SABA LED22v11 LED TV issue
dede-the-geek- Posted messages 26 Status Member -
stewartia Posted messages 12469 Status Member -
Hello,
I would like to know if it is possible to factory reset a SABA LED22V11 television without the remote control?
I no longer have the remote control and I have disabled the AV and VGA outputs. How can I reactivate them?
Do you have any solutions to reset this TV??? Thank you in advance
Configuration: Windows 7 / Chrome 23.0.1271.97
1 answer
  1. stewartia Posted messages 12469 Status Member 2 936
    Hello, check here if you can find a replacement remote control: http://www.priceminister.com/s/t%E9l%E9commande+saba
