XDTV ne marche pas
Bonjour, je viens d'essayer d'installer XDTV, mais il ne veut pas se lancer.
Quand je le lance depuis une console, voici ce qui s'affiche:
[user@localhost ~]$ xdtv
This is xdtv 2.1.1 running on Linux/i686 (2.6.11-6mdk).
scandir: No such file or directory
filename = /home/user/.xdtv/xdtvrc
/dev/video: no overlay support
xdtv_v4l-conf had some trouble, trying to continue anyway
Warning: Cannot convert string "fileSelectorView" to type Widget
wmhooks: netwm detected
wmhooks: netwm state above supported
wmhooks: netwm fullscreen supported
wmhooks: nothing found...
DGA: server=2.0, include=2.0
VidMode: server=2.2, include=2.2
  available video mode(s): 1024x768 1024x768 1024x768 1024x768 1024x768 1024x768 960x720 928x696 896x672 832x624 800x600 800x600 800x600 800x600 800x600 800x600 800x600 800x600 800x600 768x576 768x576 700x525 700x525 640x512 640x512 640x512 640x480 640x480 640x480 640x480 640x480 640x480 720x400 640x400 576x432 640x350 576x384 512x384 512x384 512x384 512x384 512x384416x312 400x300 400x300 400x300 400x300 400x300 320x240 320x240 320x240 320x240 360x200 320x200 320x175
  Selected XvVideo: video4linux on port 61 (overlay)
Selected XvImage adaptor with yuyv support: ATI Rage128 Video Overlay on port 62 (grabdisplay)
XV Information:
    XV_ENCODING max value = 1000
    XV_ENCODING min value = -1000
    XV_ENCODING cur value = 7
    XV_BRIGHTNESS max value = 1000
    XV_BRIGHTNESS min value = -1000
    XV_BRIGHTNESS cur value = 0
    XV_CONTRAST max value = 1000
    XV_CONTRAST min value = -1000
    XV_CONTRAST cur value = 0
    XV_SATURATION max value = 1000
    XV_SATURATION min value = -1000
    XV_SATURATION cur value = 0
    XV_HUE max value = 1000
    XV_HUE min value = -1000
    XV_HUE cur value = 0
    XV_MUTE max value = 1
    XV_MUTE min value = 0
    XV_MUTE cur value = 0
    XV_FREQ max value = 16000
    XV_FREQ min value = 0
    XV_FREQ cur value = 12276
*** AUDIO DEVICE TYPE = alsa
driver is not v4l2
v4l: device /dev/video does not support overlay!
WARNING: overlay mode disabled
v4l: mmap()'ed buffer size = 0x68100
Checking device palette capabilities:
    grey
    rgb16(565)
    rgb24
    rgb32
    rgb15(555)
    yuv422
    yuyv
    yuv422p
    yuv410p
*** GRABBER DEVICE TYPE = video4linux
ioctl VIDIOCSAUDIO: Invalid argument
Segmentation fault
Quelqu'un saurait-il ce qui ne va pas SVP ?
PS: Le problème ne peut venir de ma carte TV car KDE TV, xawTV et Zapping marchent sans problème.
  1. Bijour,
    Ta configuration doit avoir un probleme. Tu utilises XV pour sortir de l'image. Essayes en des moins plus lent mais diferent pour voir si ca vient de lui. Comme sortie y'a x11 qui est la plus lente, et je me rapelle pas les autres.
    A++
    1. Merci de t'intéresser à mon problème, mais j'ai rien compris..
    2. Ok désolé, je pense pas que ma phrase etait francaise.
      Je vais essayé de le refaire mais en plus clair.
      Sous linux tu peu utiliser plusieurs "drivers" ou moyen pour envoyer une image a ta carte video. Si je regarde mon menu de configuration de gmplayer, je voie comme dans parametre video les drivers suivants comme disponible : xmga, xv,x11,gl, gl2 etc etc.
      D'apres la sortie de xdtv tu utilises ou essayes d'utiliser le drivers XV. Il se peut qu'il ne marche po. Alors je te proposais d'en essayer un autre, par exemple x11 qui est le plus lent mais aussi le plus courant. Donc faut que tu trouves le menu ou le fichier de configuration et remplacer xv par x11. Puis eventuellemnt essayer les autres.
      Voila j'espere que j'espere que j'ai ete plus clair. Encore désolé pour mon chinois intensse.
      A++
  2. Ca n'a pas marché mais merci de t'être interessé à mon problème.
    J'ai eu la réponse sur le forum de XDTV: il fallait que je détermine le périphérique vidéo en lançant XDTV avec la commande /usr/bin/xdtv -c /dev/video1 . Car c'est /dev/video qui est pris par défaut, et chez moi il correspond à autre chose mais je sais pas exactement quoi (cf ma question "Savoir à koi correspondent les /dev/video ?").
