Problem reading AVI files on Sony DVD player via USB flash drive.
guiguibzh
Anonymous user -
Anonymous user -
Hello
I have a Sony DVP-SR760H DVD player and I have certain files marked .avi that my player does not recognize and cannot read.
Do you have a solution?
Thank you in advance.
Hello
You can also compare a file that works and one that doesn't using either mediainfo or vlc.
Is this the technical sheet of your player?
https://www.homecine-compare.com/lecteur-SONDVPSR760H-SONY-DVP-SR760H.htm
Also, pay attention to the resolution.
Regards -
Good evening, the reader may not read "avi" formats, only Xvid, MPEG1/MPEG4, JPEG. At that point, choose a video converter compatible with your operating system and convert the avi into Xvid, for example! See the software here @+
if you don't have what you like, like what you have!
