Problem with Pro Evolution Soccer 2008
Solved
Hello,
I bought Pro Evolution Soccer 2008 this afternoon, I installed it, but the problem is that my computer is asking me to insert the CD to play even though it is already inside. If it can help you, I have an Acer laptop with Vista
Configuration: Windows XP Firefox 2.0.0.8
  • Descending date
  1. you need the crack
    1. Comment jouer à PES 2008 en ligne ?
  2. I downloaded PES 2008 and I installed it, and now when I launch the game it tells me.
    The inserted disc is not correct.
    Please insert the original "Pes2008" cd/dvd.
    Please help me, thank you in advance.
    1. Here is the SERIAL: NA9C-97AN-HSLC-46R5-JYM9
      1. T'es pas un peu idiot de donner ton code serial ?!!!!!!
      2. Désolé, je ne peux pas vous aider avec ça.
      3. Thank you, you're so great! I've been looking for it for a long time.
    2. Hello, I installed PES2008 and I played without any problems, so I wanted to play online. I installed patch 1.2 and when I launch the game it asks me to insert the CD. Can someone help me please?
      1. It depends, I might have a solution but it wouldn't be the best we could do.
        Otherwise, tell me more things.
        Nussbi
        1. Hello,
          I have crackling sound in PES 2008, but not on other games or Windows Media Player.
          Thanks for helping me if someone has already solved this problem, thank you.
          1. Hello,
            I bought pes2008 this afternoon and I can't install it... when I click on install, an error message pops up saying:
            "The system DLL user32.dll has been relocated in memory. The application will not run properly. The relocation was made because the DLL C:\windows\system32\SHELL32.dll occupied an address range reserved for system DLLs of Windows NT"
            Please help me, I'm really frustrated that I bought the game and can't play it...
            Thanks in advance!
            1. Hello,
              it's normal, check if the game works with Vista because I believe it only works with XP.
              1. the game works with vista and xp sp1 or sp2.
                me vista asus p5ne-sli 8800gts 320mo. duo 6320.
                one thing!!! shitty server!!! I always lose!!! it lags!!!!
            2. Wesh les gars, il me faudrait le serial qui est demandé à l'installation, merci d'avance.
              1. Salut, j'ai acheté Pro 8 mais je ne peux pas l'installer, il me demande le serial, s'il te plaît aide-moi.
              2. Hello
                I just bought PES8, but when I install it, it says "drive f:/ not valid"
                Could you please help me?
                I don't understand because I had no issues with the previous versions (PES5 and 6)
                Thank you in advance
                1. Hi,
                  Did you find the answer to your problem because I have the same one as you
                  Thank you
              3. Bonjour, j'ai acheté PES8, pouvez-vous me dire comment je l'installe s'il vous plaît ?
                1. Hi everyone, I bought PES 2008 and I can't play it on my computer because it's Windows Vista! Do you have a solution??
                  Thanks in advance!
                  1. OH guys......... WAKE UP!!!
                    We ALL have the same problem. How to use PES 2008 on VISTA???? Also, I have an 8600 GT graphics card and PES tells me that my card is not strong enough............
                    Help, I need somebody, HELP!!!!!!!!!!
                    1. Resolved!!!!!!!!!!!!!!!!!!
                      PES 2008 works very well on Vista and with GeForce 8600 GT....... you just need to download the program
                      158.18_forceware_winvista_32bit_international: :)
                      I hope this helps someone!!!!!!!!!!
                      Come on Paris!!!!!!! Stand up!!!!!!!!!
                      1. Hello, I don't have Vista or Media Center. The game runs normally, but when I installed patch 1.2, at launch it asks for the CD. I inserted the CD and it still doesn't work. :(
                        1. I managed to play once with the game (~1 hour), but when I launched the game the second time, my computer crashed (black screen) and restarted showing an error message.
                          I meet the required specifications (RAM, graphics card, and processor)
                          I uninstalled and reinstalled the game after cleaning and defragmenting, but it still crashes!
                          Does anyone have a solution?
                          1. Hello!
                            I have the same issue, the first time no problems and the next day after 10 minutes a blue screen with a message that I don't have time to read...
                            Have you found a solution?
                            Thanks in advance
                            See you later
                            pharaoh
                        • 1
                        • 2
