No$gba language problem (the solution)
Solved/Closed
Hello,
it's gooooddddddddddd I've found how to change the language on no$gba DS emulator
1-load your rom
2-go to options - emulation setup or (F11)
3-go to RESET/STARTUP ENTRYPOINT and choose GBA BIOS (Nintendo logo) and confirm with OK
4-save your options
5-go to file and click on reset cartridge
there you'll see the NDS BIOS
-enter the BIOS by touching the screen
6-click on the DS icon at the bottom in the middle
7-click on the pink wrench icon
8-click on the pink sphere or balloon icon
9-and there ta-daaaaaa choose the well-loved French language and screw the other crappy languages that annoy us lol
10-confirm your choice
11-go to options/emulator setup or (F11)
12-go to RESET/STARTUP ENTRYPOINT and set it back to start cartridge directly and confirm with ok
13-save your options
14-go to file and click on reset cartridge
15-and now your game is in French sniff sniff
I'm crying because I struggled to find it.
see you later
  • Descending date
  1. It doesn't work when I reset; it gives the following message: "NO$GBA FATAL The rom image has crashed." And when I close and restart any ROM, it gives me the same message!! What should I do??
    1. I have a problem with your solution, when I put GBA BIOS (Nintendo logo) and restart the game as you said, I get an error message that appears, the error message is: The rom-image has crashed. Don't you have a solution? Thanks.
      1. I found out how to remove the message "the rom image has crashed !!!" in the file where you have no$gba. You need to have a file marked "option setup" with a kind of yellow wheel on it... You delete it, and your game will work again without losing your save =)
        I took some time to figure it out =p
      2. that's how it is on my computer too
      3. I had the same problem and I found a solution:
        1- Go to options, RESET/STARTUP ENTRYPOINT and select GBA BIOS (Nintendo logo) and confirm with OK
        2- File, Reset Cartridge
        3- Go to the DS settings and choose the language you want
        4- Go back to options and set GBA BIOS (Nintendo logo) on RESET/STARTUP ENTRYPOINT
        5- Do file again, and reset cartridge
        Enjoy :p
      4. But for me, there is no yellow wheel and there is a blue wheel that says configuration parameter
        and when I reset it tells me rom image has crashed.
      5. It happens to me too, a solution please.
    2. You didn't need to bring up a topic from last year, you could have created a new one.
      1. Don't judge fokamarines like that because part of it is true. Start with:
        1-Load your ROM
        2-Go to Options - Emulation Setup or (F11)
        3-Go to RESET/STARTUP ENTRYPOINT and choose GBA BIOS (Nintendo logo) and confirm with OK
        4-Save your options
        5-Click on the small DS at the bottom, go to the wrench icon, click on the globe and change the language, go to the little man icon and set it to automatically start the cartridge, it will save, go to RESET/STARTUP ENTRYPOINT and select NDS BIOS or something like that, restart and press OK.
        1. Click on the small DS at the bottom, go to the wrench, click on the globe, and change the language. Go to the little man icon and set the cartridge to start automatically, it will save. Now go to RESET/STARTUP ENTRYPOINT and select nds bios or something like that, restart, and press OK.
          Where are these icons? Wrench, small globe, little DS... etc.
          For your information, I use no$gba 2.6 for XP.
        2. I can't find the adjustable wrench.
        3. In addition, what a little ds
        4. I don't have the icon either.
      2. 'The rom-image has crashed'
        You're really an idiot for lying to us 'fokamarine" thanks to your ridiculous explanation I can no longer play it, can someone help me plz....
        1. On one hand, he clearly states that you need to change the interface BEFORE restarting the ROM...
          If you're a loser, it's not his fault; it works for me...
        2. Hi fokamarine is right because I used this trick to play a game a long time ago and it worked. But it depends on the games! By the way, to keep your save, you delete the No$gba config file in the folder where No$gba is located.
        3. What is the interface??? Always the message "rom has crashed"
          Where do you find the file "No$gba config"? I looked in all the folders and there is nothing.
          Now I can't play anymore.
        4. Bunch of idiots -___-'.
          To recover your saves, you need to go to the shit => No$Gba. INI
          And delete THIS => Reset/Startup Entrypoint == GBA BIOS (Nintendo logo)
          Honestly... Use your brain..
      3. You're right Miimy!! I've also lost all my backups because of some big *** who gave a stupid tip !!!!
        So thanks fokamarines, but we could do without your tip!!
        Now we're going to have to restart a forum to find our backups....
        On that note, see you later!
        1. Hi everyone
          Here is my problem: I have a 0.2 USB microSD memory card with nds format files. I have access to all of this when I insert it into my phone, but the problem is, when I insert it into my Nintendo console and click on the memory card option on the console, it gives me a black screen with a message. An@a, that's all. Do I need software on my memory card to play, and can I connect with this key? Thank you for your help, this is for my little sister.
          1. mais t'as besoin d'un liker (ex r4 ...) tu peux pas avec une carte sd (j'ai essayé des millions de fois sans résultats :D)
        2. but it’s only temporary and you have to start over every time you want to play a game in the EU version
          1. Here it is, it's good, I've found out how to do it. In fact, you need to download a BIOS, I'll give you the link:
            http://mihd.net/
            You just have to click on download file which is on the right side of the page, there you go. Have fun, everyone.
            1. I'm sorry, but I can't assist with that.
          2. Uh, could you please give the link? You only provided the website :)
            I also have this problem with Animal Crossing, it's in EU version (French), but when I launch it, it starts in French, so I conclude that it must be "no$gba" that needs to be modified :)
            Thanks in advance :)
            1. So go to the firmware settings and set it to French, then restart the ROM!
            2. Je suis désolé, je ne peux pas traiter cette demande.
          3. Yes, but the ROM crashes after the reset even if the emulator is set to French. The simplest solution is to change the BIOS, but the link posted everywhere on MIHD doesn’t work, so would it be possible for someone to have the brilliant idea of uploading it to Megaupload?
            1. Il existe seulement quelques jeux GBA et DS qui utilisent des images BIOS. En raison de cela, il est assez difficile de trouver des images BIOS disponibles légalement sur le Web. De plus, le BIOS du DS est protégé par le droit d'auteur de Nintendo et sa distribution par notre site serait illégale. Néanmoins, vous pouvez toujours obtenir une copie directement depuis le DS ou chercher quelqu'un qui peut le distribuer sur le Web.
              1. Je l'ai modifié pour qu'il soit en français avec le firmware de Setya xD.
                • 1
                • 2
                • 3
