Probleme prog installation Jdownloader
Jdownloader ne demarrant plus, je l'ai désinstallé et j'ai télécharger le programme d'installation sur le site jdownloader.org.
J'ai télécharger les deux versions proposées pour Windows (l'une utilisant une connexion web et l'autre non) aboutissant au même résultat.
En lançant l'installation, la barre de chargement du programme d'installation s'arrête et un fichier texte est généré intitulé "error" et m'indiquant ceci :
"java.lang.InternalError: couldn't create component peer
at sun.awt.windows.WComponentPeer.checkCreation(Unknown Source)
at sun.awt.windows.WComponentPeer.<init>(Unknown Source)
at sun.awt.windows.WCanvasPeer.<init>(Unknown Source)
at sun.awt.windows.WPanelPeer.<init>(Unknown Source)
at sun.awt.windows.WWindowPeer.<init>(Unknown Source)
at sun.awt.windows.WFramePeer.<init>(Unknown Source)
at sun.awt.windows.WToolkit.createFrame(Unknown Source)
at java.awt.Frame.addNotify(Unknown Source)
at java.awt.Window.pack(Unknown Source)
at com.install4j.runtime.installer.frontend.LanguageSelectionDialog.setupComponent(Unknown Source)
at com.install4j.runtime.installer.frontend.LanguageSelectionDialog.<init>(Unknown Source)
at com.install4j.runtime.installer.frontend.WizardScreenExecutor.selectLanguage(Unknown Source)
at com.install4j.runtime.installer.controller.LanguageSelector$1.run(Unknown Source)
at java.awt.event.InvocationEvent.dispatch(Unknown Source)
at java.awt.EventQueue.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.access$000(Unknown Source)
at java.awt.EventQueue$1.run(Unknown Source)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.AccessControlContext$1.doIntersectionPrivilege(Unknown Source)
at java.awt.EventQueue.dispatchEvent(Unknown Source)
at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
at java.awt.EventDispatchThread.run(Unknown Source)
Voila je ne sais pas du tout comment procéder, si vous pouviez m'apporter un peu d'aide ...
