Probleme de pub
j'ai des soucis avec les pub qui s'ouvrent et mon ordi ram si quelqu'un peut m'aider merci
Firefox 3.0.3
9 réponses
  1. telecharge ce prog :https://www.01net.com/404/­are/fiches/29061.html
    ouvre et clic sur : do a system scan and save .......
    attend le raport , 1min env
    copie le et met le ici pour voir
    1. il me marque que la page n'existe plus
      1. allors ici :http://www.malware-bytes.info/fr/
        1. oup c'est pas sa lol
          mais pas grave tu instal et garde malwarebytes quand mm c'est un bon prog.
          telecharge ici :https://www.01net.com/telecharger/windows/Securite/anti-spyware/fiches/29061.html
          1. Malwarebytes' Anti-Malware 1.28
            Version de la base de données: 1227
            Windows 5.1.2600 Service Pack 3
            04/10/2008 10:18:52
            mbam-log-2008-10-04 (10-18-52).txt
            Type de recherche: Examen complet (C:\|D:\|)
            Eléments examinés: 149724
            Temps écoulé: 45 minute(s), 39 second(s)
            Clé(s) du Registre infectée(s): 10
            Valeur(s) du Registre infectée(s): 2
            Elément(s) de données du Registre infecté(s): 0
            Dossier(s) infecté(s): 4
            Fichier(s) infecté(s): 18
            HKEY_CLASSES_ROOT\oberontb.band (Adware.Gamesbar) -> Quarantined and deleted successfully.
            HKEY_CLASSES_ROOT\TypeLib\{ad76633e-e50d-4844-9e7f-4dfbc7c18467} (Adware.Gamesbar) -> Quarantined and deleted successfully.
            HKEY_CLASSES_ROOT\Interface\{ec1a2105-5621-440f-987d-27ef428131d9} (Adware.Gamesbar) -> Quarantined and deleted successfully.
            HKEY_CLASSES_ROOT\CLSID\{6f282b65-56bf-4bd1-a8b2-a4449a05863d} (Adware.Gamesbar) -> Quarantined and deleted successfully.
            HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{6f282b65-56bf-4bd1-a8b2-a4449a05863d} (Adware.Gamesbar) -> Quarantined and deleted successfully.
            HKEY_CLASSES_ROOT\oberontb.band.1 (Adware.Gamesbar) -> Quarantined and deleted successfully.
            HKEY_CLASSES_ROOT\CLSID\{147a976f-eee1-4377-8ea7-4716e4cdd239} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
            HKEY_CLASSES_ROOT\CLSID\{9afb8248-617f-460d-9366-d71cdeda3179} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
            HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Extensions\{1a93c934-025b-4c3a-b38e-9654a7003239} (Adware.Gamesbar) -> Quarantined and deleted successfully.
            HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\internetgamebox (Adware.EGDAccess) -> Quarantined and deleted successfully.
            HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\dzihv (Adware.Navipromo.H) -> Quarantined and deleted successfully.
            HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Toolbar\{6f282b65-56bf-4bd1-a8b2-a4449a05863d} (Adware.Gamesbar) -> Quarantined and deleted successfully.
            C:\Program Files\InternetGameBox (Adware.EGDAccess) -> Quarantined and deleted successfully.
            C:\Program Files\InternetGameBox\ressources (Adware.EGDAccess) -> Quarantined and deleted successfully.
            C:\Program Files\InternetGameBox\ressources\favoris (Adware.EGDAccess) -> Quarantined and deleted successfully.
            C:\Program Files\InternetGameBox\skins (Adware.EGDAccess) -> Quarantined and deleted successfully.
            C:\Documents and Settings\HP_Administrateur\Local Settings\Application Data\dzihv_navps.dat (Adware.Navipromo.H) -> Quarantined and deleted successfully.
            C:\Documents and Settings\HP_Administrateur\Local Settings\Application Data\dzihv_nav.dat (Adware.Navipromo.H) -> Quarantined and deleted successfully.
            C:\Documents and Settings\HP_Administrateur\Local Settings\Application Data\dzihv.dat (Adware.Navipromo.H) -> Quarantined and deleted successfully.
            C:\Documents and Settings\HP_Administrateur\Local Settings\Application Data\dzihv.exe (Adware.Navipromo.H) -> Delete on reboot.
            C:\Documents and Settings\HP_Administrateur\Local Settings\Application Data\qdizfmbvqm_navps.dat (Adware.Navipromo.H) -> Quarantined and deleted successfully.
            C:\Documents and Settings\HP_Administrateur\Local Settings\Application Data\qdizfmbvqm_nav.dat (Adware.Navipromo.H) -> Quarantined and deleted successfully.
            C:\Documents and Settings\HP_Administrateur\Local Settings\Application Data\qdizfmbvqm.dat (Adware.Navipromo.H) -> Quarantined and deleted successfully.
            C:\Program Files\GamesBar\oberontb.dll (Adware.Gamesbar) -> Quarantined and deleted successfully.
            C:\Program Files\InternetGameBox\InternetGameBox.exe (Rogue.InternetGameBox) -> Quarantined and deleted successfully.
            C:\Program Files\InternetGameBox\language (Adware.EGDAccess) -> Quarantined and deleted successfully.
            C:\Program Files\InternetGameBox\uninst.exe (Adware.EGDAccess) -> Quarantined and deleted successfully.
            C:\Program Files\InternetGameBox\ressources\AttenteOff.html (Adware.EGDAccess) -> Quarantined and deleted successfully.
            C:\Program Files\InternetGameBox\ressources\AttenteOn.html (Adware.EGDAccess) -> Quarantined and deleted successfully.
            C:\Program Files\InternetGameBox\ressources\configv2_en.xml (Adware.EGDAccess) -> Quarantined and deleted successfully.
            C:\Program Files\InternetGameBox\ressources\configv2_es.xml (Adware.EGDAccess) -> Quarantined and deleted successfully.
            C:\Program Files\InternetGameBox\ressources\configv2_fr.xml (Adware.EGDAccess) -> Quarantined and deleted successfully.
            C:\Program Files\InternetGameBox\ressources\favoris\defaultv2.swf (Adware.EGDAccess) -> Quarantined and deleted successfully.
            C:\Program Files\InternetGameBox\skins\skinv2.skn (Adware.EGDAccess) -> Quarantined and deleted successfully.
        2. mais j'ai deja ad aware 2007
          1. Logfile of Trend Micro HijackThis v2.0.2
            Scan saved at 09:16:17, on 04/10/2008
            Platform: Windows XP SP3 (WinNT 5.01.2600)
            MSIE: Internet Explorer v6.00 SP3 (6.00.2900.5512)
            Boot mode: Normal
            Running processes:
            C:\WINDOWS\System32\smss.exe
            C:\WINDOWS\system32\lsass.exe
            C:\WINDOWS\system32\Ati2evxx.exe
            C:\WINDOWS\system32\ZoneLabs\vsmon.exe
            C:\Program Files\Lavasoft\Ad-Aware 2007\aawservice.exe
            C:\WINDOWS\Explorer.EXE
            C:\Program Files\Alwil Software\Avast4\aswUpdSv.exe
            C:\Program Files\Alwil Software\Avast4\ashServ.exe
            C:\WINDOWS\arservice.exe
            C:\Program Files\Fichiers communs\LightScribe\LSSrvc.exe
            C:\WINDOWS\system32\HPZipm12.exe
            C:\WINDOWS\system32\SearchIndexer.exe
            C:\Program Files\Alwil Software\Avast4\ashMaiSv.exe
            C:\Program Files\Alwil Software\Avast4\ashWebSv.exe
            C:\WINDOWS\system32\SearchProtocolHost.exe
            C:\PROGRA~1\ALWILS~1\Avast4\ashDisp.exe
            C:\WINDOWS\system32\LVCOMSX.EXE
            C:\Program Files\Logitech\Video\LogiTray.exe
            C:\Program Files\Hewlett-Packard\HP Boot Optimizer\HPBootOp.exe
            C:\Program Files\HP\HP Software Update\HPwuSchd2.exe
            C:\WINDOWS\ehome\ehtray.exe
            C:\Program Files\ATI Technologies\ATI Control Panel\atiptaxx.exe
            C:\WINDOWS\ARPWRMSG.EXE
            C:\Program Files\Search Settings\SearchSettings.exe
            C:\WINDOWS\RTHDCPL.EXE
            C:\Program Files\QuickTime\QTTask.exe
            C:\Program Files\Fichiers communs\Microsoft Shared\Works Shared\WkUFind.exe
            C:\Program Files\Logitech\Video\FxSvr2.exe
            C:\Program Files\Zone Labs\ZoneAlarm\zlclient.exe
            C:\documents and settings\hp_administrateur\local settings\application data\dzihv.exe
            C:\Program Files\Mozilla Firefox\firefox.exe
            C:\WINDOWS\eHome\ehSched.exe
            C:\WINDOWS\eHome\ehRecvr.exe
            C:\WINDOWS\system32\dllhost.exe
            c:\windows\system\hpsysdrv.exe
            C:\WINDOWS\eHome\ehmsas.exe
            C:\Documents and Settings\HP_Administrateur\Bureau\HiJackThis.exe
            R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = https://www.msn.com/fr-fr?cobrand=hp-desktop.msn.com&ocid=HPDHP&pc=HPDTDF
            R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Default_Search_URL = https://fr.search.yahoo.com/?fr=cb-hp06
            R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Search Bar = https://www.bing.com/?cc=fr&toHttps=1&redig=D4322FEE7CF74A348CB9CE970F098EF5
            R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://mystart.magentic.com/english/
            R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Bar = https://fr.search.yahoo.com/?fr=cb-hp06
            R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = https://www.msn.com/fr-fr?cobrand=hp-desktop.msn.com&ocid=HPDHP&pc=HPDTDF
            R3 - URLSearchHook: SearchSettings Class - {E312764E-7706-43F1-8DAB-FCDD2B1E416D} - (no file)
            F2 - REG:system.ini: UserInit=C:\WINDOWS\system32\userinit.exe
            O2 - BHO: Aide pour le lien d'Adobe PDF Reader - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Fichiers communs\Adobe\Acrobat\ActiveX\AcroIEHelper.dll
            O2 - BHO: DealioBHO Class - {6A87B991-A31F-4130-AE72-6D0C294BF082} - C:\Program Files\Dealio\kb127\Dealio.dll
            O2 - BHO: GamesBar - {6F282B65-56BF-4BD1-A8B2-A4449A05863D} - C:\Program Files\GamesBar\oberontb.dll
            O2 - BHO: SSVHelper Class - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Program Files\Java\jre1.6.0_05\bin\ssv.dll
            O2 - BHO: (no name) - {7E853D72-626A-48EC-A868-BA8D5E23E045} - (no file)
            O2 - BHO: Programme d'aide de l'Assistant de connexion Windows Live - {9030D464-4C02-4ABF-8ECC-5164760863C6} - C:\Program Files\Fichiers communs\Microsoft Shared\Windows Live\WindowsLiveLogin.dll
            O2 - BHO: Windows Live Toolbar Helper - {BDBD1DAD-C946-4A17-ADC1-64B5B4FF55D0} - C:\Program Files\Windows Live Toolbar\msntb.dll
            O2 - BHO: SearchSettings Class - {E312764E-7706-43F1-8DAB-FCDD2B1E416D} - (no file)
            O3 - Toolbar: Windows Live Toolbar - {BDAD1DAD-C946-4A17-ADC1-64B5B4FF55D0} - C:\Program Files\Windows Live Toolbar\msntb.dll
            O3 - Toolbar: Dealio - {E67C74F4-A00A-4F2C-9FEC-FD9DC004A67F} - C:\Program Files\Dealio\kb127\Dealio.dll
            O3 - Toolbar: GamesBar - {6F282B65-56BF-4BD1-A8B2-A4449A05863D} - C:\Program Files\GamesBar\oberontb.dll
            O4 - HKLM\..\Run: [avast!] C:\PROGRA~1\ALWILS~1\Avast4\ashDisp.exe
            O4 - HKLM\..\Run: [SunJavaUpdateSched] "C:\Program Files\Java\jre1.5.0_11\bin\jusched.exe"
            O4 - HKLM\..\Run: [LVCOMSX] C:\WINDOWS\system32\LVCOMSX.EXE
            O4 - HKLM\..\Run: [LogitechVideoTray] C:\Program Files\Logitech\Video\LogiTray.exe
            O4 - HKLM\..\Run: [LogitechVideoRepair] C:\Program Files\Logitech\Video\ISStart.exe
            O4 - HKLM\..\Run: [HPBootOp] "C:\Program Files\Hewlett-Packard\HP Boot Optimizer\HPBootOp.exe" /run
            O4 - HKLM\..\Run: [HP Software Update] C:\Program Files\HP\HP Software Update\HPwuSchd2.exe
            O4 - HKLM\..\Run: [ftutil2] rundll32.exe ftutil2.dll,SetWriteCacheMode
            O4 - HKLM\..\Run: [ehTray] C:\WINDOWS\ehome\ehtray.exe
            O4 - HKLM\..\Run: [DMAScheduler] "c:\Program Files\HP DigitalMedia Archive\DMAScheduler.exe"
            O4 - HKLM\..\Run: [ATIPTA] "C:\Program Files\ATI Technologies\ATI Control Panel\atiptaxx.exe"
            O4 - HKLM\..\Run: [AlwaysReady Power Message APP] ARPWRMSG.EXE
            O4 - HKLM\..\Run: [Adobe Reader Speed Launcher] "C:\Program Files\Adobe\Reader 8.0\Reader\Reader_sl.exe"
            O4 - HKLM\..\Run: [WorksFUD] C:\Program Files\Microsoft Works\wkfud.exe
            O4 - HKLM\..\Run: [SearchSettings] C:\Program Files\Search Settings\SearchSettings.exe
            O4 - HKLM\..\Run: [RTHDCPL] RTHDCPL.EXE
            O4 - HKLM\..\Run: [REGSHAVE] C:\Program Files\REGSHAVE\REGSHAVE.EXE /AUTORUN
            O4 - HKLM\..\Run: [Recguard] C:\WINDOWS\SMINST\RECGUARD.EXE
            O4 - HKLM\..\Run: [QuickTime Task] "C:\Program Files\QuickTime\QTTask.exe" -atboottime
            O4 - HKLM\..\Run: [NeroFilterCheck] C:\Program Files\Fichiers communs\Ahead\Lib\NeroCheck.exe
            O4 - HKLM\..\Run: [Microsoft Works Update Detection] C:\Program Files\Fichiers communs\Microsoft Shared\Works Shared\WkUFind.exe
            O4 - HKLM\..\Run: [Microsoft Works Portfolio] C:\Program Files\Microsoft Works\WksSb.exe /AllUsers
            O4 - HKLM\..\Run: [Google Desktop Search] "C:\Program Files\Google\Google Desktop Search\GoogleDesktop.exe" /startup
            O4 - HKLM\..\Run: [au] C:\Program Files\Dealio\DealioAU.exe
            O4 - HKLM\..\Run: [ZoneAlarm Client] "C:\Program Files\Zone Labs\ZoneAlarm\zlclient.exe"
            O4 - HKCU\..\Run: [BgMonitor_{79662E04-7C6C-4d9f-84C7-88D8A56B10AA}] "C:\Program Files\Fichiers communs\Ahead\Lib\NMBgMonitor.exe"
            O4 - HKCU\..\Run: [WOOKIT] C:\PROGRA~1\Wanadoo\Shell.exe appLaunchClientZone.shl|DEFAULT=cnx|PARAM=
            O4 - HKCU\..\Run: [swg] C:\Program Files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe
            O4 - HKCU\..\Run: [SpybotSD TeaTimer] C:\Program Files\Spybot - Search & Destroy\TeaTimer.exe
            O4 - HKCU\..\Run: [Nero PhotoShow Media Manager] C:\PROGRA~1\Nero\NEROPH~1\data\Xtras\mssysmgr.exe
            O4 - HKCU\..\Run: [dzihv] "c:\documents and settings\hp_administrateur\local settings\application data\dzihv.exe" dzihv
            O4 - HKUS\S-1-5-19\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\CTFMON.EXE (User 'SERVICE LOCAL')
            O4 - HKUS\S-1-5-20\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\CTFMON.EXE (User 'SERVICE RÉSEAU')
            O4 - HKUS\S-1-5-18\..\RunOnce: [Magnify] Magnify.exe (User 'SYSTEM')
            O4 - HKUS\.DEFAULT\..\RunOnce: [Magnify] Magnify.exe (User 'Default user')
            O4 - .DEFAULT User Startup: Pin.lnk = C:\hp\bin\CLOAKER.EXE (User 'Default user')
            O4 - .DEFAULT User Startup: PinMcLnk.lnk = C:\hp\bin\cloaker.exe (User 'Default user')
            O4 - Startup: Anti-Pub.lnk = C:\Program Files\Antipub\antipub.exe
            O4 - Global Startup: Utilitaire réseau pour SAGEM Wi-Fi 11g USB adapter.lnk = C:\Program Files\SAGEM Wi-Fi USB 802.11g\caroot.pem
            O6 - HKCU\Software\Policies\Microsoft\Internet Explorer\Restrictions present
            O8 - Extra context menu item: &Windows Live Search - res://C:\Program Files\Windows Live Toolbar\msntb.dll/search.htm
            O8 - Extra context menu item: Compare Prices with &Dealio - C:\Documents and Settings\HP_Administrateur\Application Data\Dealio\kb127\res\DealioSearch.html
            O9 - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.6.0_05\bin\ssv.dll
            O9 - Extra 'Tools' menuitem: Console Java (Sun) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.6.0_05\bin\ssv.dll
            O9 - Extra button: (no name) - {1A93C934-025B-4c3a-B38E-9654A7003239} - C:\Program Files\GamesBar\oberontb.dll
            O9 - Extra 'Tools' menuitem: GamesBar - {1A93C934-025B-4c3a-B38E-9654A7003239} - C:\Program Files\GamesBar\oberontb.dll
            O9 - Extra button: Ajout Direct - {219C3416-8CB2-491a-A3C7-D9FCDDC9D600} - C:\Program Files\Windows Live\Writer\WriterBrowserExtension.dll
            O9 - Extra 'Tools' menuitem: &Ajout Direct dans Windows Live Writer - {219C3416-8CB2-491a-A3C7-D9FCDDC9D600} - C:\Program Files\Windows Live\Writer\WriterBrowserExtension.dll
            O9 - Extra button: Aide à la connexion - {E2D4D26B-0180-43a4-B05F-462D6D54C789} - C:\WINDOWS\PCHEALTH\HELPCTR\Vendors\CN=Hewlett-Packard,L=Cupertino,S=Ca,C=US\IEButton\support.htm
            O9 - Extra 'Tools' menuitem: Aide à la connexion - {E2D4D26B-0180-43a4-B05F-462D6D54C789} - C:\WINDOWS\PCHEALTH\HELPCTR\Vendors\CN=Hewlett-Packard,L=Cupertino,S=Ca,C=US\IEButton\support.htm
            O9 - Extra button: (no name) - {e2e2dd38-d088-4134-82b7-f2ba38496583} - C:\WINDOWS\Network Diagnostic\xpnetdiag.exe
            O9 - Extra 'Tools' menuitem: @xpsp3res.dll,-20001 - {e2e2dd38-d088-4134-82b7-f2ba38496583} - C:\WINDOWS\Network Diagnostic\xpnetdiag.exe
            O9 - Extra button: Dealio - {E908B145-C847-4e85-B315-07E2E70DECF8} - C:\Program Files\Dealio\kb127\Dealio.dll
            O9 - Extra 'Tools' menuitem: Dealio - {E908B145-C847-4e85-B315-07E2E70DECF8} - C:\Program Files\Dealio\kb127\Dealio.dll
            O9 - Extra button: Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe
            O9 - Extra 'Tools' menuitem: Windows Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe
            O16 - DPF: {20A60F0D-9AFA-4515-A0FD-83BD84642501} (Checkers Class) - http://messenger.zone.msn.com/binary/msgrchkr.cab56986.cab
            O16 - DPF: {47CEF84E-92D8-4C4A-86D7-CB982889DCC0} (Oberon Media Network Optimizer) - http://mp1.mplay.oberon-media.com/client/flashnet.cab
            O16 - DPF: {4A85DBE0-BFB2-4119-8401-186A7C6EB653} - http://messenger.zone.msn.com/binary/MJSS.cab69309.cab
            O16 - DPF: {54823A9D-6BAE-11D5-B519-0050BA2413EB} (ChkDVDCtl Class) - http://www.cyberlink.com/winxp/CheckDVD.cab
            O16 - DPF: {5D6F45B3-9043-443D-A792-115447494D24} (UnoCtrl Class) - http://messenger.zone.msn.com/FR-FR/a-UNO1/GAME_UNO1.cab
            O16 - DPF: {5ED80217-570B-4DA9-BF44-BE107C0EC166} (Windows Live Safety Center Base Module) - http://cdn.scan.onecare.live.com/resource/download/scanner/wlscbase4009.cab
            O16 - DPF: {B8BE5E93-A60C-4D26-A2DC-220313175592} (MSN Games - Installer) - http://messenger.zone.msn.com/binary/ZIntro.cab56649.cab
            O16 - DPF: {BFF1950D-B1B4-4AE8-B842-B2CCF06D9A1B} (Zylom Games Player) - http://game12.zylom.com/activex/zylomgamesplayer.cab
            O16 - DPF: {C3F79A2B-B9B4-4A66-B012-3EE46475B072} (MessengerStatsClient Class) - http://messenger.zone.msn.com/binary/MessengerStatsPAClient.cab56907.cab
            O16 - DPF: {C45B1500-7B63-47C2-AB25-C28CB46AFDEE} (MediaBar) - http://sib1.od2.com/common/musicmanager/installation/MusicManagerPlugin.CAB
            O16 - DPF: {E6187999-9FEC-46A1-A20F-F4CA977D5643} (ZoneChess Object) - http://messenger.zone.msn.com/binary/Chess.cab57176.cab
            O16 - DPF: {F5A7706B-B9C0-4C89-A715-7A0C6B05DD48} (Minesweeper Flags Class) - http://messenger.zone.msn.com/binary/MineSweeper.cab56986.cab
            O20 - AppInit_DLLs: C:\PROGRA~1\Google\GOOGLE~3\GOEC62~1.DLL
            O23 - Service: Ad-Aware 2007 Service (aawservice) - Lavasoft - C:\Program Files\Lavasoft\Ad-Aware 2007\aawservice.exe
            O23 - Service: avast! iAVS4 Control Service (aswUpdSv) - ALWIL Software - C:\Program Files\Alwil Software\Avast4\aswUpdSv.exe
            O23 - Service: Ati HotKey Poller - ATI Technologies Inc. - C:\WINDOWS\system32\Ati2evxx.exe
            O23 - Service: avast! Antivirus - ALWIL Software - C:\Program Files\Alwil Software\Avast4\ashServ.exe
            O23 - Service: avast! Mail Scanner - ALWIL Software - C:\Program Files\Alwil Software\Avast4\ashMaiSv.exe
            O23 - Service: avast! Web Scanner - ALWIL Software - C:\Program Files\Alwil Software\Avast4\ashWebSv.exe
            O23 - Service: Boonty Games - BOONTY - C:\Program Files\Fichiers communs\BOONTY Shared\Service\Boonty.exe
            O23 - Service: Google Updater Service (gusvc) - Google - C:\Program Files\Google\Common\Google Updater\GoogleUpdaterService.exe
            O23 - Service: InstallDriver Table Manager (IDriverT) - Macrovision Corporation - C:\Program Files\Fichiers communs\InstallShield\Driver\11\Intel 32\IDriverT.exe
            O23 - Service: Service de l'iPod (iPod Service) - Apple Inc. - C:\Program Files\iPod\bin\iPodService.exe
            O23 - Service: LightScribeService Direct Disc Labeling Service (LightScribeService) - Hewlett-Packard Company - C:\Program Files\Fichiers communs\LightScribe\LSSrvc.exe
            O23 - Service: Pml Driver HPZ12 - HP - C:\WINDOWS\system32\HPZipm12.exe
            O23 - Service: TrueVector Internet Monitor (vsmon) - Zone Labs, LLC - C:\WINDOWS\system32\ZoneLabs\vsmon.exe
            1. c'est pas la mm chose
              ad aware est un antispy
              malwarebytes est un anti malware
              1. met a jour malwarebytes : onglet mise a jours
                lance un scan complet du pc
                met tout en quarantaine
                copi le raport et mt le ici pour voir
                  04/10/2008 09:31:11
                  mbam-log-2008-10-04 (09-31-11).txt
                  Type de recherche: Examen rapide
                  Eléments examinés: 0
                  Temps écoulé: 5 second(s)
                  Clé(s) du Registre infectée(s): 0
                  Valeur(s) du Registre infectée(s): 0
                  Dossier(s) infecté(s): 0
                  Fichier(s) infecté(s): 0
