Loading impossible: battery temperature too low.
Solved/Closed
Good evening, my phone won't charge, no matter which charger I use or how many restarts I try... However, every time I plug in my phone, I get this message:
What should I do?
  • Descending date
  1. Good evening, I am a professional repair technician
    the problem comes from a micro component located next to the charging controller.
    It is called a "thermistor"
    the repair is possible without changing the motherboard and you will keep your data as well
    .COM
    1. chapo you're a pro 10/10
    2. @khaledHello, I have the same problem. Could you help me please?
    3. Hello, I currently have this issue. How long can the repair take if the technician has the part?
    4. Hello, how much can the repair cost?
