Comment désinstaller Logic Studio 9 ?
Fermé
Je voudrais savoir comment désinstaller logic studio 9, car il me prend beaucoup de place.
Merci d'avance
Merci d'avance
ou ici
OK. For anyone that wants to / need to uninstall Logic 8 this is where all the files and folders are located.
I have not tried deleting all these files. In theory deleting all the below will remove Logic Studio completely from your system.
HD/Library/Application Support/Logic/
HD/Library/Application Support/Soundtrack Pro/
HD/Library/Application Support/WaveBurner/
HD/Library/Audio/Impulse Reponses/
(Impulse response files for Space Designer reverb unit)
*User*/Library/Preferences/com.apple.logic.pro.plist
*User*/Library/Preferences/com.apple.logic.pro.cs
HD/Library/Audio/Apple Loops/Apple/Apple Loops for GarageBand/
HD/Library/Audio/Apple Loops/Apple/Apple Loops for Soundtrack Pro/
HD/Library/Audio/Apple Loops/Apple/iLife Sound Effects/
HD/Library/Audio/Apple Loops/Apple/Jam Pack 1/
HD/Library/Audio/Apple Loops/Apple/Jam Pack Remix Tools/
HD/Library/Audio/Apple Loops/Apple/Jam Pack Rhythm Section/
HD/Library/Audio/Apple Loops/Apple/Jam Pack Symphony Orchestra/
HD/Library/Audio/Apple Loops/Apple/Jam Pack World Music/
HD/Library/Audio/Apple Loops Index/
Licence for Logic:
/Library/Application Support/ProApps/Logic Studio System ID
I think that's eveyrthing. You can look for receipts for the Logic studio apps and jampacks in
HD/Library/Receipts/
-->source : https://forums.macrumors.com/threads/fully-uninstall-logic-8.774305/ -
si tu as un windows
tu vas dans panneau de configuration
pui tu vas dans désinstaler un programe,tu clique sur celui que tu veut desinstaller -
salut
rendez-vous dans 'panneau de configuration' puis 2 clic sur 'Ajouter ou supprimer des programmes' ensuit sur la nouvelle fenêtre qui s'ouvre 2 clic sur le mon du logiciel a désinstaller (logic studio 9) puis cliquer sur désinstaller . -
salut
sorry capitainemoutarde
http://www.macosxaudio.com/forums/viewtopic.php?f=2&t=45428
https://www.logicprohelp.com/forum/viewtopic.php?t=30524 -
alors le problème résolue ?
