Problème d'écran bleu à répétition : watchdog
Bonjour.
Mon ordinateur plante en écran bleu depuis un mois. Et c'est de plus en plus fréquent. Ca bloque souvent quand je suis sur internet (Internet explorer).
J'ai "bluesreenview". Voici son message :
A problem has been detected and Windows has been shut down to prevent damage
to your computer.
The problem seems to be caused by the following file: watchdog.sys
KERNEL_MODE_EXCEPTION_NOT_HANDLED
If this is the first time you've seen this stop error screen,
restart your computer. If this screen appears again, follow
these steps:
Check to make sure any new hardware or software is properly installed.
If this is a new installation, ask your hardware or software manufacturer
for any Windows updates you might need.
If problems continue, disable or remove any newly installed hardware
or software. Disable BIOS memory options such as caching or shadowing.
If you need to use safe mode to remove or disable components, restart
your computer, press F8 to select Advanced Startup Options, and then
select Safe Mode.
Technical Information:
*** STOP: 0x1000008e (0xe0000001, 0xb8498925, 0xb187e320, 0x00000000)
*** watchdog.sys - Address 0xb8498925 base at 0xb8498000 DateStamp 0x480254ab
En attendant votre aide, bonne soirée.
to your computer.
these steps:
select Safe Mode.
Je vais mettre à jour ma carte graphique, un message est apparu il y a deux jours de la part de NVIDIA.
j'ai Bluescreenview qui pointe deux fichiers. Voici :
ntkrnlpa.exe ntkrnlpa.exe+70156 0x804d7000 0x806e5000 0x0020e000 0x4d00d46f 09/12/2010 15:06:55 Système d'exploitation Microsoft® Windows® 5.1.2600.6055 (xpsp_sp3_gdr.101209-1647) Microsoft Corporation C:\WINDOWS\system32\ntkrnlpa.exe
et
watchdog.sys watchdog.sys+925 0xb8498000 0xb849c500 0x00004500 0x480254ab 13/04/2008 20:44:59 Microsoft® Windows® Operating System 5.1.2600.5512 (xpsp.080413-2108) Microsoft Corporation C:\WINDOWS\system32\watchdog.sys
Ca vous dit quelque chose?
Merci d'avance -
Pour ma config. : [url=https://www.luanagames.com/index.fr.html]SIW_FREEWARE_PC-ARNOLD_20111027_223011.html[/url]
Et voici la version complète : [url=https://www.luanagames.com/index.fr.html]SIW_FREEWARE_PC-ARNOLD_20111027_223535.html[/url]
Up
Salutations,
> détaille ta configuration
> Télécharge WHOCRASHED! ICI >
http://www.resplendence.com/download/whocrashedSetup.exe
Lance le et copie/colle le rapport ici. -
Bonjour! Voilà le rapport :
System Information (local)
computer name: PC-ARNOLD
windows version: Windows XP Service Pack 3, 5.1, build: 2600
windows dir: C:\WINDOWS
CPU: AuthenticAMD AMD Athlon(tm) 64 X2 Dual Core Processor 4400+ AMD586, level: 15
2 logical processors, active mask: 3
RAM: 2146742272 total
VM: 2147352576, free: 2026897408
Crash Dump Analysis
Crash dump directory: C:\WINDOWS\Minidump
Crash dumps are enabled on your computer.
On Wed 26/10/2011 19:09:52 GMT your computer crashed
crash dump file: C:\WINDOWS\Minidump\Mini102611-02.dmp
This was probably caused by the following module: nv4_disp.dll (nv4_disp+0x242E0E)
Bugcheck code: 0x1000008E (0xFFFFFFFFE0000001, 0xFFFFFFFFB8498925, 0xFFFFFFFFB187E320, 0x0)
Error: KERNEL_MODE_EXCEPTION_NOT_HANDLED_M
file path: C:\WINDOWS\system32\nv4_disp.dll
product: NVIDIA Windows XP Display driver, Version 285.58
company: NVIDIA Corporation
description: NVIDIA Windows XP Display driver, Version 285.58
Bug check description: This indicates that a kernel-mode program generated an exception which the error handler did not catch.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: nv4_disp.dll (NVIDIA Windows XP Display driver, Version 285.58 , NVIDIA Corporation).
Google query: nv4_disp.dll NVIDIA Corporation KERNEL_MODE_EXCEPTION_NOT_HANDLED_M
crash dump file: C:\WINDOWS\memory.dmp
Bugcheck code: 0x8E (0xFFFFFFFFE0000001, 0xFFFFFFFFB8498925, 0xFFFFFFFFB187E320, 0x0)
Bug check description: This bug check indicates that a kernel-mode application generated an exception that the error handler did not catch.
On Wed 26/10/2011 15:18:42 GMT your computer crashed
crash dump file: C:\WINDOWS\Minidump\Mini102611-01.dmp
Bugcheck code: 0x1000008E (0xFFFFFFFFE0000001, 0xFFFFFFFFB8498925, 0xFFFFFFFFB321D740, 0x0)
On Sat 22/10/2011 09:04:48 GMT your computer crashed
crash dump file: C:\WINDOWS\Minidump\Mini102211-01.dmp
Bugcheck code: 0x1000008E (0xFFFFFFFFE0000001, 0xFFFFFFFFB84A0925, 0xFFFFFFFFB0E23740, 0x0)
On Wed 19/10/2011 22:47:00 GMT your computer crashed
crash dump file: C:\WINDOWS\Minidump\Mini102011-01.dmp
This was probably caused by the following module: nv4_disp.dll (nv4_disp+0x7664F)
Bugcheck code: 0x1000008E (0xFFFFFFFFE0000001, 0xFFFFFFFFB8470925, 0xFFFFFFFFB0AE56A8, 0x0)
On Sun 09/10/2011 13:50:33 GMT your computer crashed
crash dump file: C:\WINDOWS\Minidump\Mini100911-01.dmp
Bugcheck code: 0x1000008E (0xFFFFFFFFE0000001, 0xFFFFFFFFB8440925, 0xFFFFFFFFB224F2E4, 0x0)
On Tue 04/10/2011 14:17:28 GMT your computer crashed
crash dump file: C:\WINDOWS\Minidump\Mini100411-01.dmp
Bugcheck code: 0x1000008E (0xFFFFFFFFE0000001, 0xFFFFFFFFB83D0925, 0xFFFFFFFFB21EC400, 0x0)
On Wed 28/09/2011 18:51:10 GMT your computer crashed
crash dump file: C:\WINDOWS\Minidump\Mini092811-01.dmp
Bugcheck code: 0x1000008E (0xFFFFFFFFE0000001, 0xFFFFFFFFB8400925, 0xFFFFFFFFB1BC6400, 0x0)
On Wed 28/09/2011 18:50:40 GMT your computer crashed
crash dump file: C:\WINDOWS\Minidump\Mini092911-01.dmp
This was probably caused by the following module: nv4_disp.dll (nv4_disp+0x10F32C)
Bugcheck code: 0xEA (0xFFFFFFFF890CA9A0, 0xFFFFFFFF8A4E23C0, 0xFFFFFFFF8A4DB0B8, 0x1)
Error: THREAD_STUCK_IN_DEVICE_DRIVER
Bug check description: This indicates that a thread in a device driver is endlessly spinning.
Google query: nv4_disp.dll NVIDIA Corporation THREAD_STUCK_IN_DEVICE_DRIVER
On Sun 25/09/2011 13:51:45 GMT your computer crashed
crash dump file: C:\WINDOWS\Minidump\Mini092511-01.dmp
Bugcheck code: 0x1000008E (0xFFFFFFFFE0000001, 0xFFFFFFFFB83A8925, 0xFFFFFFFFB15A2704, 0x0)
On Wed 14/09/2011 15:26:59 GMT your computer crashed
crash dump file: C:\WINDOWS\Minidump\Mini091411-01.dmp
Bugcheck code: 0x1000008E (0xFFFFFFFFE0000001, 0xFFFFFFFFB8398925, 0xFFFFFFFFB26376A0, 0x0)
On Sun 28/08/2011 16:46:21 GMT your computer crashed
crash dump file: C:\WINDOWS\Minidump\Mini082811-01.dmp
Bugcheck code: 0x1000008E (0xFFFFFFFFE0000001, 0xFFFFFFFFB83A8925, 0xFFFFFFFFB026B71C, 0x0)
On Sun 07/08/2011 09:53:00 GMT your computer crashed
crash dump file: C:\WINDOWS\Minidump\Mini080711-01.dmp
This was probably caused by the following module: nv4_disp.dll (nv4_disp+0x10FCBC)
Bugcheck code: 0x100000EA (0xFFFFFFFF89864B30, 0xFFFFFFFF8A517D10, 0xFFFFFFFFB84EBCBC, 0x1)
Error: THREAD_STUCK_IN_DEVICE_DRIVER_M
Google query: nv4_disp.dll NVIDIA Corporation THREAD_STUCK_IN_DEVICE_DRIVER_M
On Thu 28/07/2011 19:15:08 GMT your computer crashed
crash dump file: C:\WINDOWS\Minidump\Mini072811-01.dmp
This was probably caused by the following module: rtkhdaud.sys (RtkHDAud+0x6303E)
Bugcheck code: 0x1000008E (0xFFFFFFFFC0000005, 0xFFFFFFFFB604403E, 0xFFFFFFFFB4A8270C, 0x0)
file path: C:\WINDOWS\system32\drivers\rtkhdaud.sys
product: Realtek(r) High Definition Audio Function Driver (HRTF data Copyright 1994 by MIT Media Lab)
company: Realtek Semiconductor Corp.
description: Realtek(r) High Definition Audio Function Driver
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: rtkhdaud.sys (Realtek(r) High Definition Audio Function Driver, Realtek Semiconductor Corp.).
Google query: rtkhdaud.sys Realtek Semiconductor Corp. KERNEL_MODE_EXCEPTION_NOT_HANDLED_M
On Fri 22/07/2011 19:41:54 GMT your computer crashed
crash dump file: C:\WINDOWS\Minidump\Mini072211-01.dmp
Bugcheck code: 0x1000008E (0xFFFFFFFFC0000005, 0xFFFFFFFFB64A203E, 0xFFFFFFFFAFF4670C, 0x0)
Conclusion
18 crash dumps have been found and analyzed. Only 15 are included in this report. 2 third party drivers have been identified to be causing system crashes on your computer. It is strongly suggested that you check for updates for these drivers on their company websites. Click on the links below to search with Google for updates for these drivers:
If no updates for these drivers are available, try searching with Google on the names of these drivers in combination the errors that have been reported for these drivers and include the brand and model name of your computer as well in the query. This often yields interesting results from discussions from users who have been experiencing similar problems.
Read the topic general suggestions for troubleshooting system crashes for more information.
Note that it's not always possible to state with certainty whether a reported driver is actually responsible for crashing your system or that the root cause is in another module. Nonetheless it's suggested you look for updates for the products that these drivers belong to and regularly visit Windows update or enable automatic updates for Windows. In case a piece of malfunctioning hardware is causing trouble, a search with Google on the bug check errors together with the model name and brand of your computer may help you investigate this further.
