Probleme gravure avec nero 14
j'ai essayé de graver des images de dvd avec nero 14
mais la gravure échoue
j'ai ceci :
9040-0197-H1L0-0E24-LP91-2493-****-****
Windows 7 6.1
AMD64
Wow64Process
Nero Version: 15.0.19.0
Internal Version: 15,0,19,0
(Nero Express)
Recorder : <TSSTcorp CDDVDW SH-S203P> FW version: SB00 - HA 1 TA 0 - 15.0.19.0
Device bus : <> HA 1
Host system bus : <IDE>
Drive buffer : 2048kB
Bus Type : via Inquiry data
CD/DVD-ROM : <TSSTcorp CDDVDW SH-S203P > FW version: SB00 - HA 1 TA 0 - 15.0.19.0
=== Scsi-Device-Map ===
DiskPeripheral : MAXTOR STM3320613AS iaStorV Port 0 ID 0 DMA: On
CdRomPeripheral : TSSTcorp CDDVDW SH-S203P iaStorV Port 0 ID 1 DMA: Off
CdRomPeripheral : LITE-ON DVDRW LH-20A1S iaStorV Port 0 ID 2 DMA: Off
=== CDRom-Device-Map ===
TSSTcorp CDDVDW SH-S203P E: CdRom0
LITE-ON DVDRW LH-20A1S F: CdRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
BUFE : 0
Physical memory : 2046MB (2095576kB)
Free physical memory: 1247MB (1277000kB)
Memory in use : 39 %
Uncached PFiles: 0x0
Global Bus Type: default (0)
Check supported media : Disabled (0)
20.10.2013
Graver une image DVD
11:27:46 #1 Text 0 File SCSIPTICommands.cpp, Line 617
LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
11:27:46 #2 PHASE 214 File dlgbrnst.cpp, Line 2066
Generation of disc structures started
11:27:46 #3 IMAGEGEN -10 File ImageGen.cpp, Line 400
Image was written as DAO.
DAOI:
MediaCatalogNumber = ''
TocType = 0x40
Finalized = 1
First/Last Track = 1 / 1
1: ISRC = ''
Blocksize = 2048
TrackMode = 'TRM_DATA_MODE1'
TrackConfig = 0x00
First/Last Index = 0 / 1
Index0FilePos = 0, Index1FilePos = 0, NextTrackFilePos = 4076175360
CUES:
MTYP: Mediumtype = DVD (old format) (0x1C)
Image file name: <L:\00 - IMAGES ISO DES DVD FAMILIAUX - IMPORTANTS\DVD1.nrg>
11:27:46 #4 SPTI -1195 File SCSIPassThrough.cpp, Line 225
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1195)
CDB Data: 0x51 00 00 00 00 00 00 00 20 00 00 00
Sense Key: 0x02 (KEY_NOT_READY)
Sense Code: 0x3A
Sense Qual: 0x01
Sense Area: 0x70 00 02 00 00 00 00 0A 00 00 00 00 3A 01
Buffer x008cd980: Len x20
11:27:46 #5 SPTI -1195 File SCSIPassThrough.cpp, Line 225
CDB Data: 0x52 01 00 00 00 FF 00 00 20 00 00 00
Sense Code: 0x3A
Sense Qual: 0x01
11:27:46 #6 SPTI -1195 File SCSIPassThrough.cpp, Line 225
Sense Code: 0x3A
Sense Qual: 0x01
11:27:46 #7 PHASE 215 File dlgbrnst.cpp, Line 2066
Generation of disc structures completed
11:27:46 #8 Text 0 File Burncd.cpp, Line 3634
Turn on Disc-At-Once, using DVD media
11:27:46 #9 SPTI -1195 File SCSIPassThrough.cpp, Line 225
Sense Code: 0x3A
Sense Qual: 0x01
11:27:46 #10 SPTI -1195 File SCSIPassThrough.cpp, Line 225
Sense Code: 0x3A
Sense Qual: 0x01
11:27:46 #11 SPTI -1195 File SCSIPassThrough.cpp, Line 225
Sense Code: 0x3A
Sense Qual: 0x01
11:28:33 #12 Text 0 File Cdrdrv.cpp, Line 10814
---- Disc Structure: Physical Format Information of Control Data Zone in the Lead-in (10h) ----
Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-R (2), Part Version: 2.0x (5), Extended Part Version: 0.0 (0)
Disc Size: 120 mm, Maximum Transfer Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
Outer Limit of Data Recordable Area: 26127F h
Data in Burst Cutting Area (BCA) does not exist
Revision number of maximum recording speed: -
Revision number of minimum recording speed: -
Revision number table of recording speed: - - - - - - -
Class: 0, Extended part version: 0
Start PSN of the Extra Border Zone: 2FE10 h
Start PSN of Physical format information blocks in Extra Border Zone: 2FFA0 h
Media Specific [16..783]:
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
00 02 FE 10 00 02 FF A0 - 00 00 00 00 00 00 00 00 ................
15 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
01 40 C1 FD 9E D8 52 00 - 02 85 0E 10 87 88 80 00 .@....R.........
03 44 41 58 4F 4E 30 00 - 04 30 38 53 00 00 00 00 .DAXON0..08S....
05 88 80 00 00 00 01 00 - 06 09 0C 12 A8 88 90 00 ................
07 88 80 00 00 00 00 00 - 08 06 16 0A 0E 09 04 00 ................
09 98 06 0C 0B 70 88 00 - 0A 80 00 00 00 00 10 00 .....p..........
0B 08 16 18 97 88 75 00 - 0C B7 9B B8 83 00 30 00 ......u.......0.
0D 0F FF D0 00 00 00 00 - 0E 09 1F 39 35 29 1C 00 ...........95)..
0F 50 1B 29 19 AA B5 00 - 10 88 84 00 04 00 04 00 .P.)............
11 00 00 00 00 00 00 00 - 12 09 2C 37 31 29 1C 00 ..........,71)..
13 50 1F 2D 1F 99 B5 00 - 14 88 84 00 04 00 04 00 .P.-............
11:28:35 #13 Text 0 File DlgWaitCD.cpp, Line 334
[E: CDDVDW SH-S203P ] Last possible write address on media: 2298495
Last address to be written: 1990319
11:28:35 #14 Text 0 File DlgWaitCD.cpp, Line 346
[E: CDDVDW SH-S203P ] Write in overburning mode: NO (enabled: CD)
11:28:35 #15 Text 0 File DlgWaitCD.cpp, Line 3034
Recorder: TSSTcorp CDDVDW SH-S203P, Media type: DVD-R
Disc Manufacturer ID: <DAXON0> <08S>
Disc Application Code: 64, Disc Physical Code: 193
11:28:35 #16 Text 0 File DlgWaitCD.cpp, Line 537
[E: CDDVDW SH-S203P ] >>> Protocol of DlgWaitCD activities: <<<
Please insert an empty disc to write to...
(Medium in drive: Inconnu. Medium required by compilation: DVD R/RW; DVD DL; DVD-RAM.)
11:28:35 #17 Text 0 File ThreadedTransferInterface.cpp, Line 879
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 (1 - DVD-ROM)
2 indices, index0 (150) not provided
original disc pos #0 + 1990320 (1990320) = #1990320/442:17.45
not relocatable, disc pos for caching/writing not required/not required
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 1990320 blocks [E: TSSTcorp CDDVDW SH-S203P]
11:28:35 #18 Text 0 File ThreadedTransferInterface.cpp, Line 1095
Prepare [E: TSSTcorp CDDVDW SH-S203P] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x40; Session Closed, disc fixated
Tracks 1 to 1: Idx 0 Idx 1 Next Trk
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4076175360, ISRC ""
DAO layout:
___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 1 | 0x41 | 1990320 | 0 | 0x00
1990320 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
MediaType: DVD-R
11:28:35 #19 Text 0 File SCSIPTICommands.cpp, Line 404
SPTILockVolume - completed successfully for FSCTL_LOCK_VOLUME
11:28:35 #20 Text 0 File Burncd.cpp, Line 4504
Caching options: cache CDRom or Network-Yes, small files-Yes (<64KB)
11:28:35 #21 PHASE 24 File dlgbrnst.cpp, Line 2066
Caching of files started
11:28:35 #22 Text 0 File Burncd.cpp, Line 4626
Cache writing successful.
11:28:35 #23 PHASE 25 File dlgbrnst.cpp, Line 2066
Caching of files completed
11:28:35 #24 PHASE 36 File dlgbrnst.cpp, Line 2066
Burn process started at 4x (5 540 Ko/s)
11:28:35 #25 Text 0 File Cdrdrv.cpp, Line 10814
11:28:35 #26 Text 0 File ThreadedTransferInterface.cpp, Line 2926
Verifying disc position of item 0 (not relocatable, no disc pos, no patch infos, orig at #0): write at #0
11:28:35 #27 Text 0 File Cdrdrv.cpp, Line 10814
11:28:35 #28 Text 0 File DVDR.cpp, Line 3137
Recording mode: Sequential Recording Mode
11:28:35 #29 Text 0 File DVDR.cpp, Line 3295
Start write address at LBA 0
DVD high compatibility mode: Yes
11:28:35 #30 Text 0 File Cdrdrv.cpp, Line 10814
---- Disc Structure: Physical Format Information (00h) ----
Outer Limit of Data Recordable Area: 0 h
Start PSN of the Extra Border Zone: 0 h
Start PSN of Physical format information blocks in Extra Border Zone: 0 h
11:28:35 #31 Text 0 File DVDR.cpp, Line 3437
Reserved Track size: 1990320 (1E5EB0h, 3887MB) -> return code 0
11:28:35 #32 Text 0 File ThreadedTransfer.cpp, Line 275
Pipe memory size 83836800
11:32:30 #33 SPTI -1033 File SCSIPassThrough.cpp, Line 225
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1033)
CDB Data: 0x2A 00 00 00 00 20 00 00 20 00 00 00
Sense Code: 0x04
Sense Qual: 0x01
Sense Area: 0x70 00 02 00 00 00 00 0A 00 00 00 00 04 01
Buffer x0ad90080: Len x10000
0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
11:32:30 #34 TRANSFER -20 File ThreadedTransfer.cpp, Line 1235
Could not perform Write
11:32:30 #35 CDR -1033 File Writer.cpp, Line 340
Drive not ready
11:32:30 #36 PHASE 181 File dlgbrnst.cpp, Line 2066
Writing lead-out...
11:32:31 #37 Text 0 File DVDR.cpp, Line 3750
EndDAO: Last written address was 31 (1Fh)
11:32:31 #38 CDR -1033 File WriterStatus.cpp, Line 316
Drive not ready
11:32:31 #39 TRANSFER -24 File ThreadedTransfer.cpp, Line 1235
Could not perform end of Disc-at-once
11:32:31 #40 Text 0 File DVDPlusDualLayer.cpp, Line 1464
SetDriveCaps: Set LAST LBA of layer 1 to 0
11:32:31 #41 PHASE 38 File dlgbrnst.cpp, Line 2066
Burn process failed at 4x (5 540 Ko/s)
11:32:31 #42 Text 0 File SCSIPTICommands.cpp, Line 454
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
11:32:31 #43 Text 0 File Cdrdrv.cpp, Line 12266
DriveLocker: UnLockVolume completed
11:32:31 #44 Text 0 File SCSIPTICommands.cpp, Line 617
UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
meri de m'aider
j'ai ceci :
Windows 7 6.1
AMD64
Wow64Process
(Nero Express)
AutoRun : 1
Excluded drive IDs:
BUFE : 0
20.10.2013
DAOI:
TocType = 0x40
Finalized = 1
1: ISRC = ''
Blocksize = 2048
TrackConfig = 0x00
CUES:
Sense Code: 0x3A
Sense Qual: 0x01
Sense Code: 0x3A
Sense Qual: 0x01
Sense Code: 0x3A
Sense Qual: 0x01
Sense Code: 0x3A
Sense Qual: 0x01
Sense Code: 0x3A
Sense Qual: 0x01
Sense Code: 0x3A
Sense Qual: 0x01
DAO infos:
MCN: ""
DAO layout:
MediaType: DVD-R
Sense Code: 0x04
Sense Qual: 0x01
Drive not ready
Writing lead-out...
Drive not ready
meri de m'aider
ContributeurAparemment, tu as 2 lecteurs/graveurs de DVD E: et F:
Et il dit que le disque n'est pas prêt...??? c'est surement une bonne raison.
Que cherche tu à faire: copier un DVD sur un autre DVD... ??
Tu dis que c'est une image... Donc le fichier de l'original est déja ripé dans ton disque dur..??
N'est-ce pas un DVD protégé contre les copy pirates..??
tu pourrais essayer avec d'autre programme plus simples comme "CDburnerXP" par ex et qui est aussi capable.
également pour de bons résultats, "CloneCD"
ou sur un autre PC..??... Est-ce que ça a déja marché... ou est-ce la première fois que tu tente cette opération. -
bonsoir
en fait je conserve mes images dvd de famille et j'aurai voulu graver un dvd à partir d'une image iso
la gravure a démarré et s'est interrompue
merci -
ContributeurPour une gravure ISO, c'est UltraISO le plus efficace ...Mais CD Burner le fait très bien aussi...
Néro le fait bien aussi, Mais c'est une usine à Gaz..C'est pour ça que je te suggère autre chose. Quel est le message affiché quand la gravure s'arrête...?
Et ton DVD vierge, c'est une simple gravure ou est-il réinscriptible...R/W..?? -
bonjour
je ne me souviens pas du message
le dvd était un DVD-R
merci -
ContributeurOK donc DVD gravé une seule fois... Si tu as un DVD R/W, tu peux l'utiliser pour faire ces essais, ça t'évitera d'en perdre un à chaque fois...
-- Par contre, tu ne réponds pas si tu as essayé les autres programmes de gravure..??
Car je suppose que c'est le parametrage de Néro qui n'est pas bon... Je ne sais pas ou.. tellement il y a de possibilités -
bonsoir
non je n'ai pas essayé d'autres programmes de gravure -
Contributeurce serait à faire pour faire avancer la situation...
De toutes façons, si ces programmes ne te plaisent pas, tu peux les désinstaller par la suite.
je vois que tu as deux Drive CD ou DVD ROM
Est-ce que ces deux appareils sont bien internes au PC et non des USB à côté du PC..?
Est-ce que tu as le même problème sur les deux..?
