Battery Charge Time Calculation Formula
Solved
Toucherche
mahj -
mahj -
Hello,
I would like you to help me find the formula to calculate the charging time of a battery. Thank you for your responses.
Best regards
Best regards
Basically, you need to divide your battery capacity (in Amp-hours (Ah)) by the charging current of your charger.
Example:
a 100 Ah battery
a charger or other charging system delivering 10 Ah in charging current
100 Ah / 10 Ah = 10 hours of charging if the battery is completely discharged.
Best regards,
Example:
a 100 Ah battery
Best regards,
We have no unit left at the end.
Furthermore, a charger provides you with a charging current and not Ah, which represents the capacity of the battery, meaning the amount of amperes per hour!
Therefore, we have 100 Ah (capacity) / 10 A (charging current) = 10 hours of charging.
As found by energiemobile
