Pioneer car radio problem
Quentin64
Quentin64 -
Quentin64 -
Hello,
I bought a Pioneer car radio just a month and a half ago, I plug it in, it works perfectly. But for the last two or three weeks, the sound cuts out at times while the radio continues to play, whether with a CD or a USB stick. The sound occasionally comes back depending on the movements of the car. When I turn right, or left, or when I brake, the sound returns for a few seconds. I tried to disassemble the unit and move the cables behind it, but nothing helps. It’s quite frustrating to buy equipment that stops working a month later.
Can someone help me?
1 answer
Try with another test car radio, there are old ones for 5€.
I lean more towards a problem with the insulation of your cables under the dashboard.-
Before this car radio, there was the original one that was mounted and I never had this problem.
The connection cables that are under the dashboard are covered in a sort of soft foam. If this were due to an insulation problem, the sound wouldn't work at all, would it? Yet it works sometimes. What would you advise me to check?
Thank you for your response. -
