Problem internet
Prière m'aider à resoudre ce problem, car je ne peu pas ouvrir ni jeux ni vedeos sur Facebook et des sites similaires.
http://www.pictures-upload.com/up/0uycdpev20101129319h92vj00t.jpg
Merci d'avance
  1. Bonjour, j'ai trouvé ça :
    It's just a common script error message that can be eliminated easily by Clicking: Menu: Tools - Internet Options - Advanced tab. Check "Disable script debugging" Uncheck "Display a notification about every script error" Unless you are the developer of the web site, you may not want this notification. And like magic; problem solved !
    1. Salut
      Problem not yet solved, could u help me again.
      he said that the page: done but with error
      Thanks
  2. Bonjour
    Je ne peu plus ouvrir mes fichiers ( PPS...) Photos ...
    Merci de me renseigner
