probleme esyphp
j'ai un probleme avec easyphp.
j'ai intalé le programme mais il ya un truc qui ne veut pas marcher et quand j'ouvre la fenetre easy php il ya marqué apache démarre et mysql arreté je fais demarer et ça marche pendant 3 segond et apres il ya une fenetre et il ya marqué unexpected end of mysql... see log file ? moi je fais oui et apres il ya ce truc la qui aparé et a propos j'ai windows vista basic
InnoDB: The first specified data file .\ibdata1 did not exist:
InnoDB: a new database to be created!
090620 22:47:44 InnoDB: Setting file .\ibdata1 size to 10 MB
InnoDB: Database physically writes the file full: wait...
090620 22:47:44 InnoDB: Log file .\ib_logfile0 did not exist: new to be created
InnoDB: Setting log file .\ib_logfile0 size to 10 MB
090620 22:47:45 InnoDB: Log file .\ib_logfile1 did not exist: new to be created
InnoDB: Setting log file .\ib_logfile1 size to 10 MB
InnoDB: Doublewrite buffer not found: creating new
InnoDB: Doublewrite buffer created
InnoDB: Creating foreign key constraint system tables
InnoDB: Foreign key constraint system tables created
090620 22:47:45 InnoDB: Started; log sequence number 0 0
090620 22:47:46 [Note] Event Scheduler: Loaded 0 events
090620 22:47:47 [Note] C:\PROGRA~1\EASYPH~1.0\MySql\bin\mysqld.exe: ready for connections.
Version: '5.1.30-community' socket: '' port: 3306 MySQL Community Server (GPL)
InnoDB: The log sequence number in ibdata files does not match
InnoDB: the log sequence number in the ib_logfiles!
090620 22:52:02 InnoDB: Database was not shut down normally!
InnoDB: Starting crash recovery.
InnoDB: Reading tablespace information from the .ibd files...
InnoDB: Restoring possible half-written data pages from the doublewrite
InnoDB: buffer...
090620 22:52:02 InnoDB: Started; log sequence number 0 46409
090620 22:52:02 [Note] Event Scheduler: Loaded 0 events
090620 22:52:02 [Note] C:\PROGRA~1\EASYPH~1.0\MySql\bin\mysqld.exe: ready for connections.
090620 22:52:42 [Note] C:\PROGRA~1\EASYPH~1.0\MySql\bin\mysqld.exe: Arrêt normal du serveur
090620 22:52:43 [Note] Event Scheduler: Purging the queue. 0 events
090620 22:52:43 InnoDB: Starting shutdown...
090620 22:52:43 InnoDB: Shutdown completed; log sequence number 0 46409
090620 22:52:43 [Note] C:\PROGRA~1\EASYPH~1.0\MySql\bin\mysqld.exe: Arrêt du serveur terminé
qu'est ce que je dois faire pour que ça marche ???
    Bonjour,*
    S'il vous plaît
    Au revoir
    etc.
    Sont monnaie courante quand on veut obtenir quelque chose !
    Saine lecture...
    A voir aussi
    * Ne pas en tenir compte si présent dans le message initial, mais bon vu qu'il est ajouté automatiquement, ça ne fait pas de mal.
