Watch problem help please
wesss54 Posted messages 3 Status Member -
 jo -
Hello,
I purchased a Quiksilver Fashion Chapter M141DL watch and I can't figure out how to set the time and date... If someone could help me, that would be really nice, thank you.
  1. olive
    1= Select the function to set to "MODE" (DATE - TIME, TIMER (countdown) or ALARM)
    2= Press SET/EL for at least 3 seconds
    3= Select the parameter to modify (for example: HOUR - MINUTES - SEC - DAY etc.) by pressing MODE
    4= Increase or decrease the value by pressing either of the two buttons on the right ST/STP or RESET
    5= Exit the setting by pressing SET/EL
    There you go, it's simple, isn't it? ;)
    30
    1. jo
      I had lost the manual, and I thought that going about it intuitively would work... but not at all!
      Thank you for this clear and precise information!!
  2. wesss54 Posted messages 3 Status Member 1
    I bought it at an auction and there was no manual, sorry.
  3. arth Posted messages 84 Registration date   Status Contributor Last intervention   1 296
    Logically, it should come with a user manual, unless it has simply been stolen...
  4. arth Posted messages 84 Registration date   Status Contributor Last intervention   1 296
    Apart from contacting Quiksilver through their website, I don't see any other option.
  5. wesss54 Posted messages 3 Status Member 1
    Well, I wanted to know if someone could help me before I contact them. Because while "fiddling" a bit with the buttons, I managed to more or less set it to the right time, then I wanted to set it to the correct time and now I've messed everything up and I can't find it at all. Thank you anyway.
