Connection on TV (audio jack to TV optical input)
Solved
matdem06 Posted messages 6 Status Member -
 matou -
Hello,
My parents have headphones (I assume Bluetooth) to watch TV.
From the headphone box, I have a cable with a male audio jack output.
But my TV does not accept an input with this audio jack.
However, it does have an "optical" input (highlighted in red in the photo). In the audio preferences of the TV sound, I have 2 options: speaker or optical.
=> How can I connect to this optical connector? What adapter should I get?
Otherwise, there are also some more classic audio jacks (highlighted in blue in the photo). I have the cable adapter from my audio jack to the two red and white outputs, but regarding the TV settings, I don’t see the option for this choice, so I don’t know what it’s for. Is it an audio output (and not an input)?
Thank you for your responses.
Best regards,
Mat
  1. baladur13 Posted messages 47340 Registration date   Status Moderator Last intervention   14 396
    Hello,
    The connections highlighted in blue are inputs (AVIN) for the television.
    If there is only one optical output, you will need an Optical IN / 3.5mm jack out converter.
    What are the references (Brand and model):
    - of the television?
    - of the headset?
    This is to find the most suitable converter for these devices.
    Very difficult to catch a black cat in a dark room.
    Especially when it isn't there...
    1. matdem06 Posted messages 6 Status Member
      Thank you for your response (yes, I understood that RCA jacks = input).
      I will gather information and get back to the forum to provide these details on the TV and headphone models.
      So my parents are also asking me: is it possible to listen to the sound on the speakers and at the same time on the audio headphones? In the TV's audio settings, I can only choose one or the other (Speakers or Optical).
      I don't see how that's possible.
      Before, they had a Canal Plus box and apparently, by using this box, it was possible.
      Mat
    1. Andy31200 Posted messages 26918 Registration date   Status Moderator Last intervention   12 203
      Good evening,
      These two converters may be suitable.
  2. matdem06
    However, I read some comments saying that the volume was not adjustable?!! :(
    Do you have an opinion on this?
    Are there converters that allow you to adjust the volume if that's the case?
    I saw this one:
    https://www.amazon.fr/Convertisseur-Num%C3%A9rique-Analogique-Aluminium-Adaptateur/dp/B09MK8GKSK/ref=pd_sbs_sccl_4_4/261-4148039-5450968?pd_rd_w=yrAEc&pf_rd_p=075589f6-3852-493e-aff6-e210133e3ed2&pf_rd_r=Z94DP9952QJHSZ71WR83&pd_rd_r=bdd9fcd4-aedf-45fe-bcab-330307659ae3&pd_rd_wg=qEjLW&pd_rd_i=B09MK8GKSK&psc=1
    Mat
  3. baladur13 Posted messages 47340 Registration date   Status Moderator Last intervention   14 396
    The headsets have their own volume control
    So there’s no need for a control on the converter, but why not.
    As for the television speakers... Using the optical output doesn't affect the sound from the television... however, if you want, you can mute the sound on the speakers.
    Supplementary question: who provides the image to the television?
    A decoder, a TV box?
    These devices also have audio outputs, which can be used just like the TV’s.
    Especially when it’s not there...
      Hello and thank you for this explanation. I'll test it to try to get the sound on the speakers + on the headset and see if it works as soon as I buy the converter.
      So basically all the converters I linked are good?
      Aren't there any better ones for my needs?
      Should I just get the cheapest one?
      The image (and sound) come from a Freebox. We checked and we can't plug anything into it.
      Mat
    2. baladur13 Posted messages 47340 Registration date   Status Moderator Last intervention   14 396 > matdem06 Posted messages 6 Status Member
      The image (and sound) comes from a Freebox. We checked and we can't plug anything into it.
      Um...? Generally, there is always an audio output (optical or coaxial) on TV boxes.
      What model is this Freebox TV or Free player?
    3. matdem06 > baladur13 Posted messages 47340 Registration date   Status Moderator Last intervention
      Good evening, this concerns the payment for the Freebox Pop.
      So I searched online and it seems that it is possible to connect to an SPDIF port. I will look into what that corresponds to, I don't know.
      So what do you advise me?
      Mat
    4. baladur13 Posted messages 47340 Registration date   Status Moderator Last intervention   14 396 > matdem06
      The S/PDIF output of the Freebox Pop player is an optical audio output.
      So you can connect your headphones either to the TV output or to the Pop player output using the same type of converter...
      There is probably something to do in the player menu as well.
  4. matou
    Thank you baladur13,
    I finally managed to find the right menu thanks to your link :)
    And it works!
    Have a great summer everyone
    Matou
