INDEX/MATCH Function - 2 Criteria for Column & 1 Criteria for Row
florntn Posted messages 2 Status Member -
Hello,
I have implemented the INDEX/MATCH function with a column criterion and a row criterion to search for a value in a table. It works wonderfully.
I would now like to do the same but with an additional column criterion. To find my value, I need two column criteria and one row criterion.
Thank you in advance,
The file: https://www.dropbox.com/s/d71yrt95viuuxuj/Florntn.xlsx?dl=0
Configuration: Windows / Chrome 63.0.3239.84
1 answer
  1. Vaucluse Posted messages 27336 Registration date   Status Contributor Last intervention   6 453
    Good evening
    there's no way to access your model without signing up. Try uploading it here:
    http://mon-partage.fr
    but already on principle:
    according to your images, it won't be possible to retrieve data from merged cells if needed (?)
    otherwise, on principle, the array formula to enter by pressing enter while holding the ctrl and shift keys down:
    (it should automatically display between curly braces in the formula bar)
    =INDEX(field to extract;MATCH(lookup value 1&lookup value 2;field 1&field 2;0))
    best regards
    The quality of the response mainly depends on the clarity of the question, thank you!
    4
    1. florntn Posted messages 2 Status Member
      Hello,
      Thank you very much for your response and your help. I was able to extract my data.
      Best wishes
