SSD front panel case red LED flashing quickly
1 answer
Contributor
Hello
If it works well....
Normally, the LED on the case indicates that the disk (SSD) is being used (read/write), and you should be able to see that in the task manager, under the "performance" tab. If the usage is constantly at 100%, that's not normal; otherwise, it's fine.
Signature
Waiting for other responses; I'm attracting trolls....
