[directx] problème installation
bonjour,
Je n'arrive pas installé directx9c sur mon pc.... il me dit "une erreur interne s'est produite. Consultez les fichiers Dxerror.log et directx.log situés dans le dossier windaub"???
Et bien évidemment je ne comprends rien à ce qu'il y a dedans.
Que dois-je faire ?
directx.log dit :
03/02/06 18:32:33: DXSetup: No command line switch
03/02/06 18:32:34: DXSetup: StartWizard()
03/02/06 18:32:38: dsetup32: IsWow64(): Windows 2000 or Windows 9x.
03/02/06 18:32:40: DXSetup: CDXWSetup()
03/02/06 18:32:43: DXSetup: start installation
03/02/06 18:32:43: DSETUP: DirectXSetupA(): hWnd: 00010628 dwFlags: 02010098
03/02/06 18:32:43: dsetup32: === SetupForDirectX() start ===
03/02/06 18:32:43: dsetup32: Sep 28 2005 14:01:14
03/02/06 18:32:43: dsetup32: DXSetupCommand = 0.
03/02/06 18:32:43: DXSetup: DSetupCallback(): Phase = 0, Steps = 0
03/02/06 18:32:43: dsetup32: DirectXSetupIsJapanese == 0
03/02/06 18:32:43: dsetup32: DirectXSetupIsJapanNec == 0
03/02/06 18:32:43: dsetup32: Installing on Win2K
03/02/06 18:32:43: dsetup32: IsWow64(): Windows 2000 or Windows 9x.
03/02/06 18:32:43: dsetup32: CLR version number = 1.1.4322
03/02/06 18:32:43: dsetup32: Checking the version: HKLM\software\microsoft\directx\Version
03/02/06 18:32:43: dsetup32: CheckVersion(): This is older DirectX which does not have the version value in the registry.
03/02/06 18:32:45: dsetup32: DXCheckTrust(): C:\DOCUME~1\PROUNE~1.ORD\Bureau\news\dxupdate.cab is trusted.
03/02/06 18:32:45: dsetup32: GetCDXUpdate(): Extracting dxupdate.dll from C:\DOCUME~1\PROUNE~1.ORD\Bureau\news\dxupdate.cab.
03/02/06 18:32:45: dsetup32: Extracted file C:\WINNT\system32\DirectX\DXA.tmp\dxupdate.inf from cab
03/02/06 18:32:45: dsetup32: Extracted file C:\WINNT\system32\DirectX\DXA.tmp\dxupdate.dll from cab
03/02/06 18:32:45: dsetup32: GetCDXUpdate(): Loading dxupdate.dll in C:\WINNT\system32\DirectX\DXA.tmp\.
03/02/06 18:32:46: dsetup32: DirectXSetupIsJapanese == 0
03/02/06 18:32:46: dsetup32: DirectXSetupIsJapanNec == 0
03/02/06 18:32:47: dxupdate: -----
03/02/06 18:32:47: dxupdate: DirectXUpdateInstallPlugIn(): Checking for dxdllreg_x86.cab...
03/02/06 18:32:47: dxupdate: DXCheckTrust(): C:\DOCUME~1\PROUNE~1.ORD\Bureau\news\dxdllreg_x86.cab is trusted.
03/02/06 18:32:47: dxupdate: Extracted file C:\WINNT\system32\DirectX\DXA.tmp\dxdllreg_x86.inf from cab
03/02/06 18:32:47: dxupdate: GetDXVersion(): RegQueryValueEx() failed, error = 2.
03/02/06 18:32:47: dxupdate: GetDXVersion(): Current DirectX may be a older version which does not have the version value in the registry.
03/02/06 18:32:47: dxupdate: DirectXUpdateGetSetupInformation(): GetDXVersion() failed.
03/02/06 18:32:47: dsetup32: CSetup::InstallPlugIn(): DirectXUpdateInstallPlugIn() failed.
03/02/06 18:32:47: DXSetup: DSetupCallback(): Phase = 2, Steps = 0
03/02/06 18:32:47: dsetup32: Installation ended with value -9 = Internal or unsupported error
03/02/06 18:32:52: DXSetup: WM_APP_ENDINSTALL
03/02/06 18:32:52: DXSetup: ~CDXWSetup()
03/02/06 18:33:42: DXSetup: No command line switch
03/02/06 18:33:42: DXSetup: StartWizard()
03/02/06 18:33:42: dsetup32: IsWow64(): Windows 2000 or Windows 9x.
03/02/06 18:33:44: DXSetup: CDXWSetup()
03/02/06 18:33:45: DXSetup: start installation
03/02/06 18:33:45: DSETUP: DirectXSetupA(): hWnd: 00030692 dwFlags: 02010098
03/02/06 18:33:45: dsetup32: === SetupForDirectX() start ===
03/02/06 18:33:45: dsetup32: Sep 28 2005 14:01:14
03/02/06 18:33:45: dsetup32: DXSetupCommand = 0.
03/02/06 18:33:45: DXSetup: DSetupCallback(): Phase = 0, Steps = 0
03/02/06 18:33:45: dsetup32: DirectXSetupIsJapanese == 0
03/02/06 18:33:45: dsetup32: DirectXSetupIsJapanNec == 0
03/02/06 18:33:45: dsetup32: Installing on Win2K
03/02/06 18:33:45: dsetup32: IsWow64(): Windows 2000 or Windows 9x.
03/02/06 18:33:45: dsetup32: CLR version number = 1.1.4322
03/02/06 18:33:45: dsetup32: Checking the version: HKLM\software\microsoft\directx\Version
03/02/06 18:33:45: dsetup32: CheckVersion(): This is older DirectX which does not have the version value in the registry.
03/02/06 18:33:46: dsetup32: DXCheckTrust(): C:\PROGRA~1\directx\dxupdate.cab is trusted.
03/02/06 18:33:46: dsetup32: GetCDXUpdate(): Extracting dxupdate.dll from C:\PROGRA~1\directx\dxupdate.cab.
03/02/06 18:33:46: dsetup32: Extracted file C:\WINNT\system32\DirectX\DXB.tmp\dxupdate.inf from cab
03/02/06 18:33:46: dsetup32: Extracted file C:\WINNT\system32\DirectX\DXB.tmp\dxupdate.dll from cab
03/02/06 18:33:46: dsetup32: GetCDXUpdate(): Loading dxupdate.dll in C:\WINNT\system32\DirectX\DXB.tmp\.
03/02/06 18:33:46: dsetup32: DirectXSetupIsJapanese == 0
03/02/06 18:33:46: dsetup32: DirectXSetupIsJapanNec == 0
03/02/06 18:33:46: dxupdate: -----
03/02/06 18:33:46: dxupdate: DirectXUpdateInstallPlugIn(): Checking for dxdllreg_x86.cab...
03/02/06 18:33:46: dxupdate: DXCheckTrust(): C:\PROGRA~1\directx\dxdllreg_x86.cab is trusted.
03/02/06 18:33:46: dxupdate: Extracted file C:\WINNT\system32\DirectX\DXB.tmp\dxdllreg_x86.inf from cab
03/02/06 18:33:46: dxupdate: GetDXVersion(): RegQueryValueEx() failed, error = 2.
03/02/06 18:33:46: dxupdate: GetDXVersion(): Current DirectX may be a older version which does not have the version value in the registry.
03/02/06 18:33:46: dxupdate: DirectXUpdateGetSetupInformation(): GetDXVersion() failed.
03/02/06 18:33:46: dsetup32: CSetup::InstallPlugIn(): DirectXUpdateInstallPlugIn() failed.
03/02/06 18:33:46: DXSetup: DSetupCallback(): Phase = 2, Steps = 0
03/02/06 18:33:46: dsetup32: Installation ended with value -9 = Internal or unsupported error
03/02/06 18:34:32: DXSetup: WM_APP_ENDINSTALL
03/02/06 18:34:32: DXSetup: ~CDXWSetup()
03/02/06 18:40:42: DXSetup: No command line switch
03/02/06 18:40:42: DXSetup: StartWizard()
03/02/06 18:40:42: dsetup32: IsWow64(): Windows 2000 or Windows 9x.
03/02/06 18:40:45: DXSetup: CDXWSetup()
03/02/06 18:40:46: DXSetup: start installation
03/02/06 18:40:46: DSETUP: DirectXSetupA(): hWnd: 0006069C dwFlags: 02010098
03/02/06 18:40:46: dsetup32: === SetupForDirectX() start ===
03/02/06 18:40:46: dsetup32: Sep 28 2005 14:01:14
03/02/06 18:40:46: dsetup32: DXSetupCommand = 0.
03/02/06 18:40:46: DXSetup: DSetupCallback(): Phase = 0, Steps = 0
03/02/06 18:40:46: dsetup32: DirectXSetupIsJapanese == 0
03/02/06 18:40:46: dsetup32: DirectXSetupIsJapanNec == 0
03/02/06 18:40:46: dsetup32: Installing on Win2K
03/02/06 18:40:46: dsetup32: IsWow64(): Windows 2000 or Windows 9x.
03/02/06 18:40:46: dsetup32: CLR version number = 1.1.4322
03/02/06 18:40:46: dsetup32: Checking the version: HKLM\software\microsoft\directx\Version
03/02/06 18:40:46: dsetup32: CheckVersion(): This is older DirectX which does not have the version value in the registry.
03/02/06 18:40:46: dsetup32: DXCheckTrust(): C:\DOCUME~1\PROUNE~1.ORD\Bureau\news\dxupdate.cab is trusted.
03/02/06 18:40:46: dsetup32: GetCDXUpdate(): Extracting dxupdate.dll from C:\DOCUME~1\PROUNE~1.ORD\Bureau\news\dxupdate.cab.
03/02/06 18:40:46: dsetup32: Extracted file C:\WINNT\system32\DirectX\DXF.tmp\dxupdate.inf from cab
03/02/06 18:40:46: dsetup32: Extracted file C:\WINNT\system32\DirectX\DXF.tmp\dxupdate.dll from cab
03/02/06 18:40:46: dsetup32: GetCDXUpdate(): Loading dxupdate.dll in C:\WINNT\system32\DirectX\DXF.tmp\.
03/02/06 18:40:47: dsetup32: DirectXSetupIsJapanese == 0
03/02/06 18:40:47: dsetup32: DirectXSetupIsJapanNec == 0
03/02/06 18:40:47: dxupdate: -----
03/02/06 18:40:47: dxupdate: DirectXUpdateInstallPlugIn(): Checking for dxdllreg_x86.cab...
03/02/06 18:40:47: dxupdate: DXCheckTrust(): C:\DOCUME~1\PROUNE~1.ORD\Bureau\news\dxdllreg_x86.cab is trusted.
03/02/06 18:40:47: dxupdate: Extracted file C:\WINNT\system32\DirectX\DXF.tmp\dxdllreg_x86.inf from cab
03/02/06 18:40:47: dxupdate: GetDXVersion(): RegQueryValueEx() failed, error = 2.
03/02/06 18:40:47: dxupdate: GetDXVersion(): Current DirectX may be a older version which does not have the version value in the registry.
03/02/06 18:40:47: dxupdate: DirectXUpdateGetSetupInformation(): GetDXVersion() failed.
03/02/06 18:40:47: dsetup32: CSetup::InstallPlugIn(): DirectXUpdateInstallPlugIn() failed.
03/02/06 18:40:47: DXSetup: DSetupCallback(): Phase = 2, Steps = 0
03/02/06 18:40:47: dsetup32: Installation ended with value -9 = Internal or unsupported error
03/02/06 18:40:48: DXSetup: WM_APP_ENDINSTALL
03/02/06 18:40:48: DXSetup: ~CDXWSetup()
DXerror dit :
[03/02/06 18:32:47] module: dxupdate(Sep 28 2005), file: dxupdate.cpp, line: 178, function: GetDXVersion
Failed API: RegQueryValueEx()
Error: (2) - Le fichier spécifié est introuvable.
[03/02/06 18:32:47] module: dxupdate(Sep 28 2005), file: dxupdate.cpp, line: 3937, function: DirectXUpdateGetSetupInformation
[03/02/06 18:32:47] module: dsetup32(Sep 28 2005), file: dxupdate.cpp, line: 244, function: CSetup::InstallPlugIn
[03/02/06 18:33:46] module: dxupdate(Sep 28 2005), file: dxupdate.cpp, line: 178, function: GetDXVersion
[03/02/06 18:33:46] module: dxupdate(Sep 28 2005), file: dxupdate.cpp, line: 3937, function: DirectXUpdateGetSetupInformation
[03/02/06 18:33:46] module: dsetup32(Sep 28 2005), file: dxupdate.cpp, line: 244, function: CSetup::InstallPlugIn
[03/02/06 18:40:47] module: dxupdate(Sep 28 2005), file: dxupdate.cpp, line: 178, function: GetDXVersion
[03/02/06 18:40:47] module: dxupdate(Sep 28 2005), file: dxupdate.cpp, line: 3937, function: DirectXUpdateGetSetupInformation
[03/02/06 18:40:47] module: dsetup32(Sep 28 2005), file: dxupdate.cpp, line: 244, function: CSetup::InstallPlugIn
Que dois-je faire ?
directx.log dit :
DXerror dit :
salut,
merci pour cette réponse mais en cherchant sur net j'a trouvé la solution :
- j'ai remis à jour mes pilotes particulièrement de celui de carte son
- j'ai fait réparer avec windaub (démarrage à partir du cd)
- et j'ai désinstaller directx manuellement grâce à :http://membres.lycos.fr/shivash/Windows/Desinstaller_DirectX.htm
- puis j'ai redémarré et installé directx9 télécharger à partir de clubic.
Et voilà ça remarche !!!!
Merci encore ! -
As-tu essayé le téléchargement à cette adresse :
http://www.microsoft.com/downloads/details.aspx?FamilyID=0a9b6820-bfbb-4799-9908-d418cdeac197&DisplayLang=fr
Bien à toi -
Même souci que toi, j'ai fait tout ce que tu as écrit mais j'ai toujours le problème...
Y aurait-il autre chose à faire ? -
Je n'arrive également pas à installer DIRECTX sur mon ordinateur, il m'affiche le message d'erreur "une erreur interne s'est produite. Consultez les fichiers Dxerror.log et directx.log situés dans le dossier "
Dirextx est pourtant bien désinstaller de mon ordinateur, aucune installation ne marche, c'est a chaque fois l'échec !
Merci d'avance,
Mel !
