLevelCompilationException() +76
System.Web.Compilation.BuildManager.EnsureTopLevelFilesCompiled() +1012
System.Web.Hosting.HostingEnvironment.Initialize(ApplicationManager appManager, IApplicationHost appHost, IConfigMapPathFactory configMapPathFactory, HostingEnvironmentParameters hostingParameters) +1025
System.Web.HttpRuntime.FirstRequestInit(HttpContext context) +11297830
System.Web.HttpRuntime.EnsureFirstRequestInit(HttpContext context) +88
System.Web.HttpRuntime.ProcessRequestNotificationPrivate(IIS7WorkerRequest wr, HttpContext context) +4336948
Version Information: Microsoft .NET Framework Version:2.0.50727.4200; ASP.NET Version:2.0.50727.4016
je comprend rien méme j'ai fé des recherche sur google et aucune reponse aide moi
et merci d'avance
9 réponses
  1. Le problème ne vient pas de vous mais du serveur de startimes2.
    1. nn ya pas ):
      on peut juste espérer qu'il marche demain inchaallah
      1. c pas seulement toi mais c pareille pour les autres aussi ):
        1. moi aussi j'ai le même problème
          svp aidez nous c'est vraiment urgent je ne peux pas accèder à startimes2
          svp
