S4 League won't start.
Solved
guigui9638
Posted messages
3
Status
Member
Cacatoes -
Cacatoes -
Hello,
I installed S4 League on my computer correctly yesterday by following the instructions, etc.
At the end of the installation, the S4 League icon appeared on my desktop. I clicked on it; a page opened with 3 characters and below "start," "register," and "cancel."
I think that’s normal so far. Then I clicked on "start," and here’s the problem: a small white box loads very quickly and disappears after reaching 100%. The hourglass appears, then nothing.
Have you ever encountered this problem?
If so, could someone help me?
Thank you
Thank you
- 1
- 2
- 3
- 4
Next
But it's not difficult for the timer. Go to the control panel, make sure to add and remove programs, check for updates, and uninstall the internet update kb976325 or kb969897. Then restart, and normally that should fix it because there's something in the updates that prevents the game from starting.
It works on my PC, but when I install it at my friend's house, it shows xtrap, the screen turns completely white, and his PC restarts without me touching anything.
Is that normal????? -
Let go of the response from Erdoire, I don't even have internet 8 and it still doesn't work.
I would be, I was, I am... MachFalcoo -
Hello everyone, I'm like you, I have the same problem but none of your ideas are correct, let me tell you why... because when you download S4 League, you see that it has been downloaded correctly, but it's not our fault, it's the fault of the mods and admins... why? Because the old players who are currently playing haven't received any bugs or anything like that, so the software that launches the game's image is probably disabled because I already had an online game called Phoenix of Medgarde, so there's only one solution: contact the GMs or the admins through the S4 League website and let them know, thanks. And actually, for more information, add me at (Address removed Moderation CCM) good luck^^
Here is the translation:
"Here, I understand that you have problems. I have an answer: for me, it works. In fact, there is nothing complicated; it’s just that you downloaded some crap. You need to go to the game’s website, but only on the official site of the game. So if you downloaded it in one second, well, it’s not the right one. So go to the site where it asks you where you want to download it. For my part, I took mmosite. Seriously, do you think a well-made game weighs only 165 MB? Anyway, I'm going back to S4, and by the way, if what I told you still doesn't work, you need to turn off the firewall and the antivirus. What they tell you with Internet Explorer is wrong because you download with the Firefox modules, not Internet Explorer." -
I'm not finding any updates for Internet Explorer, only Microsoft Windows. Should I remove that? Please help.
I think I know, but I'm not sure. Normally, there's another blue icon with some kind of arrows; you need to do those updates.
lol I also had this kind of problem except that when I click on start, the screen goes black and then there’s a lot of stuff written on a blue background, then it restarts my computer. I don’t know how to fix this but if someone has an answer, please help me. snif ^^ Thanks in advance.
I don't know, anyway it's normal, I also have the thing 100% after the game launches it says alaplaya... send an email to a GM ;)
B1 you know what ............ after all these comments and all the trillilil and trallala ........ (bla bla bla bla bla "same problem" b1 G finally found the solution =======================================> uninstall it and find another game to play ..... it's simple **..... thanks r1 *......
I'm sorry, but I need more context to provide an accurate translation. Please provide a complete sentence or more information.
Hello everyone, I downloaded S4 League, then I hit Start.
Then, HGW game watcher comes up, and when it's finished, the screen goes black, then I have to wait a bit, and then S4 League starts to load, and when the intro image appears it doesn't load, and it goes away.
What should I do? -
Pff, you are all a bunch of big NOOBS! It's way too easy
I WON'T RESPOND TO YOU =P NOOBS AHAHAHAHAHAHA X''')-
dog son, stop treating us like that, we don't know what's going on, and you're just a noob who plays badly in S4 League. I'm a pro, level 33 in Free 2. I've been playing for 2 years, and now I have a problem since I accidentally uninstalled it, and now it doesn't work, so you don't deserve your comment.
Hello everyone, I had a problem when I launch S4 League, there is a black screen and I return to the desktop. Of course, that's not normal. Is there a solution that could work, please? Thanks!
At home, I have 4 computers (1 with Vista, 1 with the latest Windows, and 2 with the old Windows) and I tried to install S4. I realized that on Vista and the latest Windows it works very well, but on the other Windows or the others, it doesn't work!!! Either it's because of your internet (updates) or there are other things that I haven't discovered yet (but probably from the download site).
- 1
- 2
- 3
- 4
Next
