Probleme gravure nero
Bonjour,j ai un probleme pour graver des films , la gravure plante a 65% Je vous montre le rapport de la gravure
Windows 2000 5.0
IA32
WinAspi: File 'Wnaspi32.dll': Ver=4.71 (0002), size=45056 bytes, created 17/07/2002 09:20:56
ahead WinASPI: File 'C:\Program Files\Ahead\nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 12/07/2006 10:58:31
NT-SPTI used
Nero Version: 6.6.1.6
Internal Version: 6, 6, 1, 6
(Nero Express)
Recorder: <HL-DT-ST DVDRAM GSA-H42N>Version: RL01 - HA 1 TA 0 - 6.6.1.6
Adapter driver: <IDE> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ?
CD-ROM: <HL-DT-ST DVDRAM GSA-H42N >Version: RL01 - HA 1 TA 0 - 6.6.1.6
=== Scsi-Device-Map ===
DiskPeripheral : WDC WD101AA atapi Port 0 ID 0 DMA: On
CdRomPeripheral : HL-DT-ST DVDRAM GSA-H42N atapi Port 1 ID 0 DMA: On
CdRomPeripheral : TEAC CD-W54E atapi Port 1 ID 1 DMA: On
=== CDRom-Device-Map ===
HL-DT-ST DVDRAM GSA-H42N D: CDRom0
TEAC CD-W54E E: CDRom1
AutoRun : 0
Excluded drive IDs:
WriteBufferSize: 36700160 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 223MB (228852kB)
Free physical memory: 58MB (59996kB)
Memory in use : 73 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
10.12.2007
Compilation ISO
12:12:55 #1 Text 0 File Isodoc.cpp, Line 6475
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : FALSE
Multisession : TRUE
Multisession type: : Start multisession
Burning mode : DAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : FALSE
Allow more than 255 characters in path : FALSE
Write ISO9660 ;1 file extensions : TRUE
12:12:55 #2 Text 0 File ThreadedTransfer.cpp, Line 531
ReadBuffer-Pipe got 35840KB of Memory
12:12:55 #3 Text 0 File Reader.cpp, Line 124
Reader running
12:12:55 #4 Text 0 File Writer.cpp, Line 122
Writer HL-DT-ST DVDRAM GSA-H42N running
12:12:55 #5 ISO9660GEN -11 File geniso.cpp, Line 3312
First writeable address = 0 (0x00000000)
12:12:55 #6 Text 0 File Burncd.cpp, Line 3305
Turn on Disc-At-Once, using DVD media
12:12:56 #7 Text 0 File DlgWaitCD.cpp, Line 281
Last possible write address on media: 2295103 (510:01.28, 4482MB)
Last address to be written: 716671 (159:15.46, 1399MB)
12:12:56 #8 Text 0 File DlgWaitCD.cpp, Line 293
Write in overburning mode: NO (enabled: DVD)
12:12:56 #9 Text 0 File DlgWaitCD.cpp, Line 2612
Recorder: HL-DT-ST DVDRAM GSA-H42N, Media type: DVD+RW
Disc Manufacturer ID: PHILIPS, Media Type ID: 041, Product revision number: 0
Disc Application Code: 0, Extended Information Indicators: 1
12:12:56 #10 Text 0 File DlgWaitCD.cpp, Line 459
>>> Protocol of DlgWaitCD activities: <<<
12:12:56 #11 Text 0 File ThreadedTransferInterface.cpp, Line 847
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 716672 (716672) = #716672/159:15.47
relocatable, disc pos for caching/writing not required/ required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 716672 blocks [HL-DT-ST DVDRAM GSA-H42N]
12:12:56 #12 Text 0 File ThreadedTransferInterface.cpp, Line 1059
Prepare recorder [HL-DT-ST DVDRAM GSA-H42N] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc not fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 1467744256, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0x00
0 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
716672 | lead-out | 1 | 0x41 | 0x00
12:12:57 #13 Text 0 File SCSIPassThrough.cpp, Line 38
SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME
12:12:57 #14 Text 0 File SCSIPassThrough.cpp, Line 83
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
12:12:57 #15 Phase 24 File dlgbrnst.cpp, Line 1685
Caching of files started
12:12:57 #16 Text 0 File Burncd.cpp, Line 4145
Cache writing successful.
12:12:57 #17 Phase 25 File dlgbrnst.cpp, Line 1685
Caching of files completed
12:12:57 #18 Phase 36 File dlgbrnst.cpp, Line 1685
Burn process started at 4x (5 540 Ko/s)
12:12:57 #19 Text 0 File ThreadedTransferInterface.cpp, Line 2707
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
12:12:57 #20 Text 0 File Cdrdrv.cpp, Line 8648
---- DVD Structure: Physical Format Information (00h) ----
Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD+RW (9), Part Version: 1.1x (2)
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: re-writable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 26053F h
End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
Data in Burst Cutting Area (BCA) does not exist
Disc Application Code: 0 / 0 h
Extended Information indicators: 1 h
Disc Manufacturer ID: PHILIPS.
Media type ID: 041
Number of Physical format information bytes in use in ADIP up to byte 63: 57
Media Specific [16..63]:
00 00 01 50 48 49 4C 49 - 50 53 00 30 34 31 00 39 ...PHILIPS.041.9
23 00 9F 7C 5C 02 28 00 - 9A 7E 70 02 28 00 A0 7B #..|\.(..~p.(..{
68 02 28 04 04 20 E0 00 - F0 00 00 00 00 00 00 00 h.(.............
12:12:57 #21 Text 0 File DVDR.cpp, Line 5561
Drive: HL-DT-ST DVDRAM GSA-H42N
Book Type request [LG]: DVD-ROM
Book Type setting not supported for the loaded disc type
12:12:57 #22 Text 0 File DVDPlusRW.cpp, Line 666
Start write address at LBA 0
DVD high compatibility mode: Yes
12:17:01 #23 SPTI -1502 File SCSIPassThrough.cpp, Line 289
D: CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1502)
Sense Key: 0x04 (KEY_HARDWARE_ERROR)
Sense Code: 0x08
Sense Qual: 0x03
CDB Data: 0x2A 00 00 07 9A C0 00 00 20 00 00 00
Sense Area: 0x70 00 04 00 00 00 00 0A 00 00 00 0F 08 03
Buffer x06c20000: Len x10000
0xFF C2 8F 95 00 5A 86 12 50 62 A0 0B 36 0A EA B9
0x7E 3E ED 2E 23 A5 C2 3A A2 07 BE FA B4 4C 4C AF
0x8D C0 62 30 2C 05 60 30 C4 14 EF B7 BF CE 91 DB
12:17:01 #24 CDR -1502 File Writer.cpp, Line 311
DMA-driver error, CRC error
D: HL-DT-ST DVDRAM GSA-H42N
12:17:04 #25 Text 0 File ThreadedTransfer.cpp, Line 228
all writers idle, stopping conversion
12:17:05 #26 Text 0 File ThreadedTransfer.cpp, Line 222
conversion idle, stopping reader
12:17:09 #27 Phase 38 File dlgbrnst.cpp, Line 1685
Burn process failed at 4x (5 540 Ko/s)
Existing drivers:
File 'Drivers\ASPI32.SYS': Ver=4.71 (0002), size=16877 bytes, created 17/07/2002 08:53:02
File 'Drivers\InCDfs.SYS': Ver=4, 3, 18, 0, size=99584 bytes, created 08/07/2005 17:17:54 (InCD4 driver for win NT/2K/XP)
File 'Drivers\InCDpass.SYS': Ver=4, 3, 18, 0, size=29696 bytes, created 08/07/2005 17:17:36 (InCD4 driver for win NT/2K/XP)
File 'Drivers\InCDrec.SYS': Ver=4, 3, 18, 0, size=8704 bytes, created 08/07/2005 17:17:56 (InCD4 driver for win NT/2K/XP)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Windows 2000 5.0
IA32
NT-SPTI used
(Nero Express)
AutoRun : 0
Excluded drive IDs:
ShowDrvBufStat : 0
BUFE : 0
Use Inquiry : 1
10.12.2007
Compilation ISO
Simulate : FALSE
Write : TRUE
Finalize CD : FALSE
Multisession : TRUE
Burning mode : DAO
Mode : 1
Joliet : TRUE
Reader running
DAO infos:
MCN: ""
Tracks 1 to 1:
DAO layout:
Media type ID: 041
Sense Code: 0x08
Sense Qual: 0x03
Existing drivers:
Registry Keys:
