Technical TV Issue.
Hello,
I have a Technical LED3211DHDB television, the screen suddenly went almost black, but the sound is still working.
Can anyone help me?
What voltages should I check? I have opened the back of the TV.
Thank you
Configuration: Windows / Firefox 54.0
1 answer
  • Descending date
  1. Hello.
    To check the voltages, it is good to have the schematic of the television.
    I mean the schematic, not the manual ;-)
    Otherwise, visually, is there anything particular regarding the components and the printed circuit? A capacitor or other numerous components could be the cause of the failure. A cold solder joint as well. A good solder joint should shine (not be dull).
    People who fight can lose. People who do not fight have already lost.
    (Bertolt BRECHT)
