Probleme NX7600gt
probleme NX7600gt
Bonjour à tous, voila j'ai un petit probleme de driver je pense.
ayant comme carte graphique une MSI NX7600gt je souhaite jouer à DOOM3 ( ce qui est suffisant ). Quand je lance le jeu, le message d erreur suivant apparait:
2010 MHz AMD CPU with MMX & 3DNow! & SSE & SSE2 & SSE3 & HTT
1024 MB System Memory
256 MB Video Memory
Winsock Initialized
Hostname: italia
IP: ca je le garde pour moi :)
doom using MMX & SSE & SSE2 & SSE3 for SIMD processing
enabled Flush-To-Zero mode
enabled Denormals-Are-Zero mode
------ Initializing File System ------
Current search path:
D:\Doom 3/base
D:\Doom 3\base\zpak000.pk4 (961 files)
D:\Doom 3\base\pak004.pk4 (5137 files)
D:\Doom 3\base\pak003.pk4 (4676 files)
D:\Doom 3\base\pak002.pk4 (6120 files)
D:\Doom 3\base\pak001.pk4 (8972 files)
D:\Doom 3\base\pak000.pk4 (2698 files)
D:\Doom 3\base\game00.pk4 (2 files)
game DLL: 0x0 in pak: 0x0
file system initialized.
----- Initializing Decls -----
------- Initializing renderSystem --------
using ARB renderSystem
renderSystem initialized.
4966 strings read from strings/english.lang
Couldn't open journal files
execing editor.cfg
execing default.cfg
"" isn't a valid key
couldn't exec DoomConfig.cfg
couldn't exec autoexec.cfg
4967 strings read from strings/french.lang
----- Initializing Sound System ------
sound system initialized.
----- R_InitOpenGL -----
Initializing OpenGL subsystem
...registered window class
...registered fake window class
...initializing QGL
...calling LoadLibrary( 'opengl32' ): succeeded
Couldn't find proc address for: wglGetExtensionsStringARB
Couldn't find proc address for: wglSwapIntervalEXT
Couldn't find proc address for: wglGetPixelFormatAttribivARB
Couldn't find proc address for: wglGetPixelFormatAttribfvARB
Couldn't find proc address for: wglChoosePixelFormatARB
Couldn't find proc address for: wglCreatePbufferARB
Couldn't find proc address for: wglGetPbufferDCARB
Couldn't find proc address for: wglReleasePbufferDCARB
Couldn't find proc address for: wglDestroyPbufferARB
Couldn't find proc address for: wglQueryPbufferARB
Couldn't find proc address for: wglBindTexImageARB
Couldn't find proc address for: wglReleaseTexImageARB
Couldn't find proc address for: wglSetPbufferAttribARB
...calling CDS: ok
...created window @ 0,0 (640x480)
Initializing OpenGL driver
...getting DC: succeeded
...attempting to use stereo
...PIXELFORMAT 7 selected
...creating GL context: succeeded
...making context current: succeeded
------- Input Initialization -------
Initializing DirectInput...
mouse: DirectInput initialized.
keyboard: DirectInput initialized.
sound: STEREO
X..GL_ARB_multitexture not found
X..GL_ARB_texture_env_combine not found
X..GL_ARB_texture_cube_map not found
X..GL_ARB_texture_env_dot3 not found
X..GL_ARB_texture_env_add not found
X..GL_ARB_texture_non_power_of_two not found
X..GL_ARB_texture_compression not found
X..GL_EXT_texture_filter_anisotropic not found
X..GL_EXT_texture_lod not found
X..GL_1.4_texture_lod_bias not found
X..GL_EXT_shared_texture_palette not found
X..GL_EXT_texture3D not found
X..GL_EXT_stencil_wrap not found
X..GL_NV_register_combiners not found
X..GL_EXT_stencil_two_side not found
X..GL_ATI_separate_stencil not found
X..GL_ATI_fragment_shader not found
X..GL_ARB_vertex_buffer_object not found
X..GL_ARB_vertex_program not found
X..GL_ARB_fragment_program not found
ERROR: The current video card / driver combination does not support the necessary features
Error during initialization
Shutting down OpenGL subsystem
...wglMakeCurrent( NULL, NULL ): success
...deleting GL context: success
...releasing DC: success
...destroying window
...resetting display
...shutting down QGL
...unloading OpenGL DLL
Je pense que c un probleme de compatibilité, open GL ou je ne sais quoi. de plus je ne puis jouer a Conter Strike en openGL mais uniquement en Direct 3D!! Bizard!! :(
J'ai deja essayer de mettre a jour les pilotes, mais rien n y fait!!
Si quelqu un saurait me depanner ou me dire ou je puis DL un pilote fiable je lui en serai reconnaissant. :)
D avance merci
Gianny
Firefox 1.5.0.11
    Normalement le pilote le plus fiable doit etre chez le constructeur...
    essaie la:http://global.msi.com.tw/index.php?func=searchresult&keywords=NX7600gt+
