SDK Android ne reconnait pas Java
J'ai le SDK Android et quand je l'ouvre il me dit:
Warning:Java not found in your path.
Checking if it's installed in C:\Program Files\Java instead (64-bit).
Java was found at C:\Program Files\Java\jre6\bin\java.exe.
Please consider adding it to your path:
Under Windows 7,open Control Panel/ System / Advanced System Settings /Environment Variables
At the end of the "Path" entry in "User variables", add the following:
;C:\Program Files\Java\jre6\bin\java.exe
Je l'ai fait mais ca continue de me montrer cette fenetre
Comment résoudre ce problème?
Merci de votre réponse,
MustangEmile
MustangEmile
