Logitech G Pro X sound issue
Maxime_4230 Posted messages 1 Status Member -
 Azal -
Hello, I bought a Logitech G Pro X and I received it today. When I plug in the headset, the sound only comes from the right side, the left side is completely non-existent. Do you have a solution to fix this issue?
Best regards
1 answer
  1. cathseba
    Hello,
    I had the same issue and there is no solution, you need to follow the warranty service procedure.
    12
    1. Hayden
      I just had this problem in 3 seconds, the headset was working perfectly and suddenly the right side stopped functioning again after all this time?
      1. Azal > Hayden
        I've had the headset for 1-2 years and I'm currently experiencing this problem, the left side doesn't work anymore, do you have a solution?
