TV Problem "Scrambled Signal CI+ Module or Smart Card Not Found"
Solved
HugoLeH Posted messages 27 Status Member -
 Joss -
Hello everyone,
I have a little problem with my Samsung TV.
I live in an apartment and I have a socket made for the TV (via cable) and this cable is connected to my TV.
Everything was fine for a year, but the only problem is that since yesterday, the channels are not found, I tried to reinstall them but nothing happens. It shows "Signal Scrambled, CI+ module or smart card not found, please check that they are properly connected."
Does anyone have a solution?
Thank you in advance!
  1. Andy31200 Posted messages 26918 Registration date   Status Moderator Last intervention   12 207
    Hello,
    This kind of message only appears on encrypted channels (like Canal, for example)
    You say:
    "I have a socket made for the TV (by cable)"
    Is this collective distribution coming from a collective aerial or a cable network?
    What's happening with your neighbors?
    I call a spade a spade *
    *in French in the text
    27
    1. HugoLeH Posted messages 27 Status Member
      Thank you for your reply,
      The collective distribution is done through a collective rooftop antenna.
      My neighbors are indeed receiving TV.
    2. Joss
      Go to punk menu ok then standard
